Old 03-29-2015, 08:54 AM   #1
Thet
Drives: Blue
Need opinions on my frs :D
Consedering getting yellow fog light tint however i have never seen it in person.
How does it look?? Pics please!!
With a white color light bulb and yellow tint, would the output be a yellow or white colour light being emmited?
Ps: I'm new to cars
Thet is offline   Reply With Quote
Old 03-29-2015, 10:03 AM   #2
raven1231
Personal opinion is I think yellow lights look like shit
The Following 5 Users Say Thank You to raven1231 For This Useful Post:
1GiantTurtle (03-29-2015), GT86_PRAGUE (07-08-2015), kch (07-05-2015), MikeM7 (03-29-2015), tennisfreak (03-30-2015)
Old 03-29-2015, 10:07 AM   #3
thill
I am not a fan either. Comes down to what you like OP. And functionally, wouldn't you be lowering the light output?
Old 03-29-2015, 10:13 AM   #4
Thet
Drives: Blue
I assume so.
With a white/xenon light and yellow tint, would the output be a yellow or white color light being emmited?
Old 03-29-2015, 11:04 AM   #5
stevesnj
stevesnj's Avatar
With a white/xenon light and yellow tint, would the output be a yellow or white colour light being emmited?
Ps: I'm new to cars
What color is your FRS?
My 2016 Build thread
Old 03-29-2015, 11:06 AM   #6
Thet
Drives: Blue
It's black.
Old 03-29-2015, 11:18 AM   #7
stevesnj
stevesnj's Avatar
It's black.
I found this pic, I'd ignore the headlights but it has yellow fogs
Old 03-29-2015, 11:20 AM   #8
Thet
Drives: Blue
Thanks do you know what color would be emitted at night with my white bulbs in ? Would the output be a yellowish color
Old 03-29-2015, 11:27 AM   #9
stevesnj
stevesnj's Avatar
I think white bulbs in a yellow housing may emit just a washed out yellow or just may show a white altogether. I duno if this is a white bulb in the yellow housing or yellow bulb yellow housing. Good question
Old 03-29-2015, 12:09 PM   #10
orangeblue
Drives: Whiteout
Looks like yellow lenses. Yellow bulbs in a clear housing doesn't create the same consistent color that a yellow lens or film will provide (in terms of what it looks like with the lights off). Yellow film will reduce the light output slightly, although on fogs probably not enough to make a noticeable difference. In general, yellow (2500k) bulbs will provide more useable light output than a white-blue (6000k) bulb in the same housing. I run 2500k bulbs in my headlights because it creates less glare.
The biggest functional change you can make (without opening the headlights to swap in HID projectors) is using modified H9 lowbeams instead of the stock H11 bulbs. You need to use an adapter or modify the plug, and trim the tabs to fit the socket, but the 10W increase is really noticeable.
orangeblue is offline   Reply With Quote
Old 03-29-2015, 12:11 PM   #11
86geek (03-29-2015), bumppinKota (07-03-2015), Choco (03-29-2015), GT86_PRAGUE (07-08-2015), raven1231 (03-29-2015)
Old 03-29-2015, 12:34 PM   #12
MikeM7
Drives: 2013 BRZ Limited White
I bought white LED bulbs just so that I wouldn't have yellow fog lights. White looks much better imo.
MikeM7 is offline   Reply With Quote
Old 03-29-2015, 01:02 PM   #13
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
I assume so.
Your eye see's yellow/green the best out of all the colors. You might not get as much light output out of the yellow compared to white lights but you will be able to see alot more detail on the road with the yellow.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 03-29-2015, 07:27 PM   #14
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
Yes you see pot holes fast with yellow I had my Prelude with 3500k hids and I like to drive with them on all the time even in the day time they looked bad ass
Albaro08 is offline   Reply With Quote
Need opinions! TakeNoL Electronics | Audio | NAV | Infotainment 13 01-26-2014 02:14 PM
New opinions Ralph2sweet BRZ First-Gen (2012+) — General Topics 26 01-17-2014 06:41 PM
opinions please? Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 12-09-2013 12:33 AM
Need Some Opinions Before I Buy Mr Kirmudget Cosmetic Modification (Interior/Exterior/Lighting) 0 09-27-2013 12:21 AM
I need your opinions WatchmaN Cosmetic Modification (Interior/Exterior/Lighting) 25 12-12-2012 01:11 PM
