Old 03-27-2015, 01:51 PM   #519
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Originally Posted by 2much View Post
will disconnecting the battery achieve the same affect (reset IAM)?
I don't believe so...however I could be wrong. There is a way called the "Vishnu Reset" which is somewhere on the forums. I haven't personally used it.
However the easiest way is to just re-flash the tune, it only takes 3 minutes now to write the tune to the ECU. So its the easiest method if you ask me
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 03-27-2015, 02:15 PM   #520
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Let me ask you guys a question that I should have asked when I first got the OFT... is the touchscreen functionality on your OFTs total crap like mine? Sometimes I will have to tap/jap/press/hammer the screen about 100 times for it to recognize a touch. It does not seem like a cpu/system problem, but a touchpad only problem. It has a LOT of trouble recognizing my input.
The reason I bring this up is because tuning will not take me 3 minutes... it will take about 20 because of this
2much is offline   Reply With Quote
Old 03-27-2015, 02:19 PM   #521
bfsnail
bfsnail's Avatar
Have you tried calibrating the touch screen?
bfsnail is offline   Reply With Quote
Old 03-27-2015, 02:26 PM   #522
2much
I wanna go fast
Nope... I haven't seen this option on the OFT before?
Old 03-27-2015, 02:35 PM   #523
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Open Flash Header Discussion
I mean it's no smartphone touchscreen. I have to apply a little pressure when using the touch screen however it's nothing like what you've just described. I recommend emailed the vishnu team.
Edit: actually try calibrating it first like @bfsnail mentioned
Kronos is offline   Reply With Quote
Old 03-27-2015, 03:49 PM   #524
JB86'd
JB86'd's Avatar
Drives: JAWS
Calibrate using a stylus if possible, Shiv says that will give the best results. I don't have a stylus but just calibrating with my fingers helped a lot.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
2much (03-27-2015)
Old 03-27-2015, 04:00 PM   #525
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Just an update on my situation... I haven't gotten a CEL (p2096) since I've retuned. I believe I just got bad gas is all. However, I am running lean still on deceleration so I'm going to reflash again and hope that fixes that
904FRSlow is offline   Reply With Quote
Old 03-27-2015, 04:03 PM   #526
FISHBURGLAR
Drives: whiteout fr-s
RECEIVED MY oft but not my OFH =/ so eager to get this bad boy in. did they start shipping the ofh?!
FISHBURGLAR is offline   Reply With Quote
Old 03-27-2015, 04:14 PM   #527
Phantobe
Phantobe's Avatar
I had a similar issue and when I calibrated the screen with a stylus it fixed the problem.
The Following User Says Thank You to Phantobe For This Useful Post:
2much (03-27-2015)
Old 03-27-2015, 04:26 PM   #528
2much
I wanna go fast
Thanks guys, I didnt know there was a calibration option. Glad I asked
Old 03-27-2015, 04:42 PM   #529
steve99
Drives: FT86
reflash wont fix it its likely exhaust or intake leak dirty maf sensor ect
ecu continuously learns no need for reflash
seeing AFR of 15 to 20 is normal on overrun deceleration
Old 03-27-2015, 09:11 PM   #530
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Good news! We are getting a much awaited batch of OFHs delivered to us this evening. They ship out on Monday. It won't fill all the pending orders but there should be another batch being delivered to us next week too. Sorry about all the delays up till now. With the shipping strike here in CA, we had our hands tied.
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
aghuman (03-28-2015), givemeporknow (03-29-2015), Takumi788 (03-28-2015)
Old 03-27-2015, 11:50 PM   #531
904FRSlow
904FRSlow's Avatar
Checked MAF and its clean. I have a small exhaust leak but it shouldn't be the issue. I'm going to do another run and record data tomorrow.
Old 03-28-2015, 04:39 AM   #532
steve99
Drives: FT86
if exhaust leak is before or nearco2 sensors it can upset readings
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 06:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 06:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 05:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 06:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
