Old 11-29-2012, 09:48 PM   #15
austell
Drives: Firestorm FR-S
I plan on using the stock headunit unless I absolutely have to upgrade. The only open spot on the stock headunit is the RCA cable spot
austell is offline   Reply With Quote
Old 02-15-2014, 05:45 PM   #16
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Looks like you can access the top of the rear struts with your design, clever indeed! You should have put these onto market man looks like you did a great job!!
Old 04-08-2015, 11:10 AM   #17
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
You've been commenting on my build thread so I thought I'd check out what you had done. These look great. Very clean. I might have to steal some of your ideas like the placement of the terminal cup and the nut plates. You said they were a headache but it really makes the front look clean so I might try that.
ハチロク is offline   Reply With Quote
Old 04-08-2015, 12:06 PM   #18
gramicci101
Off Topic
Don't use t-nuts, look up hex-drive threaded inserts instead. Put a bit of gorilla glue or PL premium or some other adhesive on the outside threads before screwing it in, and chase the inside threads with a tap to make sure they're clean.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
ハチロク (04-08-2015), wheelhaus (04-08-2015)
Old 04-08-2015, 12:31 PM   #19
wheelhaus
wheelhaus's Avatar
I had issues with the t-nuts, since the rings were made of MDF, the spikes on the t-nuts wouldn't hold them in place well, and in some cases they'd just chew through the MDF and spin. I'd say use @gramicci101 suggestion if you want to use hex bolts, or just go super cheap and use standard wood screws. MDF is just soft.
Old 04-08-2015, 01:05 PM   #20
toast
Drives: 14 BSP Edelbrock BRZ
How are the boxes mounted to the car?
toast is offline   Reply With Quote
Old 04-08-2015, 01:39 PM   #21
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
+1 on the t-nuts
I used t-nuts and now it's impossible to remove my subs... If I ever have to I'll need to drill off the screw heads.
rmjjensen is offline   Reply With Quote
Old 04-08-2015, 01:40 PM   #22
wheelhaus
wheelhaus's Avatar
They fit snugly into the little alcoves in the corner, and I'm using a couple small strips of industrial Velcro on the bottom to keep them in place. If I hit a sharp enough rise or a bump that lifts the car I can hear them thump when they settle, but no amount of high G or braking can make them move. I'd like to fasten them into place, but this is working well enough for now.
The Following User Says Thank You to wheelhaus For This Useful Post:
toast (04-08-2015)
SQ Audio Build w/ Custom 8" Enclosures wheelhaus Electronics | Audio | NAV | Infotainment 24 04-17-2015 09:53 AM
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 01:28 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Custom Order Group Buy - Enkei PF01 17" x 9", +35, 5x100 colHolm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 10-24-2012 11:42 PM
