Old 05-20-2012, 10:23 PM   #85
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Moto-P View Post
And theoretical setup is a useful guideline, but with driver brain, habits, preference, and skills as the largest of variable of them all... It can really only be finalized on the field, with equipment, talents, and resources, and over many trials to get there... So I can't really say yay or nay on your inquiries at this time... It's other half of tuning is on the seat of your pants.
Or the stopwatch.
What got me thinking about this is that the RS-R rates seem more appropriate to balancing the front to rear frequency properly than the HKS street rates, for example. The RS-R will probably be in the suggested .9:1 range (I calculated 1:1 with my preliminary estimates) but the HKS will be in the range of 1.34:1 which can cause some uncomfortable pitch oscillations over bumps. Their numbers actually look like they would be better reversed. A little bit confusing.
Because titanium.
Old 05-20-2012, 11:39 PM   #86
Staticfrost
Drives: Eight Six
CAn I buy RS*R Sports-i Coilover in Australia? The reviews and results sound very goood!!!
Staticfrost is offline   Reply With Quote
Old 05-21-2012, 12:55 AM   #87
Racecomp Engineering
Or the stopwatch.
Lower frequencies in the rear can actually be done for more comfort or other reasons...its not necessarily the end of the world. The springs are not the only things that control the balance if the car. However, spring rates that are much much lower in the rear are not imo a good idea at all on this car. Sometimes companies do things without a good explanation.
The rates you posted might be very aggressive imo and probably a bit of a handful on a track without a big wing.
The RSR rates posted are pretty good, kudos to them. I agree that rates along those lines would be a good starting point for autox depending on other factors. An upgraded rear bar should be matched with a front if you want/need additional roll stiffness or want a quick easy way to adjust balance with those rates imo.
Cool to see what looks like a quality product coming for this car!
- Andrew
Old 05-21-2012, 01:12 AM   #88
Dimman
Kuruma Otaku
Dimman's Avatar
- Andrew
Thanks Andrew.
I was working on the suggested f/r frequency ratio first and next would be sorting out lateral weight transfer with probably extra bar stiffness in the front next. (Are we fortunate enough that they share fronts with the WRX too?)
With the availabilty of rear bars from the WRX and STI would it be easier for HKS to go with the bigger rear development wise and that played a role in their spring rate choice?
Because titanium.
Old 05-21-2012, 04:17 AM   #89
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
- Andrew
Or the stopwatch.
The RS-R does give a very comfortable ride, when damper rates are dropped to low end of the adjustments, even over the stock ones, and still yield a pretty usable stroke range. Oscillation issues seem to have been very well sorted on this one, making use of the ample stroke, and thereby allowing for higher rebound rates to reduce excessive motions. This is sort of how Koni and Bilstein sets behaves in performance applications are loved by autocrossers, giving you enhanced control in stages like slalom excercises and planting the driving wheel down on the ground and keeping it there. This, despite the nature of FT86's short stroke rear end by its inherent dimensions of the dampers. The initial compression is mild and almost gives a more expensive feel to the car, since the battering of unsprung weight is much more supple and compliant, while the pitch is reduced at the same time, very well with increased spring rates. RS-R has always developed i-Shocks with 'street minded" approach, and offers almost an uncanny range of more European thinking of letting the suspension do it's thing, giving a measure of predictable, compliant, and mature driving feel, and less boy-racer than most. But the easier roll and stroke control of RS-R Sports-i here, does contribute to much greater control of low to medium speed, low-inertial loading, making it perhaps ideal for things like autocross on street tires, where massive weight transfer is not always available at low speeds and making quick transitions with faster roll-center motion makes the driver more in control and ease the learning of how to drive at limits. Cusco seems to follow this convention often as well.
As for HKS, traditionally they have been a proponent of strong compression damping, giving somewhat of an opposite feel, very firm, and seems to like a hoppy, responsive ride and dynamic attributes in nature of race cars, but being a bit enthusiastic when used over rough surfaces. This holds true for most sports coil-over systems on the market today, where strong high speed stability and firm jolting ride seems more easily understood by general consumers and is effective at very high speeds, like those on a race car. High compression dampers are also used often to compensate for more inexpensive units with twin tube design which inherently have less stroke range per given length of the cartridge, especially when designed for ultra-low ride height compatibility. Some are excellent for intended use of sports driving, at high speeds and very sticky tires, but not always ideal for street if this is catered too far for extreme theoretical performance, some striking a balance in-between by different models as in HKS, Tanabe, and JIC.
Others, I am not too familiar but generally inexpensive ones almost always suffer from some elements critically lacking due to multiple applications made from simply adapting a wide range damper to be used on many different applications, and being less optimized for any single application.
I can't say though for sure on the many FT86 units though, as I've only used a lot of them in the past for S13, BMW M3, and AE86 applications.
It's all how you think and feel, and prefer... With the FRS, the sky is the limit, as the basic foundation of balance, rigidity, and driver controls are top notch, and like the old AE86, any and all modifications are easily felt and understood because of this. This is why we loved the AE86 and this is how the NEW 86 will be sure to have lots of fans among the new core driving enthusiasts.
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
Old 05-21-2012, 04:29 AM   #90
Moto-P
Moto-P's Avatar
Yes, there isn't a distributor in Australia at this time, but since all i-Shocks by RS*R is built to order at this time in Japan, the USA office can take your order at competitive prices with favorable USD exchange over JPY, and have the i-Shocks drop-shipped directly from Japan to your location in Australia so it doesn't cost any more than it would to buy them in the USA, including shipment.
They have delivered a few to Europe as well this way.
RS-R USA
1802 Carnegie Avenue
Santa Ana, CA 92705
T: 949-833-7718
E: info@rs-r.com
Facebook: rsrusa
Twitter: @RSRusa
You can ask for Ben when asking and tell them it's Moto that sent you :P So they know how serious you are
Moto Miwa
Old 05-21-2012, 07:05 AM   #91
Staticfrost
Drives: Eight Six
RS-R USA
Santa Ana, CA 92705
T: 949-833-7718
E: info@rs-r.com
Facebook: rsrusa
Twitter: @RSRusa
Thanks Moto, what option should i be specifying when I am ready to place the order?
Old 05-21-2012, 07:18 PM   #92
sirus
86 Owner
sirus's Avatar
Drives: White GTS 86
RS-R USA
Santa Ana, CA 92705
T: 949-833-7718
E: info@rs-r.com
Facebook: rsrusa
Twitter: @RSRusa
Hi Moto-san,
Do you mind if I use your name as well?
On the road. Check your mirrors!
sirus is offline   Reply With Quote
Old 05-21-2012, 10:19 PM   #93
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
dang moto-san you sold me on the rs*r i-sports, i just gotta save up or get a raise so i can buy the car first...
cyde01 is offline   Reply With Quote
Old 05-21-2012, 11:03 PM   #94
Staticfrost
Drives: Eight Six
I found these - http://page12.auctions.yahoo.co.jp/j...ion/p286747814 how can I confirm that this has the same settings?
Old 05-21-2012, 11:43 PM   #95
Nardi330
Nardi330's Avatar
Drives: 86
It looks like u can choose spring rates.
soft F5k/R7k or hard F7k/R8k
Nardi330 is offline   Reply With Quote
Old 05-22-2012, 09:03 PM   #96
Rawdog
Drives: 4.5in jeep
Any reviews on that air filter you dropped in?
Rawdog is offline   Reply With Quote
Old 05-22-2012, 09:07 PM   #97
zoomzoomers
zoomzoomers's Avatar
Wow awesome! Congrats on the new setup.
Old 06-05-2012, 05:25 AM   #98
Moto-P
Moto-P's Avatar
yes, but if you buy those, that is about $1860 in today's dollar without shipping!!!! So you might as well buy it direct from RS*R USA so you can get this for about $1950 (INCLUDING Shipping to your door in the USA from JAPAN!!)
Moto Miwa
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
US Subaru BRZ Port Installed Accessories and Packages List and Prices eikond BRZ First-Gen (2012+) — General Topics 42 04-28-2015 07:45 PM
Live Pics of Subaru Boxer Sports Car Architecture (BRZ) from Geneva! + Press Release Hachiroku BRZ First-Gen (2012+) — General Topics 103 09-14-2011 04:05 PM
Dealer Installed Badges ToyotaObsession Scion FR-S / Toyota 86 GT86 General Forum 55 05-14-2011 12:16 AM
Turbo FT-86 G-Sports pics from 2010 Australian International Motor Show Calais FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 49 11-04-2010 05:40 PM
