Old 03-26-2015, 11:15 PM   #1
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Rear transaxle conversion
I'm trying to kill a few birds with one stone here, but I'm less than 100% sure and want advice from the community.
Attached are images of an unbolted (upside down) FRS rear subframe and a Porsche Boxster S transaxle. I am wondering... It looks to me that cutting out the center box beam section where the diff bushings sit and welding on tubular mounts to fit the attach points of the porsche gearbox is feasible. It would require a torque tube to connect the transmission/transaxle to the engine.
This would allow the stock transmission, driveshaft, differential, and axles all to be replaced all at once (more on this below).
An older Boxster S or Cayman transmission can be had for about $3,000.00, and can handle significantly more torque than our stock transmission.
It would extend a short way past the subframe in the rear, but removing the stock muffler will leave a cavity with plenty of space.
Now, I have done plenty of welding and mechanical work but I have zero experience with torque tube cars. (I hope there's a Corvette guru around..) I know DSS and others can fabricate one... As I understand, the flywheel and clutch can stay put, and the tube will need custom bellhousings on both ends, the front accommodating the starter. Correct me if I'm wrong. The shifter will also need to come out and be replaced with a cable shifter...And I know almost nothing about cable shifters.
Objectives and benefit:
Gets rid of the fragile manual transmission in the stock car. (Also axles and driveshaft, although I haven't seen a lot of those breaking).
Improve balance (Working on exact numbers, but my car is on a barge for the next 8 weeks.)
Compatible with any eventual engine swap...
I'm betting on overall weight reduction, but I'll hold my tongue until I have numbers.
Concerns:
I've overlooked something and this will not work.
Blah blah blah polar moment of inertia...whatever.
Subframe or engine movement breaking the tube.
Starting a senseless argument about weight distribution (please god no)
More information needed, I'm working on it:
Porsche transmission weight, model Number, gear ratios.
Stock diff weight (have stock trans [115lb] and muffler [26lb] weight) Correct if wrong.
Any important sensors I haven't thought of? F*** the gear indicator, I don't care.
Spartarus is offline   Reply With Quote
Old 03-26-2015, 11:27 PM   #2
Spartarus
...Just add nauseum
Spartarus's Avatar
Here is the underbody illustrating the diff, subframe, and muffler placement.
I'll elaborate a little more on why I care about static balance, and why i'm shooting to get closer to 50/50. As you know, weight doesn't transfer nearly as well on slick surfaces, so static balance matters more for maximizing traction. I learned this lesson over and over and over in Alaska, in many different cars. I am moving out of Alaska, but I'd still like to build a car that's happy doing rally, dirt track, and ice racing. I know AWD is much better for those conditions, but it isn't nearly as FUN.
...And isn't that why this little car exists?
Old 03-26-2015, 11:34 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
It seems like an expensive way to go about things but I can see some sdvantages to it too. In for results
EDIT: How would the trans compare height wise to the diff we have?
1974 TA22 Celica
2013 86 GT
Old 03-27-2015, 12:36 AM   #4
Dipstik-sportech
Dipstik-sportech's Avatar
Stock diff weight is 95ish lbs. Won't the fuel tank be in the way of the bell housing for the transaxle?
Old 03-27-2015, 01:35 AM   #5
Crazy Drew
Drives: Smells like tires when I drive
Interesting idea and I'm curious if it pans out. TBH I'm not sure there's really that much to be gained by converting to a transaxle. The stock trans is light, I know it's a bit "fragile" but it does well in 99.9% of applications, as does the diff. I'm also a few beers in for the night so please forgive me but is removing 30-40lbs from near the center of rotation on the car really worth the expense?
As Dipstick said I'm sure the fuel tank will be in the way, as well as the trunk floor.
My main question (playing devils advocate here, I really want to see this done but need to be a realist) is, who is going to make the torque tube? You're talking about a pretty serious piece of equipment to manufacture by the time you consider the alignment and strength and stiffness concerns between engine and transaxle.
Crazy Drew is offline   Reply With Quote
Old 03-27-2015, 02:16 AM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Ohhhhh I like this thread.
Old 03-27-2015, 02:23 AM   #7
D K
Stig's dark passenger
Another dreamer with a project that will never see the light of day
D K is offline   Reply With Quote
The Following 3 Users Say Thank You to D K For This Useful Post:
Captain Snooze (03-27-2015), Freeman (03-27-2015), OkieSnuffBox (03-27-2015)
Old 03-27-2015, 12:15 PM   #8
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Am I the only one to notice that he'll have 1 forward speed and 5 in reverse? This transaxle is meant to be in front of the engine, not behind it. Unless it's from a front-engine Porsche, like the 944, or 928, in which case you'd already have a torque tube and custom bellhousings from the donor car.
KoolBRZ is offline   Reply With Quote
Old 03-27-2015, 12:28 PM   #9
Dipstik-sportech
The boxster/cayman are mid engined cars, the transaxle is behind the engine so it would be fine.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
wparsons (03-27-2015)
Old 03-27-2015, 12:29 PM   #10
Koa
you're ridiculous koolsquad
Old 03-27-2015, 12:32 PM   #11
gramicci101
Off Topic
Where would the clutch be? The bellhousing sticks up a lot, and that would interfere with the chassis. If the clutch is still on the back of the engine, you'll need a separate housing just for it, then a driveshaft feeding back to the transaxle. Which would need a lot of fabrication to knock the bellhousing down a bit.
Old 03-27-2015, 12:40 PM   #12
wheelhaus
wheelhaus's Avatar
I'll be impressed if this actually makes it into modification steps, and blown away if it's made to work reliably. I'd love to see this pan out for the sole reason that it's unique and ambitious.
Couple questions... What's the purpose of a torque tube, why not use the driveshaft? Where would the clutch go, by the engine of trans? I guess it would be easier at the engine, but I'm not sue how well the driveshaft would balance at 7400 rpm. What speed does it spin on a stock drivetrain at 150mph?
Old 03-27-2015, 01:18 PM   #13
KoolBRZ
KoolBRZ's Avatar
If you bought a wrecked '85 on up 928 s4 or gts, you would not only have the transaxle, but the bellhousings, torque tube, clutch, and a light-weight aluminum V8 as well! That would make an FR-S/BRZ chassis really fly. It would sound great also.
The Following User Says Thank You to KoolBRZ For This Useful Post:
Old 03-27-2015, 01:32 PM   #14
gtpvette
Drives: 2015 FRS - FFR GTM
I'd say this or a C5 or C6 transaxle would work better. These boxes are made to be remote from the motor.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
FBM 8.8 IRS Rear Diff Conversion FullBlown Forced Induction 133 12-26-2015 10:35 AM
FS: Cusco rear LCA, Project KICS conversion spacers, and Sparco quick release newerafury Brakes, Suspension, Chassis 3 02-05-2015 11:11 AM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
Rear fog reflector to brake light conversion Cal3000 Cosmetic Modification (Interior/Exterior/Lighting) 1 03-30-2014 02:57 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
