Old 03-31-2015, 04:54 PM   #435
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by serialk11r View Post
That FA20 pump gear looks super weird! The little "holes" would seem to allow a little leakage of oil back and effectively lower the displacement by a tiny bit. It might be that the discharge port is shaped kind of weird and at high rpm it would generate more pressure, but that makes no sense, if anything you want higher pump displacement per revolution at lower rpm to generate the necessary pressure quickly and not the other way around. That's how all the variable displacement pumps work these days, they open an internal valve to reduce the flow at high rpm without incurring the losses of the traditional relief valve so that you can keep the pressure at say 60psi as if the pump were spinning slower.
Maybe it's just a way for Subaru to make a lower flow oil pump from an existing design. The turbo FA20 probably needs more than just 14mm/12mm =1.166 times more flow than the NA engine.
It's for low RPM efficiency and high rpm flow. So the focus isn't to have high pressure at low RPM.
Element Tuning is offline   Reply With Quote
Old 03-31-2015, 05:00 PM   #436
serialk11r
Drives: '06 AM V8V Coupe
I'm not well versed on oil pressure and flow needs of an engine from a bearing protection standpoint but on modern engines I thought you want significant oil pressure at low speed to power your chain tensioners, cam phasers, and hydraulic lifters if applicable. The gas cycle efficiency benefits of VVT are partially offset by the need for a bigger oil pump. It seems extremely weird to decrease oil pressure at low rpm when it's critical for making the VVT work quickly, which does a lot more for fuel economy than lowering oil pressure.
That's why I'm thinking the design might just be a significantly reduced displacement pump without any atypical rpm dependent behavior. A thicker, bigger pump gear pumping the same amount of oil would have less load and probably be more reliable. My guess is that the inner teeth start to seal against the outer teeth at the bottom of the indent instead of near the top of the indent like usual thus cutting the displacement by a significant amount. Does 1/2 the oil flow of the WRX pump sound plausible, empirically?
Old 03-31-2015, 05:03 PM   #437
Element Tuning
Originally Posted by P86RAVES View Post
Could you expound on that a little? This perspective is interesting.
I've resolved myself to never modify this car so long as I own it. Until I owned it I was in love with the car, but after driving it about and window planning a modification route.... I kinda despise it because it's not at all what I was hoping it would be.
Do you think within the next 5 years the money:performance will improve, or do you think shops will start treating it like an RX-8?
It's about the cost for performance for a given platform. If this was a factory $75k car then the costs wouldn't be out of line but for a $25k car the cost for performance is high. This shrinks the market down is all.
It's a good performer at 300 whp but as you push past that it gets exponentially more expensive. I think in time more will actually spend big bucks than they are now since the new car, warranty.....etc is still in the mindset of the average owner.
It's hard for me to be happy at this power level as I'm used to racing 500-700 whp cars. This chassis is capable and that's what's frustrating. It's getting to the point where I don't want to be the one to figure it all out. I've done a full plug and play stand-alone, the engine (still moving forward), the braking system, and now I don't want to be involved with the transmission. I just want to write a reasonable check to someone else. LOL!
The Following 5 Users Say Thank You to Element Tuning For This Useful Post:
ATL BRZ (04-01-2015), Calum (04-01-2015), MINOCIN (04-02-2015), P86RAVES (04-01-2015)
Old 03-31-2015, 05:57 PM   #438
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
In that vain, is it worth doing the full blown V160 supra swap?
Luckrider is offline   Reply With Quote
Old 04-01-2015, 10:05 AM   #439
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
I get where you're coming from and thank you for taking the time to reply.
It's based on a RWD Corolla, what do you expect?
P86RAVES is offline   Reply With Quote
Old 04-05-2015, 01:29 PM   #440
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Found some info on the reimax pump gears on a uk forum.
Theoretically they should flow more oil based on the measurements he has done.
http://www.gt86.org.uk/forums/topic/...details/page-2
I have a set on order.
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
BatStig (05-30-2015)
Old 04-05-2015, 02:19 PM   #441
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
No it's not that simple as the front and rear rotor diameters along with piston surface areas had to be reconfigured to give us the balance we needed and that the OEM system could deal with. OEM bias is off the chart wrong for racing.
Is it something you guys will be offering to the public?
The Racers Line is offline   Reply With Quote
Old 04-05-2015, 04:44 PM   #442
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
How are you guys not dry sump?
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline   Reply With Quote
Old 04-05-2015, 05:03 PM   #443
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
They will eventually, theyre just prototyping springboard ideas for those who want a oily track car without the price of a dry sump.
Old 04-05-2015, 09:40 PM   #444
Element Tuning
Don't forget I tested a 14mm pump with the traditional tooth profile and it didn't help enough (this was with the factory oiling setup and not our engine mods). I suspect that gear will just ramp pressure faster is all.
Old 04-05-2015, 09:43 PM   #445
Element Tuning
Yes, this is a product the community will be able to purchase and the manufacturer is building stock after I gave it the
The Following 4 Users Say Thank You to Element Tuning For This Useful Post:
Darryljr11 (04-06-2015), GhostOp86 (04-13-2015), The Racers Line (04-05-2015), Valentino (04-14-2015)
Old 04-05-2015, 09:45 PM   #446
Element Tuning
We will it's just the first attempt didn't go as planned so back to the drawing board. I have new parts on the way to me to test but I'll need to fabricate so new items. Fingers crossed we get the pressure we all need for high power!
The Following User Says Thank You to Element Tuning For This Useful Post:
blackfireball5 (04-06-2015)
Old 04-10-2015, 06:55 PM   #447
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Someone should make a gearset like this lol
http://www.vividracing.com/catalog/-...37832010-RRS50
http://www.vividracing.com/catalog/-...45232270-RRS50
Darryljr11 is offline   Reply With Quote
Old 04-13-2015, 01:03 PM   #448
D K
Stig's dark passenger
A stronger gearset isnt going to help a lot.
There is an inherent design limitation with our stock gearbox.
Straight cut gears might help more since they are less susseptible to shaft flex.
D K is offline   Reply With Quote
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
