Old 03-28-2015, 06:20 PM   #1
autograph
autograph's Avatar
Drives: 6MT Hot Lava
No bolt threads on the Valenti Style Reverse lights?
I bought the following reverse light: http://store.ijdmtoy.com/Valenti-Sty...tion-a/617.htm
the instructions say to install the reverse light just like you uninstalled the stock reverse light. on top of the stock reverse light, there are two bolts. However, when I went to put the bolts into the new reverse light, nothing was catching -- as if there is no thread-hole at all. All that is holding it currently are the two side plastic screws and the plastic clip on the middle/bottom. Not sure if this is safe. Anyone with these reverse lights care to input?
Thanks!
autograph is offline   Reply With Quote
Old 03-28-2015, 08:33 PM   #2
dubbrand
Thanks!
If I remember correctly I pulled the factory metal tabs off of my stock 3rd break light and slid them onto the Valenti ones so you could use the bolts up top
dubbrand is offline   Reply With Quote
The Following User Says Thank You to dubbrand For This Useful Post:
autograph (03-29-2015)
Old 03-28-2015, 10:03 PM   #3
Poodles
Drives: 2015 Series.Blue
Mine bolted directly in (different vendor though)
Old 03-29-2015, 12:28 AM   #4
autograph
autograph's Avatar
thanks guys -- im going to try what dubbrand mentioned tomorrow. we'll see how it works out
Update: I did what dubbrand did; used flat head to take the metal tabs off the stock reverse light and just clipped / bent them onto the aftermarket reverse light. worked like a charm!
WTB: Valenti Tail Lights & Reverse Bar Combo TONY_BRZ Exterior Parts (Aero, Lighting, Etc.) 0 11-24-2014 10:18 AM
Valenti reverse lights Battle86 Hawaii 4 08-05-2014 01:37 AM
FS: Valenti LED Tail lights + LED Reverse Lamps donutfilling Exterior Parts (Aero, Lighting, Etc.) 6 03-27-2014 02:52 AM
Rewiring Valenti Reverse Lights Seungify Southern California 2 02-04-2014 03:44 PM
New Valenti Smoked reverse lights SOCAL SliverBrz Exterior Parts (Aero, Lighting, Etc.) 8 07-31-2013 05:46 PM
