Old 04-03-2015, 11:26 PM   #127
Amir Ghadiri
Amir Ghadiri's Avatar
Yup, definitely a spun rod bearing. I don't feel like doing another rebuild, maybe I'll just v8 swap. We'll see
Size:  268.0 KBName:  ImageUploadedByTapatalk1428117948.299249.jpg
On a side note, it took me about 90 minutes to pull the motor. I suppose I've done it enough times now lol
Amir Ghadiri is offline   Reply With Quote
Old 04-04-2015, 01:51 AM   #128
BirgeyT1
too soon jr
BirgeyT1's Avatar
Drives: 2014 Sterling Silver BRZ Limited
you didnt waste any time pulling the motor! lol. I don't blame you though on wanting to do a swap now. It's just not worth the moeny to build the FA20.
T1 Race Development
ID Injector Dynamics
BirgeyT1 is offline   Reply With Quote
The Following 3 Users Say Thank You to BirgeyT1 For This Useful Post:
2013GTRNate (02-13-2016), Amir Ghadiri (04-04-2015), hmong337 (04-04-2015)
Old 04-04-2015, 02:22 AM   #129
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Damn bro. I've been following this thread closely. Sorry about your luck. You could've already had a v8 swap of some kind with what you've done with your FA20. I can't imaging your pain right now. This must be frustrating. This also tells me all the more reason to dump the overly complex Subaru junk for something else.
hmong337 is offline   Reply With Quote
The Following 2 Users Say Thank You to hmong337 For This Useful Post:
Amir Ghadiri (04-04-2015), cf6mech (07-20-2015)
Old 04-04-2015, 01:48 PM   #130
Amir Ghadiri
I was going to do a v8 swap before too, I just didn't want to deal with the hassles of getting it all to function like a factory car. But now those hassles are beginning to seem worthwhile! I already have the swap kit, already have an LS, just need to decide if I'm going to swap to a t56 trans or make the OEM trans work (which may be what I do, replacements are cheap!).
The Following User Says Thank You to Amir Ghadiri For This Useful Post:
Old 04-04-2015, 01:53 PM   #131
Amir Ghadiri
It's all good man, it is what it is. The FA is a great motor and 100% worth building for someone who knows that they're dealing with. I would much rather have a 500HP FA than my 500HP LS in there, but at the end of the day it comes down to one thing: replacements. I can get a junkyard LS replacement for $500 and it will already make the power. That will just never happen with an FA.
On a side note, the failure was probably my own fault. No pride here, just a kid that tried building his own motor and wasn't able to finish successfully. I said I would build the motor, never said it would run!
The Following 7 Users Say Thank You to Amir Ghadiri For This Useful Post:
hmong337 (04-04-2015), jcw99 (03-18-2016), Lonewolf (04-04-2015), lupindub (09-29-2015), mit_peid (04-05-2015), pward08 (03-25-2018), Ultramaroon (04-05-2015)
Old 04-05-2015, 07:01 PM   #132
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
^ now thats some gd honesty. Cheers to you mate.
about this LS Swap kit, is it mounts or full shebang with wiring harness and such?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
The Following 3 Users Say Thank You to itsjustdavep For This Useful Post:
2013GTRNate (02-13-2016), Amir Ghadiri (04-05-2015), raven1231 (04-05-2015)
Old 04-05-2015, 09:41 PM   #133
Amir Ghadiri
The swap I have is everything except wiring for integration of factory electronics. I have motor mounts, transmission mounts, driveshaft, radiator, accessories, standalone EMS, fuel injection, etc. I've decided to do the T-56 transmission so all I will need to do is: 1) source a transmission 2) integrate factory electronics
Once I have this figured out, the swap shouldn't be too difficult
SLOWrz (04-16-2015)
Old 04-05-2015, 09:49 PM   #134
itsjustdavep
i will def follow this to see how the journey to get teh factory electronics goes. thats literally the only thing stopping me as well. Although i wont go LS, im aiming for the the 4.8 Block. I want revs lol
The Following User Says Thank You to itsjustdavep For This Useful Post:
Amir Ghadiri (04-07-2015)
Old 04-07-2015, 01:58 AM   #135
Amir Ghadiri
4.8 would be a good option! Although with decent heads and cams a 5.3 could rev just as high and make 30-40 more hp than a similarly built 4.8. I may actually be installing a 5.3 myself, my friend may want my 6.0 for another project. The 5.3 iron block would be good for boost anyways, and this build will likely be FI very soon after its completion.
It's going to be a few weeks or so until the car is running. It's getting picked up by the company designing the swap kit this Thursday, and it should be back late April. At that point I will just need to do the wiring (which really won't be too bad) and decide which heads/intake I will use as I have a few laying around.
Old 04-07-2015, 03:37 AM   #136
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
Awesome car, sad about the motor but looking forward to seeing the engine swap. I would love to do an LS swap myself but I'm probably several years away from making that happen.
Amaya is offline   Reply With Quote
The Following User Says Thank You to Amaya For This Useful Post:
Amir Ghadiri (04-10-2015)
Old 04-10-2015, 03:55 AM   #137
Amir Ghadiri
Swap time f**k you Boxer Name:  ImageUploadedByTapatalk1428652509.954452.jpg
Size:  128.3 KBName:  ImageUploadedByTapatalk1428652524.120631.jpg
raven1231 (04-15-2015)
Old 04-10-2015, 01:25 PM   #138
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Just stumbled on this build thread today, and can't wait to see how this turns out! I was already jealous of your car so I wonder how I'll feel when there's a V8 in it! Hahaha
Kind of scares me that you started to loose compression at 10psi and 300whp. I'm also at 10psi on 91 oct with my Full Blown kit, but I am only making around 280ish whp on a Mustang Dyno (tuned by Evasive Motorsports)... Hope the same thing doesn't happen to me but if it does maybe I'll end up using this swap kit
John Rambo is offline   Reply With Quote
The Following 2 Users Say Thank You to John Rambo For This Useful Post:
Amir Ghadiri (04-11-2015), raven1231 (04-15-2015)
Old 04-10-2015, 01:27 PM   #139
itsjustdavep
Which team is doing the swap by the way
Old 04-11-2015, 10:23 PM   #140
Amaya
Amaya's Avatar
I think he said he lost compression after a boost spike to over 25psi not during normal operation.
How Shiny Are the Work Kiwami GTS Silver bobsacamenoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-01-2014 08:34 PM
how to make polyurethane shiny DarkestBuddha Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 05-04-2014 01:26 AM
FR-S? BRZ? Premium? Limited? 10 Series? My brain hurts! oldpueblo Scion FR-S / Toyota 86 GT86 General Forum 36 01-02-2014 10:14 PM
Winter hurts. Superhatch BRZ First-Gen (2012+) — General Topics 33 02-07-2013 08:29 PM
shiny wheels jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 08-21-2012 03:23 PM
