Old 03-31-2015, 02:45 PM   #365
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'll leave this here.... Could be the deal breaker for some
I am booked in with Fensport to have mine install in June because I want to keep my exhaust 2.5 " and intake, yesterday cosworth give the go ahead to change the maps provide by them can't wait
Not me BTW
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-31-2015, 03:14 PM   #366
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Not me BTW
Why would this be a deal breaker?
Old 03-31-2015, 03:20 PM   #367
Kodename47
Kodename47's Avatar
Drives: UK GT86
Surely engine dyno & simulation time by Cosworth and then custom tweaked to your own mods is appealing? People had stated that they would rather the "tuner" package option rather than the 3 "OTS" map.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-31-2015, 03:32 PM   #368
weederr33
weederr33's Avatar
Ah, ok I gotcha.
Old 03-31-2015, 03:43 PM   #369
350matt
Drives: toyota mr2/ Toyota GT86
what would they tweak? slight fiddles to the MAF scaling and pulling out any spark where required?
350matt is offline   Reply With Quote
The Following User Says Thank You to 350matt For This Useful Post:
ajc209 (04-02-2015)
Old 03-31-2015, 04:00 PM   #370
sw20kosh
Drives: 2013 Black FR-S
intake cam profiles
exhaust cam profiles
ignition timing
AFR
direct injection timing
direct injection / port injection balance
driveability tweaks
etc
The Following User Says Thank You to sw20kosh For This Useful Post:
CSG Mike (03-31-2015)
Old 03-31-2015, 05:53 PM   #371
350matt
Really ? all that? based on what data? it not like they'll be putting every car on the rollers
I'd expect it all to be based on their existing tune - which probably has got all the changes you mentioned and more besides over the stock tune - or is that what you meant?
ajc209 (04-02-2015)
Old 03-31-2015, 06:20 PM   #372
sw20kosh
You misunderstood his post. He is talking about the cosworth tune being "open". Meaning that when you get your kit and tune the tune can be tweaked by you or your tuner of choice. You tweak cosworths tune.
Alternatively, a "tuner kit" doesn't come with a tune and it is up to your tuner of choice to tune the kit.
Old 04-01-2015, 01:50 AM   #373
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
Originally Posted by cdrazic93 View Post
Yes, the as vehicle speed and engine load increases so does torque and therefor friction. The more friction you have the more heat you have, thus higher drivetrain loss the higher in the RPM band you go. Another reason why it's good to have torque down low so its more useful than torque in the higher rpms.
F1 engines only put out close to 250 Ft.lbs. Horse power can always be geared down to provide the required torque. Having power band over more rpms = desirable. Nitride coatings in modern engines, by reducing friction, allow for higher rpm cylinders by allowing lower tolerance piston to wall clearances. Inertia from big displacement/torque engine is a greater loss here. All you need is this fancy thing called a heat exchanger.
I will give you that Straight cut gears are ideal for high torque. They have lower contact area = less friction when compared to high rpm helical cut gears.
Now go race a farm tractor with a Superbike.
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline   Reply With Quote
Old 04-01-2015, 02:35 AM   #374
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why would you buy a tuner kit to tune from scratch when you can get them to tune from a well sorted base file? I don't think the unlocked tunes are for customers, just for the tuners selling the kit.
Realistically, from the provided tune, you would only need minor tweaks to AVCS, AFR, and ignition timing.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-01-2015, 03:17 AM   #375
sw20kosh
Every other FI offering on the market offers an option for a tuner kit where you tune the kit yourself (or your tuner does it). It usually doesn't come with any tuning hardware or software so it is cheaper. This shouldn't be a surprise for you.
Some people want to use their tuner to start from scratch. I know of two tuners whom I have used that wont touch another tuners open tune. They would much rather start from scratch with their own FI starting tune. Most companies don't send out open tunes anyways so tuners need to start from scratch most of the time.
I don't think Cosworth will offer an option for Cosworth to "tweak" the tune for your mods. I have not heard they will offer this type of E-tune service.
Old 04-01-2015, 04:14 AM   #376
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, they are apparently letting their retailers do it for them which is what I posted originally. I know what your saying about the tuner packages, but the reason why people go that way is so that the tune is for their car. I know that if I were a potential customer, if I could get a Cosworth stage 2/2.2/2.3 tune edited specific to my mods then that would be better than any from scratch tune from elsewhere in my eyes. The basis of the tune is going to be solid from the testing that they do and to customize it to a certain car isn't going to involve that much or that many big changes that you stray far from their original calibration.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-01-2015, 07:13 AM   #377
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
this is from the installation instructions..it appears there are two stage 4 tunes for the US market..with or with out the full exhaust ,with or with out manual /auto transmission
♠♠♠88
Ernie L is offline   Reply With Quote
Old 04-01-2015, 07:29 AM   #378
350matt
Hi Ernie
my copy of the instructions shows 1 more variant
Ernie L (04-01-2015)
Cosworth FA20 Stage 1 Power Package DaDr00 Engine, Exhaust, Transmission 84 06-10-2016 03:02 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
