Old 03-31-2015, 01:13 PM   #771
sw20kosh
Drives: 2013 Black FR-S
More video of the turbo kit on track:
The Following 6 Users Say Thank You to sw20kosh For This Useful Post:
Blizzz (04-01-2015), CSG Mike (03-31-2015), Dinko (04-03-2015), kanundrum (03-31-2015), mkivsoopra (03-31-2015), rb6freak (03-31-2015)
Old 04-05-2015, 09:33 AM   #772
bjun
bjun's Avatar
Drives: white premium brz M/T
Anyone with oil pressure gauge? I installed mine last night and I put the oil pressure and temp sensor both on the Ptuning oil cooler. The temp is reading fine but the pressure is always at 100psi
bjun is offline   Reply With Quote
Old 04-05-2015, 09:40 AM   #773
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Either sender is damaged, or connection is loose or its not properly grounded.
Sent from my SM-N900A using Tapatalk
Old 04-05-2015, 10:37 AM   #774
bjun
bjun's Avatar
Ok, thanks. I will double check my wirings
I read on forum some people are tapping their oil pressure sensor into the oil galley? I was wondering if putting the pressure sensor on the oil cooler itself was wrong
Old 04-05-2015, 11:34 AM   #775
buddy32
Drives: WRB Subaru BRZ Limited
I have the innovate oil pressure/ temp sensor hooked up to the oil cooler. The pressure shows 100 when during cold start, and will eventually come back down when the car warms up.
Edit: This copy and paste explains better than I can.
"When and engine starts, all the oil is in the sump and the oil pressure is zero. The pump cannot begin to deliver oil or generate oil pressure until it has sucked up cold oil through the filter screen and the pick up tube. Hence, cold start lubrication is greatly assisted by having a short, wide pick up tube and oil that has very good cold flow properties.
When the oil reaches the pump it is then forced through the filter and then through the engine. However, as the oil is still cold and the oil channels are very narrow, flow is slow and a large back pressure develops so that the pressure Gauge registers a dramatic pressure increase.
As the oil circulates and warms up, it flows faster and the oil pressure declines to a stable level. It is only at this point that the engine is being properly lubricated. Until stable oil pressure is obtained wear rates are high due to inadequate oil delivery to the wearing surfaces. Under cold start conditions, a "good" oil is one which gives stable oil pressure the fastest."
buddy32 is offline   Reply With Quote
The Following User Says Thank You to buddy32 For This Useful Post:
bjun (04-08-2015)
Old 04-07-2015, 10:12 AM   #776
jchudson13
jchudson13's Avatar
Drives: 13' Scion FR-S Firestorm MT
Hey guys, I will be making the trip to PTuning to get my PTuning turbo kit installed along with other parts. I will be leaving this coming Sunday night April 12 around midnight. It's about an 8hr drive for me but I'm super pumped about it. This will be my first legit build and I'm having them do the install because I want it done right. Their customer service is excellent, I've been emailing them with any questions I have since August of last year with quick replies every time. I have requested to have them send me some pictures during the build and I will be reporting the progress with pictures and a final dyno video with numbers they should have the install and tune done by April 21.
Here is the list of things I have held at PTuning and having them install:
*PTUNING Turbo Kit (Black)
*PTUNING 4-1 Header
*PTUNING Turbo Back Exhaust
*ECU & Fueling Package
*PTUNING Oil Cooler w/ Gauge Adapter
*Koyo Radiator
*Exedy Stage 2 Cerametallic Clutch Kit
*Exedy Lightened Flywheel
*PTUNING SS Braided Teflon Clutch Line Kit
*AEM Digital Boost Gauge
*AEM Digital Oil Pressure Gauge
*AEM Digital Wideband AFR Gauge w/ Failsafe
*PTUNING EBCS
*PTUNING Windshield Washer Reservoir Kit
Near Future Upgrades:
-PTUNING adjustable rear sway bar and end links
-wheels and tires (Gramlights 57Xtreme 17x9 with Hankook RS3 tires 245/40/17)
-coilovers (not sure what ones yet)
-some kind of brake upgrade (whether it be pads, lines, and fluid, or BBK)
Also, if anyone has been using the Exedy stage 2 cerametallic clutch please let me know how the drivability is. Feel free to chime in if there is anything to look out for with this kit as well.
jchudson13 is offline   Reply With Quote
The Following 2 Users Say Thank You to jchudson13 For This Useful Post:
Deadpool_25 (04-25-2015), kanundrum (04-07-2015)
Old 04-07-2015, 10:37 AM   #777
buddy32
@jchudson13, u found me on youtube! Haha
Old 04-07-2015, 10:38 AM   #778
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
A 130 lb box shipped out of Manassas, VA heading my way on Monday. Should be here on Thursday.
Old 04-07-2015, 10:50 AM   #779
copafeel
Drives: Honda 2000
copafeel is offline   Reply With Quote
Old 04-07-2015, 10:51 AM   #780
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by copafeel View Post
When you getting yours? I hope you are first in line when they start selling them again in July.
Old 04-07-2015, 10:55 AM   #781
kanundrum
Drives: 2013 Whiteout FR-S
*PTUNING 4-1 Header
*Koyo Radiator
*PTUNING EBCS
When will you be at the shop ? Always like having lunch with folks coming out of town.
Old 04-07-2015, 10:57 AM   #782
Blizzz
I couldn't tell the difference between the stage 2 clutch and a normal clutch. Granted I've only driven the car less than 1k miles with the stage 2 in it, but it is VERY easy to drive. Seriously, it's a no brainer to have it.
Blizzz is offline   Reply With Quote
Old 04-07-2015, 11:06 AM   #783
jchudson13
jchudson13's Avatar
I will arrive at the shop around when they open on the 13th, but I plan on getting a rental car while I'm there. I will be staying there the whole week until my car is done. I could give you a heads up when i get into town or later that day. I might need to get some rest before hand since I'll be driving through the night but yeah dude anytime.
Old 04-07-2015, 11:08 AM   #784
copafeel
Drives: Honda 2000
Haha I hope so too man. Maybe Ptuning will let me do paycheck deductions lol.
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
