#43 | |
Alexandrino_Auto
Drives: series.Blue
The Shadetree Project: I turn wrenches
#44 |
Drives: 2015 Scion FR-S RS1.0
Are torque specs specific to your car? If so where can i find mine? If not what are the general torque specs for the header area? i want to change my headers but do not know what are the bolt torque specs.....
#45 | |
Drives: FT86
see here http://www.borla.com/17284.pdf 22 foot pounds header/engine bolts 26 foot pounds header/overpipe bolts added some oil cooler info as well to first post Last edited by steve99; 03-08-2015 at 07:36 PM. |
| The Following User Says Thank You to steve99 For This Useful Post: | eddiev116 (03-09-2015) |
#46 |
One & Done (AOZORA)
Drives: '15 Series.Blue BRZ (WRB)
If I get a test pipe, what does that exactly replace and will I most likely fail the NYC emissions test with it? Debating whether to get that to go with my new exhaust system, but if its going to fail me on the emissions test, then it may not be worth the trouble.
"I have the need....the need for speed! - Maverick (Top Gun)
#47 | |
Drives: FT86
Generally if you remove one or more of the two catalytic converters (cats) in the exhaust you may fail testing depending on how strict the testing is in your area. If your referring to a "track pipe" or a muffler delete then that should not effect emissions test but you may fail on noise output. I'm in OZ so not up with tests in USA. |
#48 |
Drives: FT86
added a bit more info on headers and oil coolers to first post.
#49 |
Drives: rocketship
COnsdiering running the Ultimate racing 2.75 inch overpipe and resonated catless front pipe combo with the skunk2 header and perrin 2.5 ich resonated combo.
THe 2.75 inch piping work with the 2.5 inch outlet on the header and inlet on the perrin work without any issues? THoughts on any issues with running this setup?
#50 |
Some Dumb Guy
Drives: wanting an Acabian
@steve99, Awesome post, very informative, thank you. Helps simplify the decision about where to start and get the best bang for your buck.
She said it was her or the car. Longest
she had ever seen. |
| The Following User Says Thank You to Blu-by-U For This Useful Post: | steve99 (03-25-2015) |
#51 |
Drives: FT86
added a couple of link to intke manifold oil starvation high rpm ect
#52 |
Drives: Subaru BRZ Limited
Anyone know that the TRD intake need to do the maf-scaling?
Thanks. |
#54 |
Drives: 2015 FRS
"If you want more than about 35-40 wheel horsepower gain then your going to need to go Forced Induction FI either Turbo or Supercharger, just skip NA mods "
Hey, I've been doing some research/lurking here for the past month and I have zero experience with modding a car. I would just like to clarify if this statement means that you can go from a completely stock frs/brz and add a turbo kit onto it without any other modifications? I tried to use the search function, but I couldn't find anything that I was looking for(may have been incorrectly searching). Thanks! |
#55 | |
Drives: FT86
Their is a forced induction thread that should provide answers. But quick and dirty answer Yes you can bolt on a supercharger or turbocharger kit to a stock frs\brz motor without decompressing or other internal engine mods On petrol you will be limited to about 10 psi boost due to limitations of stock fuel injection system. arround 280 wheel hp You might also want to budget for a clutch and an oil cooler and a bigger radiator if you want to drive it hard or track it. Without clutch you might want to stick to about 7 or so psi boost arround 240 wheel hp and you might get away without the radiator , but an oil cooler is still needed, unless you live in cold climate and you only drive hard for very short periods stock cars are about 170 wheel hp You can break stock cars by driving them like a d1ck, you will break a boosted one faster if you drive in that manner with no respect for the extra mechanical stresses and heat loading you are putting on the car. |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Aozora.BRZ (04-15-2015), Caspeed (06-14-2015) |
#56 |
Drives: 2015 Subaru BRZ
I love this thread!
Thanks to the information, here, I am now running Open Flash's UEL headers and an E85 Stage 2 tune on my 2015 BRZ. And I have the glove box outlet cap in the sound tube. I'm no mechanic--i've never done anything more complicated than brakes on any of my previous cars. But I had no trouble installing the header and flashing the tune in my driveway. The car I bought was a fun little car. Now, with the investment of about $1000 and a Saturday of work, I have something that feels like a real sports car! I know it's still not actually a fast car but it feels dramatically faster. I don't have access to a dyno, but I can easily believe the changes have added at least 10% more power, and mostly in the 4-5000 rpm range which make daily driving so much more fun! Thanks for the great information. |
| Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! | Simon99 | BRZ First-Gen (2012+) — General Topics | 104 | 10-10-2016 12:45 PM |
| What mods next? Exhaust? Intake? | Ludacrits | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-05-2013 08:25 PM |
| Question about basic performance mods | bdanisi | Engine, Exhaust, Transmission | 2 | 01-25-2013 05:40 PM |
