Old 03-25-2015, 10:03 AM   #15
burdickjp
Drives: 2013 ultramarine Scion FR-S
I would caution to avoid an unequal length manifold, as large differences in volumetric efficiency between cylinders require different fueling and ignition. If this isn't accounted for then you aren't maximizing power, or worse, running quite a risk, as cylinder mixtures and temps will vary.
If you feel like paying for tuning with individual cylinder exhaust gas temperature probes and individual O2 logging, then you'll get broader torque delivery.
burdickjp is offline   Reply With Quote
Old 03-25-2015, 10:06 AM   #16
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
and we all know how much of a difference the cat-back exhaust makes
It's not just the catback, it's the overpipe and front pipe which are restrictive as hell on stock pieces. Ask any real tuner.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
wparsons (03-26-2015)
Old 03-25-2015, 10:19 AM   #17
raven1231
is Drift-Office not comprised of real tuners? As I said before there are better headers and if OP has money to spend then all means get them. All I'm saying as it's not going to be noticeable and not worth the money in my opinion.
Old 03-25-2015, 11:06 AM   #18
2016 Camaro SS
Drives: Fast
Yes, they're a real tuner, but they also stated the exhaust is stock besides the header. Even Bob will tell you that car probably would have been close to 200 whp without the restrictive overpipe and front pipe combined with it. You can tune more aggressively with better scavenging than the crappy borla collector that doesn't scavenge near as well. An engine that can breath better will always produce more power.
Old 03-25-2015, 12:08 PM   #19
burdickjp
It's half the definition of an engine producing power.
Old 03-25-2015, 02:24 PM   #20
tennisfreak
Drives: 2018 BMW M240i
Stock
You already paid for it
Its under warranty
Its 50 state emissions legal
The Following User Says Thank You to tennisfreak For This Useful Post:
Hyper4mance2k (03-27-2015)
Old 03-25-2015, 03:51 PM   #21
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by tennisfreak View Post
Stock
Its under warranty
http://replygif.net/334
DANG, can't get it to embed.
Old 03-25-2015, 04:05 PM   #22
Koa
overpipe and front pipe are shown to be pretty dismal for gains given the $$...
The Following User Says Thank You to Koa For This Useful Post:
raven1231 (03-25-2015)
Old 03-25-2015, 04:14 PM   #23
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The cats are restrictive yes, but the piping size of the header is what makes it the most restrictive. Since the exhaust gas is considerably higher temp than when it hits the FP or OP, the larger the pipe the better it is for exhaust velocity. (To a certain extent, cant have 5" piping for a manifold, that wouldnt hold enough velocity for the gas).
After the exhaust gas cools down, it compresses (chemistry class PV=NrT.)
Thus the exhaust diameter doesnt matter as much as when its hotter vs colder farther down the system.
The Following 4 Users Say Thank You to cdrazic93 For This Useful Post:
akahenry (04-07-2015), Koa (03-25-2015), raven1231 (03-25-2015), RobertPaulson (04-07-2015)
Old 03-25-2015, 04:23 PM   #24
Koa
Aye I understand the velocity of EGTs and how it pertains to this system.. but realistically speaking, the gains are exponentially worse than a free-flowing header if we're talking gains per $ spent, but I could be so far off that its not even funny.. would have to spend more time researching it
The Following 2 Users Say Thank You to Koa For This Useful Post:
cdrazic93 (03-25-2015), raven1231 (03-25-2015)
Old 03-25-2015, 05:52 PM   #25
2016 Camaro SS
Drives: Fast
The whole point of a header is to improve flow. Why restrict it again at the OEM over pipe and front pipe? Sure, they don't do much with a stock header, but they flow a lot better when combined together.
Old 03-25-2015, 05:53 PM   #26
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Dont worry Ko; im agreeing with you lol
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
Koa (03-26-2015), raven1231 (03-26-2015)
Old 03-25-2015, 10:54 PM   #27
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
I will be getting aftermarket overpipe and front pipe down the line also. But for now, just getting uel header and of tablet.
Mr_YUzU_FRS is offline   Reply With Quote
Old 03-25-2015, 10:59 PM   #28
Mr_YUzU_FRS
fueling and ignition? is that fixable with tune? I am getting the oft for tuning. I like the rumble of uel headers, Im aware some el headers can produce more power than uels. I'm definitely not running the headers without the tune, thats for sure, only way to get the most out of it anyways.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
