Old 03-20-2015, 08:22 PM   #57
Monogram
Drives: 2014 FR-S
Originally Posted by MFPC View Post
Well that's a bummer if that's the case.
Here's my little report I got after I got my car.
If it makes the noise again, I'll be sure to mention it to be the clutch master cylinder and slave cylinder.
In regards to the clutch master cylinder, it never made any sense to me that the noise only happens when shifting, and never happens when depressing the clutch at a stand-still. The throw-out bearing/clutch/trans makes sense, but there have been a number of people who have been the clutch route, and they have all had to replace the master cylinder to fix the noise. If yours was fixed with the clutch/throw-out bearing, I will be surprised. Please post up if the noise doesn't come back.
Monogram is offline   Reply With Quote
Old 03-23-2015, 06:19 PM   #58
SpidyJ
Drives: 2013 FRS
Originally Posted by SpidyJ View Post
Sorry I'm such a dumazz Mono, but what is an FTS?
....aaaah "Field Technical Specialists" (Google is my frenn!)
Noise verified at the dealer today. Wating for instructions from the FTS @ Toyota......will know what they tell them to do by Wednesday 3/25/15.
SpidyJ is offline   Reply With Quote
Old 03-24-2015, 05:04 PM   #59
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
Anyone else here been ripping along, rowing through the gears and get that hon and almost crap your pants because it sounds like someone is honking at you RIGHT NOW AND RIGHT UP INSIDE YOUR SPACE?
I'll be cruising to work all chill during rush hour, see an opening and rip through the gears but then get that honking and think that someone is about to hit me...
Otherwise is there any damage being done? I'd rather not have to have the dealer do any diagnostic test drives if I can avoid it, let alone tear down my transmission.
Jond63 is offline   Reply With Quote
Old 03-24-2015, 07:18 PM   #60
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Mine does it more often when it's cold, but since I garage the car it never really sits out and gets too cold... Well that and it's hasn't been super cold in the PacNW much this year. I first noticed in Dec of 2013.
I took it to the dealer 3 times and they could never reproduce it and neither can I. It just happens once or twice when I least expect it then not again for another couple weeks.
Maybe I should pay attention to my surroundings.. my car could be honking at other cars it likes.
PRO86 | WTCC | STL
Old 03-24-2015, 07:29 PM   #61
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I have the honk. I am sure it is coming from the clutch pedal.
2much is offline   Reply With Quote
Old 03-24-2015, 07:47 PM   #62
Jond63
Jond63's Avatar
I'm sorta leaning toward the master cylinder myself, and that's why I wonder if there is any harm being done if just left alone.
Old 03-24-2015, 07:53 PM   #63
2much
I wanna go fast
it seems to only occur during clutch transition, and when the engine is at a certain RPM/throttle. It kinda bugged me when I first started hearing it, but that was 2 years ago, and I pretty much just ignore it now.
The Following User Says Thank You to 2much For This Useful Post:
Jond63 (03-25-2015)
Old 03-28-2015, 10:05 AM   #64
SpidyJ
Drives: 2013 FRS
Delayed for Master Technician Verification.
Took the car to Sparks Toyota this morning for their Master Technician ride along. We heard it immediately. He will call Toyota Monday for recommendations/instructions.
Oh the suspense!!!!!!
Old 03-28-2015, 10:09 AM   #65
SpidyJ
Drives: 2013 FRS
If you want to reproduce the sound then ride the clutch a little in 1st or 2nd at 3-4k...it will scream at you. Don't do it often though....you know what happens when you overheat the clutch.
Old 04-05-2015, 08:59 AM   #66
SpidyJ
Drives: 2013 FRS
So...the dealer had my car for two days. 3 mechanics could not isolate the noise. All heard it. The Toyota area tech specialist will look at it next. The dealer wants to be the first to find and document the root cause.
Glad they didn't just tear into it and start replacing parts.
.........to be continued.
Old 04-05-2015, 02:34 PM   #67
Monogram
Drives: 2014 FR-S
This has already been diagnosed and solved by Toyota. It's the accumulator in the clutch master cylinder.
Old 04-06-2015, 09:45 AM   #68
nivek111070
Drives: 2014 GB Scoobie BRZ
i get it it on every shift regardless of RPM's. Been with me the whole 20k miles since new... i thought it was the clutch spring or pressure plate
nivek111070 is offline   Reply With Quote
Old 04-18-2015, 01:03 PM   #69
SpidyJ
Drives: 2013 FRS
Still wating for a date with the Regional service guy.
Sparks Toyota Service has stopped retuning my calls.......chuh.
Old 04-19-2015, 08:24 AM   #70
Ozzman
Drives: old
My noise has seemed to diminish greatly with temps now in the 70's and high humidity, go figure.
Ozzman is offline   Reply With Quote
For the not faint of heart.. NX NOS!!! Kit Sportsguy83 Engine, Exhaust, Transmission 84 03-01-2015 02:54 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
Faint Clutch Smell - 6,000 Miles FnFast Issues | Warranty | Recalls / TSB 8 08-16-2013 04:17 PM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 06:03 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
