Sam Strano
Old 04-03-2015, 07:02 PM   #2745
Wheeljack
Wheeljack's Avatar
Drives: 2013 WRB BRZ Limited
From the solomaters facebook comments, it seems like the SCCA might look to make these either illegal or Bstreet next year. One person (national course designer) said that it wasn't a classing decision, but a rules clarification. That could mean they would reclass the TRD cars next year....said the hopeful BRZ owner.
Two other things to keep in mind: 1). The rear rate on the TRD springs seems rather high. This could negate any advantage of lower ride height or require a massive front sway bar to make the package work. 2). As many have said before, an ND Miata in CStreet will make this irrelevant
Wheeljack is offline   Reply With Quote
Old 04-03-2015, 07:10 PM   #2746
simpleisbest
Senior Citizen
Drives: Scion FR-S
You know the spring rates???!!!!
simpleisbest is offline   Reply With Quote
Old 04-03-2015, 07:31 PM   #2747
Wheeljack
Wheeljack's Avatar
I found them on the internet
http://www.ft86club.com/forums/showthread.php?t=8739
So it must be true?
Old 04-03-2015, 07:41 PM   #2748
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
So it must be true?
Well, if true then those numbers would seem to indicate that the TRD springs are not re-branded Eibach Pro-Kits as some have been theorizing.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 04-03-2015, 07:57 PM   #2749
simpleisbest
Senior Citizen
Drives: Scion FR-S
So it must be true?
PNs are different. I think JDM TRD Springs not same as USDM TRD Springs...
Old 04-03-2015, 09:29 PM   #2750
klittl06
Drives: FRS?
I'm hoping someone can save me from digging through the rule book (although I probably should).
Is a 3 point harness legal for c street?
klittl06 is offline   Reply With Quote
Old 04-03-2015, 10:09 PM   #2751
coneracer30
Drives: 2013 Fiestorm FR-S
To those with the springs installed.....have any of you measured rear camber? I saw the service manual stated that it could be over 2 degrees. Sounds like a lot.
coneracer30 is offline   Reply With Quote
Old 04-03-2015, 10:32 PM   #2752
SVLTE
Heading in for an alignment next week. I'll be sure to post up what the numbers turn out to be.
SVLTE is offline   Reply With Quote
Old 04-03-2015, 10:49 PM   #2753
coneracer30
That would be great. As with anything else in Street Class, I expect there will be compromises made. For instance, will the springs and bars be stiff enough to keep us off of the bumpstops after being lowered or not having any allowance to fix rear camber.
Right now I am leaning towards stocking up on tires letting this play out. Will definitely be paying attention though. I am not going to Nats this year but will be attending the pro and NT in Packwood.
Old 04-03-2015, 11:08 PM   #2754
renfield90
The Stig's German cousin
No but we gained some. My pyrometer readings on stock springs indicated that I needed more rear camber anyways so I'm ok with this. We did not have time at the pro last weekend to take any tire temps but I will be doing that at next weekend's local (while potentially dialing in new shocks...ehh, maybe I should wait on installing the Konis).
The upgraded bump stops are shorter which helps you stay off of them - at any rate, just think of them as a free bump in spring rate
Old 04-03-2015, 11:17 PM   #2755
coneracer30
You're not helping!
I'd pull the trigger in a heartbeat if I didn't think that I would pretty much have to do Koni's at the same time.....Although, I am just about convinced that I should get the koni's even with the stock springs.
Old 04-03-2015, 11:48 PM   #2756
renfield90
You're not helping!
If you want to be competitive at the national level, you're going to need springs and shocks - simply because that's what the rest of us are doing, and unless you are God's gift to the steering wheel you're not going to beat us on stock shocks. And you're going to want to order them now before Toyota/Koni runs out (tire rack had less than 4 fronts remaining when I pulled the trigger).
So my advice is to decide just how well done you want to boil this egg. If you're not gonna be a nationals type you don't need the konis, but you don't necessarily need the springs either. Do what puts a smile on your face.
Old 04-04-2015, 12:05 AM   #2757
coneracer30
I have always believed that it's the Indian not the bow. I've only made it to nationals once in 2007. I held my own. 🍺
I may just see how many "prepped cars" i can find this year to beat before they get moved to BS next year.
Old 04-04-2015, 12:08 AM   #2758
renfield90
In case you haven't followed all the conversation, a quasi-official post from an SEB member indicates they are reassessing the RS 1.0's placement in BS, and noted they are within the 12-month window where they can unilaterally re-class it.
Likely it's coming to CS, since it's got no better suspension than you can legally install on a base model. We're only moving to BS if we prove an overdog, and I don't think that's going to happen.
The Following User Says Thank You to renfield90 For This Useful Post:
Cueman (04-04-2015)
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
