Old 04-05-2015, 12:46 AM   #1
DemonRawr
Drives: 2014 BRZ Limited 6M
Noise in the Rear with ST Coilovers
Ever since I've installed a set of used ST coilovers, there has been a very pronounced clunking and thumping noise coming from the rear. I've went the distance to torque every bolt of the suspension, but to no avail...
The last attempt my friend and I did was to tighten the top nut of the rear coilovers by using a socket to hold the shaft in place while using an allen key to tighten. However, no matter how much we tighten, it would not fully tighten. It would get tighter at certain degrees, but then it gets light again.
I was wondering if anyone else has this issue. I had Stance Coilovers in the past and they would only clunk below 15 mph. The current noise produced by my set of ST is definitely worst.
DemonRawr is offline   Reply With Quote
Old 04-05-2015, 07:12 AM   #2
cortrain
Drives: Whiteout FRS
I had a similar issue. However, I just needed to zip the nuts on with an impact gun. Take the nut completely off, lightly hand thread it a turn (So the gun can get some momentum), and zip it on.
Hope this helps!
cortrain is offline   Reply With Quote
Old 04-05-2015, 11:18 AM   #3
vroom4
Torque the lower steut bolt to 90 ft lbs. That's where my noise keeps coming from. I just keep re tightening.
Should probably buy new oem bolts at some point.
vroom4 is offline   Reply With Quote
Old 04-05-2015, 11:32 AM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
That sure sounds like a stripped bolt/nut. I hope not for your sake but...
The Following User Says Thank You to cjd For This Useful Post:
8R6 (04-05-2015)
Old 04-05-2015, 11:36 AM   #5
8R6
8R6's Avatar
Drives: FRS
Definitely sounds like a stripped bolt/nut. Probably why you hear the clunking because it's unable to be tightened down to spec.
8R6 is offline   Reply With Quote
Old 04-05-2015, 12:10 PM   #6
vroom4
Yea didn't notice that sentence, take the coilover off and take that nut off and see what's going on
Old 04-07-2015, 11:12 AM   #7
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
Top nut is most likely your issue, especially if it wasn't tightened correctly (as in using a key to keep the shock from spinning while tightening the top bolt). I had all kinds of noises for a week until I took the time to correctly torque the top bolt.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 05-01-2015, 08:40 PM   #8
zeal86
zeal86's Avatar
Drives:
With my RS*Rs I did not have the option of using a hex key to keep the shaft from spinning... I cut a m14 1.5mm nut in half and used that with a small piece of aluminum to hold the shaft. I used the nut to protect the threads and the aluminum to protect from marring the flat side of the shaft. Worked very well!
projekt zeal86 build
zeal86 is offline   Reply With Quote
Old 05-01-2015, 10:21 PM   #9
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Use a pass thru wrench and use a 10mm socket to put on top and it'll hold it in place.
clank, clunk, coilovers, noise, st coilovers
Noise coming from rear of car B-R-Z BRZ First-Gen (2012+) — General Topics 9 05-30-2017 06:04 AM
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
ST coilovers noise b rawr z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-24-2014 11:08 AM
Noise coming from the rear end... jm1681 Issues | Warranty | Recalls / TSB 17 03-13-2014 07:30 PM
rear brake noise norcal_brz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-19-2013 03:25 PM
