#183 | |
Did you even read the left column in the PDF you linked to? It shows the rpm/load conditions where things are targetted to happen.
| The Following User Says Thank You to wparsons For This Useful Post: | KoolBRZ (04-08-2015) |
#184 | |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
This is your life and it's ending one minute at a time.
#185 | |
Drives: Asphalt FR-S
Honestly, at the rate he's going, he's gonna go from FR-S performance to Geo Metro performance real quick.
| The Following 4 Users Say Thank You to Mad1723 For This Useful Post: | Dipstik-sportech (04-01-2015), RobertPaulson (04-01-2015), Tcoat (04-01-2015), wparsons (04-01-2015) |
#186 | |
Drives: UK GT86
The exhaust tables do not have negative values, the intake ranges from -10 to 40 or 45 IIRC. Also your maths doesn't add up, the pdf shows intake opening range of 44BTDC to 24ATDC... That's a range of 68 degrees. Now we know that the system definitely doesn't have that range so no one knows for certain what the rest angle is and it could vary between engines. Know what, read this thread that I started a while back: http://www.ft86club.com/forums/showthread.php?t=57662
.: Stealth 86 :.
#187 | |
How do we get a more usable daily driver? By detuning the system to get a shorter wider powerband. How do we get more power out of the system across a broad range of frequencies? Variable valve timing. Oversimplified but basically that's it. Unless you have a dyno or are able to model the whole thing using CFD, you're going to end up with a mess. Just be prepared for disappointment and make sure you can get back to square one before you change anything. BTW, I haven't read the pdf. |
#188 |
Drives: 2014 GT86
Somehow when browsing parts shops stubled upon part of opening/closing direct bypass with electric motor & valve in exhaust by simple press of button from inside car. That made me think, that it should be very easy/simple/cheap for manufacturer to make something partially closing/fully opening inside exhaust to for exhaust to be dynamically optimized for specific rpm-s by ECU. Yet vendors didn't implement it. Even if it's just +5whp/wtq, implementing it by economy of scale shouldn't be too expensive. Often vendors spend even more funds and time on fine-tuning other bits, but none, including for hi-end very expensive cars did it this way. Imho that's another weight on scale of this being more of a placeboo then actually improving performance.
#189 | |
edit for truth: EXUP was at the collector end of the header so it's not the same as Kool's experiment. My bad. Last edited by Ultramaroon; 04-01-2015 at 09:17 PM. |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | wparsons (04-01-2015) |
#190 |
Drives: 2014 GT86
Interesting. But most implementations/vendors listed in article are for motorcycles. But why i don't hear about it being used for cars? Precision controlling engine variable valve timing seems to me by magnitude harder task then simplest valve on exhaust tube. Vendors even play with dynamic aerodynamics like deployable wing at speed. But where are exhaust valves in common cars? I heard about them at car exhausts only in context of changing sound/noise, not optimization for rpms. :/
#191 | |
![]() That's it. No more crazy guessing from me. Anyone more knowledgeable please shoot me down. |
#192 | |
My Tumbler is an FRS
Drives: exclusively in the fast lane
Lord have mercy on the poor soul that buys this car without knowing it has been experimented on more than Frankenstein. I'm all for questioning conventional wisdom and trying different approaches to help pioneer new solutions for common problems, but using a certain tune that was designed specifically for an alternate setup just to see what happens is a whole other brand of stupid. There's a reason it is designed and written the way it is... it serves a very specific purpose. That's like using a hammer to try and torque a bolt. |
| The Following User Says Thank You to ImBatman For This Useful Post: | wparsons (04-02-2015) |
#193 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I have a theory that the valve overlap needs to be adjusted to compensate for the difference in back-pressure when switching to an unrestricted exhaust. in the PDF it states valve overlap is used to reduce pumping losses and increase economy. Well my economy went down when I went to an unrestricted exhaust, so this is what I have done.
First I reduced valve overlap to see if that made any difference. Mileage went down some more. Then today I added more valve overlap and I'm going to see if that change compensates for the unrestricted exhaust. Tell me what you think, don't hold back, I can take it. |
#194 |
#195 | |
This proves that power and economy will suffer when changing to an open exhaust
I immediately noticed better acceleration, and low-end torque, particularly in 5th and 6th gears. Normally my car bogs down as soon as I shift to 5th, but now it accelerates smoothly through all 6 gears. Now bear in mind, my car is an auto, and both 5th and 6th are over-drive. I now have an unrestricted intake and exhaust, so I have some more work to do to adjust the valve overlap to compensate. This does point me in the right direction though. I'll post AVCS tables if anyone's interested, just ask.
#196 |
Post it
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | cdrazic93 (04-08-2015) |
| Tags |
| guy knows nothing, world's last, zero facts |
| Wtb ft86 uel header | 86socal | Want-To-Buy Requests | 1 | 08-23-2014 09:00 PM |
| Anti A-Hole Button | ButtonMasher | Off-Topic Lounge [WARNING: NO POLITICS] | 45 | 07-25-2014 12:55 PM |
| Eibach Anti-Roll Kit | babykwiss | Canada Classifieds | 1 | 07-14-2014 09:29 AM |
| Fastest FT86 in the World 9.10@256km/hr! | Bahraini86 | Forced Induction | 94 | 02-19-2014 12:25 PM |
| is it necessary to change anti-roll bar? | yuli8466 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-25-2012 10:58 AM |
