Old 04-02-2015, 03:06 AM   #1933
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Originally Posted by Alltezza View Post
Wait so you can have a light flywheel and light pulley? I don't know for sure I may have said it wrong as well, just trying to look out for a fellow 86 owner
See below quote from 2012
Originally Posted by KronosPerformance View Post
Both lightweight flywheel and pulley do and affect 2 different things
As long as the diameter is the same on the pullies are the same as factory and not smaller, there are no adverse affects. Its just less rotating mass which helps your pulley system move easier.
Lightweight flywheels can however have adverse affects depending on how low in weight you go. This will affect driveability whether its how much power it takes to get moving, how quick revs drop out of your powerband in between shifting, easier to stall and things of that nature. Its one of those things that the less weight isn't always for the better.
Too light will drastically change your driving style, increased chattering and make it easier to stall.
Cliff Notes: You can run both no problem...lightweight flywheels can have more negative affects if you go too low.
0351USMC is offline   Reply With Quote
The Following User Says Thank You to 0351USMC For This Useful Post:
Alltezza (04-03-2015)
Old 04-02-2015, 05:00 AM   #1934
CSG Mike
CSG Mike's Avatar
I love ultra lightweight clutch setups...
*LongFella (04-02-2015), 0351USMC (04-02-2015)
Old 04-02-2015, 05:32 AM   #1935
0351USMC
0351USMC's Avatar
Quick question for you guys....what the diameter of the tubing where the filter attaches? It looks like 100mm/4in but it like to know for sure.
Getting an HKS SuperMegaFlow filter to put on. Because HKS, and also the purple filter matches the purple HKS oil filter which matches the purple lightweight pulleys which matches the purple radiator hoses......you get the point.
And before its said, no its not going to look like Barney shit all over the engine bay. Its going to be the air filter, oil filter, pulleys, radiator hoses, engine cover (with the shiny metal still shiny) and MAYBE the fuse box.
Old 04-02-2015, 06:28 AM   #1936
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Only because you brought it up...
It definitely sounds Barney looking to me.
Old 04-02-2015, 09:03 AM   #1937
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Jackson Racing Supercharger Owners Thread
You're not going to turn my FRS into Barney, are you?!?!
Maybe I should just keep my FRS... jkjk
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 04-02-2015, 09:08 AM   #1938
*LongFella
*LongFella's Avatar
Purple?!?!?! Come on!!!!!!
Just don't plasti-dip wrap Jenny purple.... 😔
Old 04-02-2015, 11:56 AM   #1939
CSG Mike
CSG Mike's Avatar
It is 76.2mm.
Did you already purchase your kit?
Old 04-02-2015, 12:59 PM   #1940
0351USMC
0351USMC's Avatar
Just don't plasti-dip wrap Jenny purple.... ��
Oh no, shes staying white. Id never plastidip her completely purple.
It is 76.2mm.
Nope, not yet. It comes in 70mm or 80mm, so im guessing 80, the difference is only 0.14".
Old 04-02-2015, 01:25 PM   #1941
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
So sorry if I overlooked this, but who out there is rocking the JRSC + a flex fuel tune?
What do you think versus just the JRSC?
Sirsimon is offline   Reply With Quote
Old 04-02-2015, 01:28 PM   #1942
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Dai from a couple pages back, and I think TheSlowOne is using flex fuel now
ScionOfHorus is offline   Reply With Quote
The Following User Says Thank You to ScionOfHorus For This Useful Post:
Sirsimon (04-02-2015)
Old 04-02-2015, 01:31 PM   #1943
Xuningshen
Drives: Subaru BRZ
I'd like to hear from some of those guys running a flex fuel kit too! which tuner and flex fuel kit you're using. Contemplating doing it in the next few months.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 04-02-2015, 01:38 PM   #1944
Sirsimon
Sirsimon's Avatar
Me too. Trying to decide between going FF + injectors from Delicious or spending the money on my FZJ80 Land Cruiser instead (needs a lift kit).
Decisions, decisions. ;-)
DJ
Old 04-02-2015, 01:39 PM   #1945
*LongFella
*LongFella's Avatar
@exam2300
He also posted a pretty good write in the software section (having trouble linking it with my phone at the moment)
The Following User Says Thank You to *LongFella For This Useful Post:
Old 04-02-2015, 01:41 PM   #1946
ScionOfHorus
They both use the kit and tunes from moto-East.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
