go_a_way1
Old 03-26-2015, 02:19 AM   #3053
_Taylorgaaaang
Drives: 15' WRB BRZ
What front camber bolt would you guys recommend to pull the most camber?
Also which hole would be best top or bottom? Looked at some threads here couldn't really get a straight answer.
_Taylorgaaaang is offline   Reply With Quote
Old 03-26-2015, 10:43 AM   #3054
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Camber bolts are for bottom only.
If you want max camber. Replace the upper strut tower bolt with the lower OEM bolt. When you have the camber bolt installed. You can also grind down the OEM bolt for more adjustment/negative camber
Kosmos is offline   Reply With Quote
Old 03-26-2015, 12:13 PM   #3055
jaydee_do_work
jaydee_do_work's Avatar
Drives: 13' Whiteout FR-S
the mrs. and I at our local spring opener with the works finally on!
jaydee_do_work is offline   Reply With Quote
The Following 5 Users Say Thank You to jaydee_do_work For This Useful Post:
cfig21 (03-26-2015), DavidBob (03-29-2015), dubbrand (03-26-2015), RUNAMUK (04-23-2015), WhiteLightning (04-04-2015)
Old 03-29-2015, 09:30 AM   #3056
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Kuzuri is offline   Reply With Quote
The Following 10 Users Say Thank You to Kuzuri For This Useful Post:
BRZtoni (03-29-2015), chas3wba0 (04-01-2015), DavidBob (03-29-2015), Dr Evil (03-29-2015), Goya (04-01-2015), Jdogg88 (03-30-2015), Metabrz (04-02-2015), PradiG (03-31-2015), ricky rod (04-02-2015), srizzors25 (03-30-2015)
Old 03-29-2015, 02:05 PM   #3057
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Looking to get 225/40's on my 18x9.5's, could you guys recommend some tires? Not looking to break the bank but decent tires would be nice. What are you guys running?
DavidBob is offline   Reply With Quote
Old 03-29-2015, 03:09 PM   #3058
Vten
Drives: Too heavy
I like achilles ATR sports , haven't try the ATR sport 2 yet , but I love it so far . Great grip on the rain and dry also streches pretty well.... And they're cheap too .
Vten is offline   Reply With Quote
The Following User Says Thank You to Vten For This Useful Post:
Old 03-29-2015, 09:38 PM   #3059
PradiG
Drives: Fr-s
PradiG is offline   Reply With Quote
The Following 11 Users Say Thank You to PradiG For This Useful Post:
636 (04-02-2015), cfig21 (03-30-2015), Dr Evil (03-30-2015), Goya (03-31-2015), HATED1 (03-31-2015), Kuzuri (03-30-2015), ricky rod (04-02-2015), sittinSideways (04-02-2015), srizzors25 (03-31-2015), stancypants (04-14-2015), WhiteLightning (04-04-2015)
Old 03-29-2015, 11:01 PM   #3060
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Cambaahh
The Following User Says Thank You to Kosmos For This Useful Post:
vtmike (03-31-2015)
Old 03-30-2015, 03:11 PM   #3061
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
free-wheelin' camber...
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 03-30-2015, 08:58 PM   #3062
srizzors25
Daedalus Moto
srizzors25's Avatar
I don't know if this counts?
Old 03-31-2015, 06:25 PM   #3063
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
Follow me on IG: @rougarou86
boucher is offline   Reply With Quote
The Following 4 Users Say Thank You to boucher For This Useful Post:
636 (04-02-2015), GuerillaRacing (04-02-2015), Kuzuri (04-01-2015), WhiteLightning (04-04-2015)
Old 03-31-2015, 06:28 PM   #3064
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Hits real camber
Old 03-31-2015, 11:59 PM   #3065
jedichimp
jedichimp's Avatar
Drives: yes
Oh, haha. It looked like you just took off the lugs and it was just chillin on the hub...
Originally Posted by Kosmos View Post
Hits real camber
panda cheez
Old 04-01-2015, 02:06 PM   #3066
MrMarinakos
Drives: Asphalt Monogram Fr-s
Just got my wheels mounted and had a shoot, heres some of my favorites:
IMG_7940 by bryanreyesva, on Flickr
IMG_7788 by bryanreyesva, on Flickr
IMG_7654 by bryanreyesva, on Flickr
IMG_7544-2 by bryanreyesva, on Flickr
I'm going a little more camber all around and lower, just need some tweaking. Debating on getting onimade camber plates or slotting my front coilovers.
MrMarinakos is offline   Reply With Quote
The Following 10 Users Say Thank You to MrMarinakos For This Useful Post:
636 (04-02-2015), Autocon (04-01-2015), boucher (04-02-2015), GuerillaRacing (04-02-2015), Kuzuri (04-01-2015), Losssss (04-17-2015), PradiG (04-02-2015), ricky rod (04-01-2015), srizzors25 (04-01-2015), swarb (04-01-2015)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
