Old 03-24-2015, 10:15 AM   #477
tomaszjanczak
Drives: Silver Subaru BRZ
Originally Posted by 2much View Post
Mine seems to be constant since it started, a week or two ago.
Will logging exhaust data be accurate enough to determine something like a tiny pinhole leak?
I think it just depends how much the leak affects the O2 readings. It might be too small to make a difference. I logged and my data logs looked fine and I took it to a repair shop to do a smoke test to check for leaks to be 100% sure.
Originally Posted by 904FRSlow View Post
I did clear the code. If i remember correctly, it was p2096 or somewhere around there.
I retuned because it was running like crap after I cleared the code.
I got code P2097 on the same tune you are running. At first that would indicate a leak but I didn't have any leaks because multiple smoke tests showed no leaks and data logs looked good. I emailed Shiv about this and he turned off the code in my tune since everything was looking good and there were no other codes except that one. This might be your situation too.
tomaszjanczak is offline   Reply With Quote
The Following User Says Thank You to tomaszjanczak For This Useful Post:
Wepeel (03-24-2015)
Old 03-24-2015, 12:13 PM   #478
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Originally Posted by s2d4 View Post
That doesnt help much if you can't remember it for sure.
Do you have a K&N filter or any oil based filtet?
I do. It was p2096 actually, just googled it
904FRSlow is offline   Reply With Quote
Old 03-24-2015, 12:31 PM   #479
Wepeel
Drives: '13 BRZ Ltd
Well this is interesting. I'm running OFH+OFT. I notice that when the car idles a lot, like when I leave the car running between autox runs, that the LTFT1 climbes super high - it hit as high as 18% this weekend. It quickly learns back down after I leave the autocross and start normal driving again. Fuel trims at higher loads seem unaffected, so AFR at high loads is still ok, this is only during idle.
But I believe if that fuel trim parameter becomes too positive it will results in the P2096/2097 you guys are seeing.
Fuel trims during driving are all within 6% normally and I hear no odd noises.
Wepeel is offline   Reply With Quote
Old 03-24-2015, 03:13 PM   #480
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
Dear Openflash Customers,
We understand that there has been a long dreaded wait for the OFH. The west coast labor dispute occurred roughly a month ago and even today we are still dealing with the delay. We apologize for the headache and inconvenience it may have caused you. We are doing our best to try to retrieve our shipment but for the most part it is out of our hands. We have gotten the most recent update from the ports. Our first shipment of 17 will likely arrive later on this week or early next week. We have 25 more that will hopefully follow next week. And then we have another shipment of 20 to follow after that. So no matter what we will have all of your orders fulfilled. We are just waiting for our shipment to show up. We are doing everything on our end to speed up the process by prepping the boxes and labels so that as soon as the shipment shows up we can go over QC and then ship out the package to you all. Thanks again for your patience and we apologize for the delay.
Cheers and have a wonderful day.
Robert@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Robert@Openflash For This Useful Post:
aghuman (03-24-2015), inositle (03-24-2015)
Old 03-24-2015, 03:38 PM   #481
stugray
Drives: 2013 GBS BRZ Limited
Well I still have this little rasp/rattle that I cant put my finger on, and unless I'm going crazy, it was NOT there for the first month or two of owning OFH.
Originally Posted by tomaszjanczak View Post
You're not going crazy. If we're hearing the same raspy/exhaust leak sound, then mine is a random surprise every day. One day it will be really loud, the next completely quiet, like if the stock header shielding and everything was there. .
Originally Posted by JB86'd View Post
I also have the raspy noise..it's only under about 3000 rpm and I think it's just air movement, possibly from the diameter of the overpipe being slightly smaller than the header collector size. I think it's more apparent on cold days, seems to get quieter after the car is warmed up.
I upgrade ROM to the OFT stage 1 with NO HEADER and I got the rasp as well.
I thought it was a exhaust shield or something like that getting loose.
However I believe it is just the tune and they way the system manages the HPFP. There was a thread on here all about it, cant recall enoguh key words for a search though....
Old 03-24-2015, 03:54 PM   #482
2much
I wanna go fast
Drives: 2013 FR-S 6MT
What bothers me is that I've had the same tune (oft stg 2 91) and header (ofh) installed for a while and this sound wasnt there. Nothing in the engine bay has changed since. It also seemed to be worse today.
I might end up taking it down to CSG or another local shop that is really familiar with 86's just to get a second opinion.
2much is offline   Reply With Quote
Old 03-24-2015, 04:11 PM   #483
JB86'd
JB86'd's Avatar
Drives: JAWS
This is something completely unrelated to what we're talking about, what you have is VVT noise, which is normal on the stage 1 tunes.
JB86'd is offline   Reply With Quote
Old 03-24-2015, 04:46 PM   #484
904FRSlow
904FRSlow's Avatar
Here is some data I logged if it helps...
Old 03-24-2015, 06:55 PM   #485
2much
I wanna go fast
OK i've logged some data, and posted to datazap. I really don't know what I am looking for.
This is about a 20 minute drive to get some lunch, it is mostly casual driving but I got some first, second, and a single third gear pull in. Did not reach redline in the third gear pull though.
Can anyone help me analyze?
http://www.datazap.me/u/cjh/first-lo...e?log=0&data=1
Old 03-24-2015, 11:11 PM   #486
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I had a raspy sound at 3200; turned to by a loose O2 sensor. No codes, just an annoying sound. All good now.
Sleepless is offline   Reply With Quote
Old 03-24-2015, 11:32 PM   #487
s2d4
s2d4's Avatar
IAM less than 0.5 most of the time, literally lost half of your timing.
Did you put in 87 or something?
Or really low e on e85 tune?
Old 03-25-2015, 02:33 AM   #488
904FRSlow
904FRSlow's Avatar
I only put in 93. Checked the MAF sensor and its fine. My friend thinks I might have a leak on one of the heads though.
Old 03-25-2015, 05:02 AM   #489
s2d4
s2d4's Avatar
Perhaps, get it checked out asap.
Old 03-25-2015, 03:00 PM   #490
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Here is the latest and greatest from Openflash for the people waiting for header shipment. Hopefully this time the port adviser is right.
Hey Josh
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Yoda (03-25-2015)
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 07:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 07:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 06:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 07:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
