Old 01-09-2015, 12:18 AM   #197
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Originally Posted by smg1138 View Post
So, is the consensus here that this wheel will fit the stock suspension without rubbing? I want to use these with a 245 tire on the stock suspension. I'll probably get coilovers later, but not until my warranty is up next year.
It fit fine for me no rubbing. I didn't want to buy coils and wheels / tires at the same time either.
Mad_Mike is offline   Reply With Quote
Old 01-15-2015, 07:31 AM   #198
Panman
Panman's Avatar
Drives: 86 GTS
I have Bilstein B6 with STI Pink springs (so stock spring diameter), I currently have a camber bolt and Raceseng Camber Tops in the front and LCAs in the rear (-3.0 Camber front, which I want to dial back to around -2.6) I'm assuming that I'll have to pull some of the camber bolt camber out and get some of the camber back through the Raceseng tops to get where I want to be with this fitment.
Panman is offline   Reply With Quote
Old 01-23-2015, 02:47 PM   #199
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
So, I got a set of RPF1's in this size with some 245/40 17R tires. Had them mounted last weekend and thought they were ok at first. However, after a little while, I realized they were rubbing the bottom of the spring perch just a little. Not sure if it was all the time or just occasionally. There's a noticeable rub line on the inside of both tires. The guy at the tire shop swore to me they weren't rubbing when they mounted them. I've already taken them off until I decide what I'm going to do to fix it. Do you guys think a 5mm wheel spaces would do the trick? Here's a couple of pics to show what was going on.
smg1138 is offline   Reply With Quote
Old 01-23-2015, 02:50 PM   #200
vroom4
I got what you neeeeeeed
http://www.maximalperformance.com/5m...ts-Kit-BRZ-FRS
vroom4 is offline   Reply With Quote
Old 01-23-2015, 05:01 PM   #201
smg1138
smg1138's Avatar
Thanks for the link. I think may just end up getting coilovers sooner than I expected. I'll give it some thought over the weekend.
Old 01-23-2015, 05:54 PM   #202
2much
I wanna go fast
Drives: 2013 FR-S 6MT
the +35 offset versions of these should effectively give 10mm more clearance, correct?
2much is offline   Reply With Quote
Old 01-24-2015, 12:19 PM   #203
smg1138
smg1138's Avatar
Yes, but they will poke out more. It would probably be the better option if you're going to stay with stock suspension. I believe you'll need to add some negative camber to the front as well to keep from rubbing the fenders though.
Old 03-29-2015, 10:39 PM   #204
nick_318is
Drives: 2013 Subaru BRZ, 1991 BMW 318is
I just installed a set of these on my DGM BRZ, I'm still on stock suspension. 245/40/17 Dunlop Direzza ZII star specs.
I've added a set of 3mm spacers up front, I thought I might have a little rubbing and wanted a little extra space to be safe. After adding the spacers I'm pretty sure there was no rubbing, the wider ZIIs are just noisy.
nick_318is is offline   Reply With Quote
Old 04-04-2015, 12:04 PM   #205
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
I have 17x9 +45 with BFG Sport Comp2 on eibach pro springs. The fronts will not clear without spacers. I ordered a set of 10mm spacers but the poke is too much, so I ordered 5mm spacers for the front and am using 3mm spacers in the back to even it out. Will repost when I install the 5mm spacers. Until then, I have awful poke up front.
Shoulda went with coilovers, as they do not require any spacers to clear.
bryan767 is offline   Reply With Quote
Old 04-04-2015, 12:44 PM   #206
Takumi788
JHerbert Racing
Takumi788's Avatar
Would just a 3mm spacer allow the fronts to clear?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 04-04-2015, 02:40 PM   #207
bryan767
bryan767's Avatar
Nope, I originally purchased the 3mm for the fronts since I read someone having success, unfortunately I wasn't as lucky so they are on the rear now. 5mm will rub on full lock but won't poke. 10mm+ will poke and not rub, but you'll look like you're some turbo FWD car which looks dumb to me on a RWD car and it's not very great for handling.
Edit: I decided to go the coilover route (smaller diameter spring perch), I like the idea of no spacers or extended studs.
On a side note, just picked up 2" knockout conduct seals from lowes for center caps. you will need to wrap the prongs in some sort of tape - I used electrical - and you will have to pull the tabs outward to create a better/secure fit (if your paranoid you can also put a bit of superglue on the underside). However they are the perfect DIY center cap and only cost me 5$
Will be plasti dipping them black before I install. Pics to follow.
Old 04-13-2015, 04:21 PM   #208
DJCarbine
Thupercharged
DJCarbine's Avatar
3mm spacers on stock springs will clear some tires, the only tire I have experience with is the 245 wide Continental DWS which clears with spacers (5-6 mm clearance) but it is close.
Is anyone running a BBK with their 17x9 +45 rpf1 wheels?
I've done a lot of searching, lots of posts saying no but I am planning on running a 10mm spacer.... guess I will throw the caliper fitment template on with spacer to see how much clearance there is with different kits.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 04-14-2015, 11:54 PM   #209
DJCarbine
Thupercharged
DJCarbine's Avatar
Looks like so far only the essex endurance kit will work on the front with a 10mm spacer
2013 FRS
Vortech V3 11psi
Old 04-15-2015, 06:37 AM   #210
dp1
driving smoother faster
Drives: Sold
17x9 +45 RPF1 with 12mm spacer, leaves about 3mm gap at the closest point to the Essex AP Racing Sprint BBK. Bought the spacers off Amazon last year - not sure if that size is still available but it's perfect for this application. Also consider that you might need camber (I run -3f/-2.5r) to avoid rubbing the fender at full load (at the +33 offset) on track/ax, depending on tire size - mine are 235/40-17 Nitto NT01.
dp1 is offline   Reply With Quote
The Following 2 Users Say Thank You to dp1 For This Useful Post:
BRZ86_ (04-17-2015), DJCarbine (04-15-2015)
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 05:18 PM
