Old 03-24-2015, 09:41 AM   #29
bababooey
Drives: BRZ SWP Limited -6MT
Originally Posted by Simplicity View Post
So how long have you been doing that method and ever needed to replace the clutch or transmission?
previous vehicle lasted 80k+. the one before that I had for about 50k.
with these lower torque engines i tend to wind em up a bit to get em moving from a stop light/sign then settle into cruising speed. around town 4th or 5th fits that speed. youve gotta wait an extra second for the rpms in 2nd @ 5k to drop down slow enough to match that speed in 5th gear.
bababooey is offline   Reply With Quote
Old 03-24-2015, 01:39 PM   #30
Poodles
Drives: 2015 Series.Blue
Skipping gears doesn't cause any excess wear. In fact, Chevys have had a second gear lock out forever. It forces you to shift to 4th if you rev too high in first under light throttle instead of letting you into second. Most people disable the system though.
The Following User Says Thank You to Poodles For This Useful Post:
malave7567 (03-24-2015)
Old 03-24-2015, 01:49 PM   #31
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
If you're going under 17mph, and at <20% throttle, when you clutch in from 1st gear, it will lock-out second and third gear. Annoying, but it's how they defeat gas guzzler tax on the fifth gen manual SS Camaro, and how they advertise 17mpg in the city on the Vette. Thank goodness it's easy to disable with a $20 plug in.
I absolutely hated it on my SS... lol
malave7567 is offline   Reply With Quote
Old 03-24-2015, 01:50 PM   #32
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
??? Are you suggesting that you will cause excess wear on your transmission if you don't go in order? Lol.
Stang70Fastback is offline   Reply With Quote
Hearing a squeak whenever I accelerate and shift gears slowbrz Issues | Warranty | Recalls / TSB 7 05-29-2022 08:52 PM
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
shift indicator sticker Juurian Cosmetic Modification (Interior/Exterior/Lighting) 27 05-25-2013 01:03 AM
Shift position Indicator Ryan86 AFRICA 17 04-12-2013 07:24 AM
what does the rpm shift indicator beep sound like? pr086 Scion FR-S / Toyota 86 GT86 General Forum 10 07-26-2012 01:28 AM
