#15 |
Drives: 2014 Scion FRS
dont our cars have an idle problem where RPM's will dip from time to time?
http://jalopnik.com/5948647/heres-ho...s-idle-problem i havent noticed mine dipping at all, maybe i just dont pay attention to it |
#16 | |
Hit the road and I'm gone
Thanks.
Slip, slidin' away.
#17 | |
Off Topic
I had actually been responding to Koa's post on his mixing room, not cars specifically. However, if you want a horn in a car check out Bill Fitzmaurice's autotuba, http://www.billfitzmaurice.com/AutoTruckTuba.html. You could possibly do a truck tuba laying down flat in the trunk. |
#18 |
Drives: 2013 White BRZ Limited
While the RPM drops are a minor problem, it's not as if I drive around blasting the system all the time. The engine is only effected at full volume with the gain at about 75%. My guess is the engine is just having to work harder to keep up with the alternator's power demands. I see quite a few questions on this post, I'll probably reply to the rest of them later today.
#19 |
My rpms drop about 200-250 often at idling with full current & draw from a 500/1.. witnessed on logs as well, go from ~760rpm to ~530-540rpm
Much more pronounced since I've installed perrin motor mounts. I am looking into a low cost solution for it.. unfortunately will probably still have to be a sub cell battery or hi-amp alternator as this car's system isn't very powerful |
#20 | ||
Hey, I do some music production too! ![]() What's this about paper cones? The images I've seen of the stock speakers showed poly cones and rubber surround... As long as I keep the gain low enough (which I always do), I don't see why 12s would be any more overpowering than any other system. |
#21 | |
The 2013 early HU scions had shit cones, someone want to chime in with specs or pics? I know the newer all-touchscreen HU's on the fr-s switched over to polys |
#22 |
BRZ FNG
Drives: 00 Civic LX/CWP or GBS BRZ someday
Yeah it's definitely not dropping idle due to amplifier draw, that's a $70 "1100 Watt" amp with a single 30A fuse. It's not going to put out anything anywhere near 1100W and a maximum 30A load (peak) shouldn't be dragging down a stock alternator.
#23 | |
#24 |
Drives: 2020 BRZ PP
Aren't the Sears gold batteries supposed to be a good alternative for the budget minded? I know they aren't exactly cheap but I've reasd good things about them.
I am running two Addictive Audio 10's off a Db drive 750.1 amp and components off a DB drive 75.4 amp that's bridged and I only really see a an RPM drop on really REALLY bass heavy songs. No headlight dimming at all. |
#25 |
Drives: 2014 Scion FRS [Asphault Grey]
Please don't say "brag" about rockford fosgate subs with a box that doesn't fit in the trunk and a boss amp...
...Now that that's out of the way! You dropping 500 RPM isn't because the subs are drawing too much power. I've got a about 250 watts RMS on my mids/highs and 2600 watts RMS on my 2 10"s in my FRS and, while I do get headlight dimming, I only see a drop of MAYBE 50 RPM (yes I meant 50, not 500) when the bass hits hard even at idle. I've run this setup with the stock battery as well as an optima yellow top that I upgraded to. Yes I'm still running the stock alternator while I wait for my custom 320a alternator to be built/shipped. It's probably something messed up with your wiring if anything or a deeper problem. Also, whatever you do, do NOT put a capacitor with your system. They are terrible for your cars electrical system if you don't have the alternator/batteries to support what you have and basically just work as a buffer to help with long power wire length. |
#26 | |
| FS - (2) BM mkIV Stereo Integrity 12" subs | AtlasMick | Audio/Visual, Electronics, Infotainment, NAV | 8 | 05-04-2015 10:11 AM |
| FS: Alpine Sound system PDX-V9 amp, 2 8" Type R subs SOLD | Kayzer Soze | Canada Classifieds | 1 | 08-24-2014 08:33 AM |
| Are the door speakers full range or just "subs"? | f0rge | Electronics | Audio | NAV | Infotainment | 6 | 07-22-2013 03:14 PM |
| 2 X 12" Subs, 2 X Amps and NOS | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 04-28-2013 10:38 AM |
