Old 03-28-2015, 08:19 PM   #533
mmc18467
Drives: 2013 Scion FR-S Asphalt MT
What's the waiting period for a header these days? Just wondering before I buy it.
mmc18467 is offline   Reply With Quote
Old 03-28-2015, 08:28 PM   #534
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I believe our next shipment (which is expected to arrive next week) is pretty big and should leave us with units in stock after all backorders are filled. But to be sure, shoot an email to the sales guys at sale@openflashperformance.com. The will know better than I.
Shiv@Openflash is offline   Reply With Quote
Old 03-30-2015, 07:25 PM   #535
rdub-S
Drives: 2013 FRS
For those of you waiting for the next shipment of headers, it looks promising. I received my tracking information today.
Looking forward to it.
rdub-S is offline   Reply With Quote
Old 03-30-2015, 08:32 PM   #536
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
ME TOO! Due at my door April 6th!! Just in time for my first track event of the year.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 03-31-2015, 01:39 PM   #537
AlwaysSideways
Drives: 2013 WRB Subaru BRZ
here's a video of my car. Has Perrin 2.5" catback, Perrin overpipe, OFH+OFT tune
AlwaysSideways is offline   Reply With Quote
Old 03-31-2015, 05:24 PM   #538
2much
I wanna go fast
Drives: 2013 FR-S 6MT
@steve99 @JB86'd @Phantobe
OK so I've got some new logs. I reflashed stage 2 uel 91 octane and started data logging immediately after. IAM was indeed reset to 1.
The first log is pretty boring. Normal, low throttle city driving for about 15 minutes. IAM did not change.
Second log I drove a little harder on the way home. You can see the IAM cut to .88 and there is some knock shown around 3k rpm.
Weird thing about this second log - it does not show me going above 7k. And I am sure I redlined it, twice, at the two peaks. Weird??
1: http://datazap.me/u/cjh/1-just-after...e?log=0&data=1
2: http://datazap.me/u/cjh/1-just-after...e?log=1&data=1
2much is offline   Reply With Quote
Old 03-31-2015, 05:38 PM   #539
steve99
Drives: FT86
Bit of knock arround 3000k rpm is very common.its only very minor and wont rearly hurt anything but if you want to stop the occasional iam drop then pull about 0.7 degrees from 2400 to 4000 rpm loads 0.6 to 1.1.
Then see how it goes just note where you get knock load/rpm and pull small amounts of timing. you will never completly eliminate it on 91 fuel.
If jb86'd is on same setup as you on 91 fuel get a copy of his changes.
Old 03-31-2015, 05:44 PM   #540
2much
I wanna go fast
Is it even worth the effort then? Should I just let the ECU do its thing and run a retarded ignition multi?
Old 03-31-2015, 05:49 PM   #541
steve99
Drives: FT86
You could just leave it if you want
however when IAM drops ecu pulls timing from entire rpm range for safety so it takes away from top end even though knock is only at lower rpm. Its not much but us fiddlers just like to fiddle and get thing just right.
Stock factory tune runs iam around 0.5 to 0.7 and pulls around 3 degrees knock correction on 91 fuels.
Old 03-31-2015, 06:30 PM   #542
2much
I wanna go fast
JB did you modify your 91 stage 2 ots tune?
Old 03-31-2015, 08:03 PM   #543
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
http://www.ft86club.com/forums/showp...&postcount=346
http://www.ft86club.com/forums/showp...&postcount=304
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 03-31-2015, 08:05 PM   #544
tracerit
Drives: '13 SSM BRZ Limited 6MT
Have you updated your template (3/27) and OFM 1.18.4? I did a few WOT and none of it showed up, but I haven't had any issues since updating.
tracerit is offline   Reply With Quote
Old 03-31-2015, 08:07 PM   #545
2much
I wanna go fast
thanks... the concept is a little scary but if it really is just editing numbers to match your table... I will take a go.
Old 03-31-2015, 08:08 PM   #546
2much
I wanna go fast
I have not, the OFT is telling me to update my template when I log. However the last few logs show me hitting 7600rpm and I havent changed anything.
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 06:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 06:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 05:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 06:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
