Old 04-06-2015, 06:16 PM   #1
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Tuning an RS 1.0
Are the ecu's different and or do they require different roms to tune?
Jaden
Jaden is offline   Reply With Quote
Old 04-06-2015, 06:18 PM   #2
raven1231
All that additional power requires a lot of extra tuning. No they are the same, just pick the matching ID
Old 04-06-2015, 08:10 PM   #3
Jaden
Road-hole
ok then are there different roms for ECUflash then for 2015???
Are there different ROMS on ECU flash for 2015?
It wouldn't find it when I read the rom on that one.
Jaden
Old 04-06-2015, 08:14 PM   #4
raven1231
Do you have an OFT or Ecutek? If OFT you can plug it in and it will tell you which CAL ID you have.
Old 04-06-2015, 08:35 PM   #5
jflogerzi
jflogerzi's Avatar
RS 1.0's use the same engine, same power, etc... so the ecu is the same. For non FI tuning, I recommend OFT. If your going to go to FI at some point, just get ecutek right off the bat.
Old 04-06-2015, 10:07 PM   #6
steve99
Drives: FT86
Jaden
2015 86\brz in usa\canada generally run
ZA1JD00C MANUAL
ZA1JD00D AUTO
however always best to check using your flash device to read ecu calid or android torque or similar obd scanner device
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 07:53 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
