Old 03-26-2015, 07:31 AM   #1
awhatzable
Drives: GTS86
How do I remove fastener plug underneath TRD lip?
I want to remove my TRD Lip so I can fix the scrape marks on the stock bumper. I tried pulling it out with my hands and pliers but it only come out halfway before my fingers gives out. The plug clicks in when you push the head/base in to the ring around it.
Number 5 is the plug I'm talking about on the picture.
awhatzable is offline   Reply With Quote
Old 03-26-2015, 07:51 AM   #2
TJ3000
Drives: MT Raven Black FRS
Just pop so the screw looking like thing comes up. It won't come out all the way, then when it's out "half way" you can pry the base out easily.
TJ3000 is offline   Reply With Quote
Old 03-26-2015, 07:54 AM   #3
awhatzable
Drives: GTS86
It comes out half way but it's still connected to the stock bumper underneath.
Old 03-26-2015, 08:03 AM   #4
awhatzable
Drives: GTS86
Also, what's the plug called and where can you buy it ?
Thinking about chiseling it off if it ain't coming out...
Old 03-26-2015, 08:53 AM   #5
TJ3000
Yes it's not supposed to come off all the way, because it's connected to the base, pop up the screw... Let it dangle, get some pliers and gently wiggle the ring while the screw is popped up if not then it may possibly be connected with the bumper it's self. If that's the case then pop up the screw then wiggle the whole bumper off assuming it's the last fastner on the lip.
Old 03-26-2015, 09:11 AM   #6
Called a "push pin" rivet or clip. With the right tool they pop out as smooth as can be.
8R6 (03-26-2015), tennisfreak (03-26-2015), TJ3000 (03-26-2015)
Old 03-26-2015, 12:18 PM   #7
8R6
8R6's Avatar
Drives: FRS
pop the middle "screw/cap" thing so it's loose (won't fully come out like everyone already said). then get something flat and little wider than a typical flathead screwdriver to push up UNDER the outer circle base. should slide out like a ho.
btw, invest a couple bucks in something like @Tcoat posted. I have a set of panel trim removal tools and it makes life SO MUCH EASIER in little shit like this.
8R6 is offline   Reply With Quote
Got a dent underneath.. bhbnuckle CANADA 8 04-02-2014 11:13 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
What is this underneath the car? FRSHunter Scion FR-S / Toyota 86 GT86 General Forum 13 08-06-2013 10:32 AM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 09:38 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
