Old 03-31-2015, 01:14 AM   #1877
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by JB86'd View Post
Would you run a hooker without a condom?
Is it cheaper?
Old 03-31-2015, 01:32 AM   #1878
JB86'd
JB86'd's Avatar
Drives: JAWS
Is it cheaper?
Short term yes
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Andrew025 (03-31-2015)
Old 03-31-2015, 02:50 AM   #1879
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
Assuming you're talking catback, you will not make any extra power; the primary restriction is the catalytic converters, which you are not removing. If you get a header and a headerback exhaust setup, then you WILL gain power, but you will also need a retune. The Jackson Racing supplied tune requires the cats to be in place.
I keep hearing things about area86, but I can't actually register on Naver so I have no idea what's going on :p
Thanks, Mike. Just as I thought. Regarding removing restriction, wouldn't high-flow cats be much less restrictive than stock cats? So if I wanted to keep at least one HFC in the exhaust system, would it be better to get catted header or catted front pipe?
Regarding a retune, I know I will need one, so I am planning on just getting the JRSC tuner kit and not the CARB version since I will need a custom tune anyway.
Naver's registration process sucks. But you can still register as a foreigner, I believe.
Rookie84 is offline   Reply With Quote
Old 03-31-2015, 10:54 AM   #1880
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
You want to remove the restriction closest to the engine for the most gains.
ApolloSki is offline   Reply With Quote
The Following 3 Users Say Thank You to ApolloSki For This Useful Post:
Alltezza (03-31-2015), Rookie84 (03-31-2015), SirBrass (03-31-2015)
Old 03-31-2015, 11:22 AM   #1881
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Basically, get catless headers and replace fp cat with a high flow one (or go catless there as well if you spouse/significant other or you doesn't mind gasoline stink). You CAN run it without a tune, but you will only see minimal gains. You need the retune to take advantage of the extra power now available to you by removing the restrictions.
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
Old 03-31-2015, 12:04 PM   #1882
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Why is this? I always figured that restriction is restriction, no matter where it is in the exhaust system.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 03-31-2015, 12:32 PM   #1883
sw20kosh
Drives: 2013 Black FR-S
It has a lot to do with exhaust scavenging/header collector design and as little pressure as possible near the exhaust valves.
Old 03-31-2015, 12:39 PM   #1884
SirBrass
SirBrass's Avatar
If we're talking continuous flow, then you are correct, as fluid is fluid whether it's liquid or air. However, the engine delivers exhaust in pulses, as the exhaust valves open and close. Also, exhaust gasses cool (and thus slow as well) as they get farther from the heat source (engine exhaust ports). A restriction in the area where they're faster and hotter tends to create more turbulence and slow the gasses when they should be moving fast.
Think of how lane restrictions slow traffic on roads. Where is a single lane restriction more disruptive to smooth traffic flow? When normal flow is faster (like on a freeway) or slower (like on the street)?
The Following 2 Users Say Thank You to SirBrass For This Useful Post:
904FRSlow (03-31-2015), CSG Mike (03-31-2015)
Old 03-31-2015, 02:13 PM   #1885
CSG Mike
CSG Mike's Avatar
Originally Posted by 904FRSlow View Post
So should I just tow my car there?
Absolutely.
Old 03-31-2015, 02:15 PM   #1886
CSG Mike
CSG Mike's Avatar
If you're driving hard and/or redlining, there's a high probability you'll kick the car into limp mode with the Jackson Racing CARB tune.
@SirBrass is correct; always get a tune/retune to get the most out of the parts you're putting on the car.
Old 03-31-2015, 02:15 PM   #1887
CSG Mike
CSG Mike's Avatar
Funny you mention that; we're working on something like that.
Old 03-31-2015, 02:18 PM   #1888
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
You're making a header specifically for gains with the JRSC? God dammit. Now I have to wait on headers... (UEL please)
ScionOfHorus is offline   Reply With Quote
Old 03-31-2015, 02:28 PM   #1889
ApolloSki
Stealth
ApolloSki's Avatar
If the price is right and gains are there, it might be worth swapping.
Old 03-31-2015, 03:02 PM   #1890
SirBrass
SirBrass's Avatar
Of course if you have CA plates, you have that whole CARB nonsense to wrangle with.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
