Old 03-30-2015, 11:09 PM   #24907
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Sometimes I think things that materialistically being beings or objects cannot exist.
That made my head hurt.
Yesterday, while driving I got lost fort 20min and refused to turn around. It was interesting just seeing things in my head.
I was thinking of water and sand. Then particles smaller than those. Then, realized that matter cannot be made or destroyed. I mean, when you sneeze, lets pretend, and boogers/spit/food or whatever you had in your mouth then, spills onto a table per say, so if you quickly rub your sweater or a napkin to 'soak' or 'clean' the mess, it doesn't just disappear... it moves (well the molecules) onto other objects... But! it doesn't just destroy them!
So, I pulled over, realized my buddy is ko'd in the back seat, got out of car and noticed how sunny it is and every time I attempted to put both my index fingers together (not touching though), the shadows produced by my fingers seemed to pull at each other!
THEN BAM!!! I started thinking how Einstein hypothesized that gravity can bend light!
Well... just my random thought. I think too much?
Packofcrows is offline
The Following 2 Users Say Thank You to Packofcrows For This Useful Post:
Hot Lava (03-31-2015), Tcoat (03-31-2015)
Old 03-31-2015, 01:48 AM   #24908
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
I really need to start working on my research paper due in two weeks, yet here I am..
GhostRai is offline
The Following 2 Users Say Thank You to GhostRai For This Useful Post:
Choco (03-31-2015), Tcoat (03-31-2015)
Old 03-31-2015, 06:55 AM   #24909
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
inb4Packofcrowsholdstheworldhostagewithanuclearbom b
echo419 is offline
The Following User Says Thank You to echo419 For This Useful Post:
Tcoat (03-31-2015)
Old 03-31-2015, 09:32 AM   #24910
frickin' "lasers"
Tcoat is offline
Choco (03-31-2015), Ultramaroon (03-31-2015)
Old 03-31-2015, 09:58 AM   #24911
Dimman
Kuruma Otaku
Dimman's Avatar
^ Also applies to all your science "jokes"...
Because titanium.
Dimman is offline
The Following User Says Thank You to Dimman For This Useful Post:
Tcoat (03-31-2015)
Old 03-31-2015, 11:07 AM   #24912
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
https://www.facebook.com/video.php?v...005&permPage=1
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
AznKirby is offline
The Following User Says Thank You to AznKirby For This Useful Post:
Choco (03-31-2015)
Old 03-31-2015, 11:25 AM   #24913
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
Whatever substances brought you these random epiphanies... Please share with the rest of the class.
Special_K is offline
The Following 2 Users Say Thank You to Special_K For This Useful Post:
Packofcrows (03-31-2015), Tcoat (03-31-2015)
Old 03-31-2015, 07:10 PM   #24914
Special_K
Bannéd
Special_K's Avatar
Sooo... I'm putting my car on pause in order to build a new PC. After a long run and constantly Frankensteining it back from the grave, it's finally reached the end of it's journey. My next PC will be built to last at LEAST 2 life cycles hopefully more. And I'm finally going to attempt something I've always wanted to do, and build a fully custom water-cooled/wall-mounted system. Something like this, although probably a bit less extravagant.
Thoughts?
Old 03-31-2015, 07:16 PM   #24915
Thoughts?
Oh if you are doing a wall mount at least do it up right!
Tcoat is offline
Special_K (03-31-2015)
Old 03-31-2015, 07:16 PM   #24916
serialk11r
Drives: '06 AM V8V Coupe
Thoughts?
Dat super long ribbon cable = too much latency lol.
I dislike that wall mounted setup, if I were to do a blinged out desktop rig I would try to put it inside the desk with a glass window to the surface of the desk.
serialk11r is offline
The Following User Says Thank You to serialk11r For This Useful Post:
Old 03-31-2015, 07:24 PM   #24917
Special_K
Bannéd
Special_K's Avatar
I've used shielded cabling before to get rid of EFI in the past, a bit spendy but well worth it.
I'm for sure not going to rip of that guys setup, I have my own plans, and it should be much more compact.
As far as a desk mount goes, I'd love that. Only problem is, I don't have a desk so much as a welded framework/cockpit with a racing seat for my workstation, so nowhere to hide any components haha.
Old 03-31-2015, 07:25 PM   #24918
Thoughts?
It's silly to water cool something that's already "out there." If you're really planning to go external you'll have tons of room for surface area. Just strap a big fat heat sink over the hot parts and be done with it. No noise and more importantly, no leaks.
Ultramaroon is offline
Tcoat (03-31-2015)
Old 03-31-2015, 07:49 PM   #24919
AznKirby
Are you 20/20?
AznKirby's Avatar
I've always wanted a crazy computer like that. My laptop is having trouble with my big file size image processing.
How much does a setup like that cost? Probably easier than modding a car, right?
2014 FR-S Monogram
IG: @MonKehC
AznKirby is offline
The Following 2 Users Say Thank You to AznKirby For This Useful Post:
Special_K (04-01-2015), Tcoat (03-31-2015)
Old 03-31-2015, 08:46 PM   #24920
Just get a bigger monitor so the image fits.
