Old 03-26-2015, 12:27 PM   #29
TheRoadWarrior
Much damage?
TheRoadWarrior's Avatar
Drives: Renaultsport Clio200
Rick, interesting vid as ever. Are you planning on doing a drive-by video to let us compare if the car with full exhaust is any quieter now it's got a supercharger on there?
TheRoadWarrior is offline   Reply With Quote
Old 03-26-2015, 04:50 PM   #30
Calum
That Guy
Drives: 2013 asphalt FRS MT
Rick, can you convert the speeds on your dyno graph to rpm for me?
Old 03-26-2015, 10:45 PM   #31
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Any ideas as to what oil cooler you guys would run with this kit?
Old 03-27-2015, 09:56 AM   #32
350matt
Drives: toyota mr2/ Toyota GT86
would you need one if you're not going to track it?
350matt is offline   Reply With Quote
Old 03-27-2015, 12:20 PM   #33
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
Originally Posted by 350matt View Post
I think cosworth re offering 3 tunes to go with the charger;
stage 2.0 - stock exhaust
stage 2.1 - catback exhaust
stage 2.3 - full exhaust inc manifold
and I think the kit gives about 7 psi
I am curious about this and if someone can indeed confirm that Cosworth does offer above OTS maps, it would be great.
Also, do you have to use Cosworth exhaust parts in order to use their OTS map? I want to know if their OTS map can cover the usage of other brand's header and exhaust.
Rookie84 is offline   Reply With Quote
Old 03-27-2015, 12:40 PM   #34
weederr33
weederr33's Avatar
Those are the tunes offered. They say their tunes are geared specifically for their exhaust parts but... it's just piping so I would assume you could. Well as for the headers, I'd still use them
Old 03-27-2015, 01:06 PM   #35
350matt
I'd say as long as you're running more or less the same pipe dimensions ( the Cosworth kit is all 3") you can probably mix and match OK
if its too high a back-pressure compared to the Cosworth exhaust then it'll hamper the tune
Old 03-27-2015, 01:07 PM   #36
Rookie84
Oh sweet. Thanks for the confirmation. I know exhaust shouldn't really matter... as for the header, I am wondering if usage of UEL header will be okay or not with OTS stage 2.3 tune. BTW, did Cosworth release any power figures and graphs for stg 2.3?
The Following User Says Thank You to Rookie84 For This Useful Post:
ultra (03-29-2015)
Old 03-27-2015, 01:09 PM   #37
Rookie84
I see. Thanks for the info. Like I have mentioned in my above reply, do you think use of UEL header will be okay or not?
Old 03-27-2015, 01:18 PM   #38
350matt
you might have some issues I'd say as the cam timing is going to be quite different between the 2 type
thing is if you're going Cosworth you get the tune included anyway? So there's nothing to stop you trying it and see how you get on
if it doesn't work out and you're desperate to keep the UEL header then you'll obviously need a custom tune
Old 03-27-2015, 01:20 PM   #39
Koa
UEL and EL and tuning are not interchangeable @Rookie84
Old 03-27-2015, 01:29 PM   #40
weederr33
weederr33's Avatar
They graphs are on their website. As for the headers, like others may have stated, it would probably not work. I'd say at least keep the headers that Cosworth uses the same. As for the rest... well that's your choice
The Following User Says Thank You to weederr33 For This Useful Post:
ultra (03-29-2015)
Old 03-27-2015, 10:34 PM   #41
Rookie84
Just as I expected... thanks for the confirmation anyway, gentlemen.
Old 03-28-2015, 09:47 AM   #42
350matt
so are you planning a custom tune for yours then?
who will you use?
Cosworth FA20 Stage 1 Power Package DaDr00 Engine, Exhaust, Transmission 84 06-10-2016 03:02 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 07:29 AM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Cosworth Stage 2 v86 Software Tuning 2 11-05-2014 07:47 PM
