Old 03-26-2015, 02:17 PM   #505
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Originally Posted by JB86'd View Post
Same. I would try Shell if you have a station nearby, I've had good luck with Shell, it's more knock resistant than Chevron in my experience, don't know about 76.
I am stuck on 76. for a rather embarassing reason
2much is offline   Reply With Quote
Old 03-26-2015, 02:30 PM   #506
JB86'd
JB86'd's Avatar
Drives: JAWS
Screwed a cheap hooker in the bathroom of a Shell and got banned for life?
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
flippy (04-15-2015)
Old 03-26-2015, 02:37 PM   #507
2much
I wanna go fast
lol dude. Despite being almost 30 and having a stable, decent paying job, the one thing I still get from my mom is a 76 gas card
Old 03-26-2015, 03:21 PM   #508
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Better fuel could fix your problem but its still likely you're gonna have to pull timing, I haven't seen anyone that has run 91 and not have had to edit the timing tables.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 03-26-2015, 05:00 PM   #509
2much
I wanna go fast
So the 91oct OTS map shouldnt be as aggressive we think?
Old 03-26-2015, 05:31 PM   #510
steve99
Drives: FT86
Even the stock tune using 91 you will get knock and your iam will be down arround 0.6 this is ecu's normal behaviour to coping with 91 when its tuned for 93. Its not going to blow up but will result in reduced power and torque and likely economy.
looks like your current 91 fuel is a low grade 91.
switching to a "better" 91 brand would be best option.
If you want to stay with that fuel and want to have iam at 1 then you will need to modify your timing map to accomodate that fuel.
Old 03-26-2015, 05:37 PM   #511
2much
I wanna go fast
what is the whole fucking point of 91 again? To reduce carbon emissions? Meanwhile it is killing my MPG, I average 23 right now.
Sounds like there is no real solution here except to either switch to e85 or have the OTS file modified. Or just live with it...
Old 03-26-2015, 07:14 PM   #512
Phantobe
Phantobe's Avatar
Its cleaner for the environment.
E85 is a good option, however if you take the time to read about tuning pulling timing isnt such a hard feat.
Old 03-26-2015, 09:48 PM   #513
s2d4
s2d4's Avatar
what is the whole fucking point of 91 again? To reduce carbon emissions? .
Are you blaming the tune because of bad gas?
Old 03-26-2015, 10:18 PM   #514
troek
troek's Avatar
Drives: 2012 Toyota 86
i think he is saying, why not have all gas be high octane.
troek is offline   Reply With Quote
Old 03-26-2015, 10:49 PM   #515
2much
I wanna go fast
i am wondering why california enforced 91 when in my particular case it is reducing my fuel economy and causing my engine to knock.
Old 03-26-2015, 11:48 PM   #516
Phantobe
Phantobe's Avatar
Lol emissions dude, we're a hippy state :P
Old 03-27-2015, 12:16 AM   #517
s2d4
s2d4's Avatar
Take it up with your gas supplier or just change brand.
Old 03-27-2015, 12:49 PM   #518
2much
I wanna go fast
Looks like you have some knock in the 3600 to 5000 RPM range.
Reflash your tune (this resets IAM to 1) and start logging and go for a cruise, let the ECU learn a bit then maybe do some WOT pulls & you'll be able to see where the ECU begins to pull timing but from your current log its 3600 to 5000 RPM however there could be more knock elsewhere when your IAM is starting at 1.
will disconnecting the battery achieve the same affect (reset IAM)?
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 06:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 06:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 05:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 06:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
