| Member's Car Journals Car journals by our members. |
Drives: '13 Argento MT FR-S
Kwaziekeller's "Argo" Build log...
I bought Argo 6/18/2012, and traded in a Procharged '07 Charger SRT8 (527rwhp/454tq). I followed the 86 through its concept days and the allure of potential power to weight ratio, having a manual again, and RWD sold me on the platform. I've modded here and there along the way, but I finally got around to making a build log. I plan to turbo the car, and if I didn't purchase a house in June of '14, I would have ordered a turbo kit, clutch and axles. Essentially, all I have left are those 3 things, possibly a built engine, and a Flex fuel kit. My goals were to make the car fun to drive (well more fun), and eventually 300ish whp on 93 and ~500 on e85 (330whp should equal my Charger in power to weight ratio). I'll probably go with a EFR7163 or GTX3076R turbo, but may go slightly smaller for better response.
Mod list: Exterior/Aesthetics: Window tint (15% sides, 5% F/R) Rear Fog light wired as tail-light 6K HID kit FT86SpeedFactory/Velox Motorsports "race" upgraded front splitter FT86SpeedFactory/Velox Motorsports splitter endplates FT86SpeedFactory/Velox Motorsports front wheel air deflectors Driveway Labs Type 1 rear diffuser Interior: TRD QuickShift kit Spare tire and toolkit removed Engine: Sound Generator Tube Delete Oil Catch Can PLM long tube Header Motiv Concepts Ceramic Coated Overpipe Invidia catless, resonated front pipe Invidia N1 catback with Ti tips Perrin Lightweight Crank Pulley aFe Pro Dry-S Drop in panel filter SuperTEK intake pipe/tube ECUtek with FT86SF Stg2 93oct tune Suspension: Hotchkis Lowering Springs (25mm, 1") SPC Rear Control arms SPC Offset Toe Bushings SPC Front Camber Kit Megan Racing diff brace Megan Racing rear trailing arms Whiteline Rear Subframe Bushings Perrin Rear Shifter Bushing Perrin Transmission Support Mount Stock Wheels with 225/45R17 Continental DWS (Winter) 17x9 +35mm Enkei RPF1's with 245/40R17 Dunlop Direzza ZII (summer) A few pics... I need to take some better ones once the weather improves a little more. ![]() ![]() ![]() ![]() ![]() ![]() Snow + Splitter =
#2 |
Drives: 2013 SSM BRZ
I like your splitter and diffuser. I wasn't a fan of those rims before I got my car, just from seeing pics, but for some reason they look pretty good on silver.
Do you track the car, or just dd? |
#3 |
I feel the RPF1's are kind of overplayed on 86's but went with them because they are so hard to beat weight wise for the price. I went with the gunmetal finish from Oakos.com because I didn't like the other finishes available, so far so good.
It's my DD and I enjoy winding roads occasionally. Considered getting into auto-x, but I have a crazy work schedule (only one weekend off a month). If there were some road courses closer I'd consider prepping for a track day sometime. The splitter and diffuser were to address aero concerns (stock kinda floats at high speeds) and increase mpg. Down the road once I'm FI, I'll do a lot of roll racing and need the stability.
#4 |
JHerbert Racing
Drives: 2013 Scion FRS
Sub'd
Idk what type of FI you are looking to get into but check out the development of the FT86 Speedfactory turbo kit. It seems like it is going to be the perfect balance of power and handling.
#5 |
Makes me feel privileged to live in southern California with access to two tracks within an hour so. Although the lack of any roads with a turn within a 25 mile radius is depressing.
I prefer the functional aero to the aesthetic ones, and those look serious. I'm definitely going to keep an eye on your thread as your ride develops. |
#6 |
Yea, I'm keeping my eyes on the FT86SF turbo kit as well. Leaning towards a GTX3076R or EFR7163 based kit to reach the 500whp goals I'm after, but recently some one cracked 600whp on a 3076R so that may be a bit of overkill. By time I'm able to do it, I should be able to get all of the supporting mods I want, including internals... so we will see. Going to be a while, like 4 years tho lol.
I just found out the other day that Memphis International Raceway is open and hosting HPDE events again. They had changed ownership a few years ago and I wasn't sure if the road course was open yet. That track is about 2-2.5 hours away, and after membership dues etc, I could get to a NASA HPDE 2-day driving event for around $400, and get into the SPEC86 class if they get that going (although I'm sure some of my mods are not approved). It's not a great track, or world renown persay, but it's definitely a safer environment than public roads! Yea, I went after functional aero instead of cosmetics. Both products have had CFD analysis done on them, and the information is on the forums. I'm more than happy with them. I'd say they make a minor difference on dry roads (you can tell they're there but it's not like an F1 car all of a sudden), are extremely noticeable on wet roads, and they help mpg a little too. They reduce tramlining and hydroplaning, give more steering feel, and really inspire confidence in turns (makes the car virtually 0 lift but I'd need combined CFD data to know for sure). If you followed the product thread about the splitter you'll notice I'm the guy who had the street version "fail" (exceeded it's recommended speed (under 100mph) by a bit (125-ish when it failed) and had it pull the rivet nuts through the bumper, not a "failure" but exposed a "known weakness"), and ushered in a hardware revision for the street kit (washers between rivet nut and bumper to reinforce the rivet nut). The race kit is rock solid... the suspension will compress before the splitter deflects
#7 |
JHerbert Racing
I am looking to buy rpf1s this week but before I do, did u have any rubbing issues with the +35 offset and 245/40 tires?
#8 |
Drives: White brz
How are the Megan trail arms holding up? I have some installed on my car, but curious how they will hold up long run vs the short amount of time I have had them.
#9 | |
So far so good, I got the non-adjustable ones. I may eventually swap to the adjustable ones, and go to "better" LCA's. I haven't been under the car in months because of the weather, but next time I get a chance to I'll check the rear components, since I need to check the diffuser for damage as well (mainly getting slightly bent by snow).
#10 |
Are you planning on anything for the sides like skirts? You got the front and back taken care of, now just need something on the sides to balance it out.
I have the Driveway Labs V2 on mine and love it. The V1 was a bit too much for my tastes but it actually works great on your car because of the front splitter. Just keep the look goin on the sides I think. -RyanG |
#11 |
I've considered Driveway Labs side splitters, or the HT Auto side skirts, but I'm worried about speed bump clearance lol. Not that my car is excessively low, but it's a DD and function is still important. Plus both are matte black to match the front splitter and diffuser. Someday I'll get around to it, hopefully by the end of the summer.
As far as other planned mods. Power wise, just a turbo kit, flex fuel kit, clutch and axles left. I may get a spoiler (I like the Modbargains one, which is based on the ABFlug iirc), and some side skirts (it does look kind of off with out any). That's really about all I have left lol. I may replace the Megan Trailing arms with the adjustable ones, and go to better LCA's (interested in Velox Motorsports' that are under development). Other than that... just maintenance and smiles per gallon.
#12 |
Added the FT86SF/Velox splitter endplates and front wheel deflectors. I've since moved the plastic from the wheel-liner to inbetween the CF and the fender due to concerns it would possibly pull over the hex head cap screws/washers. Pretty happy with them so far. Can notice that the aero balance is shifted forward, as well as in increase in front end grip. I haven't noticed much of a gas mileage penalty due to the drag from the endplates, but haven't had her on long trips yet. Looks pretty intimidating from the front...
PS... I'm ready for warmer overnight lows so I can put my RPF1's and Direzza ZII's back on! ![]() ![]() ![]() ![]() ![]()
#13 |
JHerbert Racing
Nice! This is the first FRS I have seen with the deflectors. I am considering them myself. The only thing holding me back is my canards. I am not too sure how great those would look with these.
#14 | |
I'm not sure. I definitely haven't seen anyone running canards and these endplates. The endplates are pretty new, so I imagine they'll start popping up more and more. I didn't want to clog up your build thread with talk of the deflectors etc. They're a little longer than stock, but still have a good bit of ground clearance. I haven't had them scrape anything yet and I've been over some speed bumps, buckling cracks in the roads, potholes, and my muddy driveway lol.
| Tags |
| argento, driveway labs, frs, sterling silver, velox motorsports |
| TWINCHARGED (Supercharged & Turbocharged) Widebody "WTF-86" 86/FRS *MASSIVE* build :D | WTF | Member's Car Journals | 224 | 08-18-2016 09:39 PM |
| Meet "Cloud" Errol's FR-S Build Thread | RainEG | Member's Car Journals | 12 | 08-01-2014 05:18 PM |
| Vicious LED "BABYLFA" Asphalt FR-S Build Thread! | Vicious LED | Member's Car Journals | 111 | 01-24-2014 02:20 AM |
| Whiteout "8ROKU" build from Dallas (Frisco) | jacobzking | Member's Car Journals | 23 | 06-27-2013 01:56 AM |
