Old 03-22-2015, 06:03 PM   #645
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
My next step to combat the heat and the horrible oil pressure these cars have when they get hot. Trying out some new oil too.
Setrab 25-row oil cooler to upgrade my current 14 row. Non thermostatic sandwich plate will be reused as well. The core will be covered until I'm at the track.
The Racers Line is offline   Reply With Quote
The Following User Says Thank You to The Racers Line For This Useful Post:
Koa (03-22-2015)
Old 04-05-2015, 07:14 PM   #646
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Alright guys, any reason I shouldn't go with an oem coolant base oil cooler setup with my turbo kit? The price difference on the forester kit and the aftermarket ones is much to my liking. With FI my coolant seems steady at 90c/194f which is much lower than the 230 I seem to get lightly driving the car daily for 25-30min. The coolant based oil cooler would also help the turbo warm up in winter which is a plus I guess.
Also taking a bit from the new STi concept. Another way to cut the mustasche... the it would look much worse on the production brz since it isn't beveled as much.
Old 04-07-2015, 02:41 AM   #647
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
i just installed the seibon DV hood on my car and I'm pleased with how much heat it's letting out. You can literally see the heat radiating out now, and thats barely even pushing the car very hard.
For anyone that doesn't run a vented hood, I would highly recommend it.
I was always against vented hoods for cosmetic reasons, but the DV from seibon keeps the factory lines and the two large horizontal slits are large enough to act like a chimney.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 8 Users Say Thank You to protpibe For This Useful Post:
8686 (04-07-2015), BatStig (05-01-2015), blue cat (04-07-2015), Efferalgan (04-07-2015), GT86_PRAGUE (08-03-2015), Hyper4mance2k (06-02-2015), Sellout (04-09-2015), Subzero (04-07-2015), Xuningshen (04-28-2015)
Old 04-07-2015, 11:45 AM   #648
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I agree on the vented hood. That definitely was going to be the next step on my BRZ. A properly designed one has added venting and downforce benefits.
Old 04-07-2015, 01:25 PM   #649
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Getting mine sometime this month lol. Do these carbon hoods have holes to attach the gas struts or does the oem hood prop need to be used? I know they're all probably different so I was wondering about the Vis AMS hood.
Btw @protpibe your car is sick.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
protpibe (04-07-2015)
Old 04-07-2015, 03:49 PM   #650
protpibe
protpibe's Avatar
I'm running Grimmspeed struts and they bolted on fine to the Seibon hood. My assumption is that they would all work with one another since hood struts generally bolt directly on to the OEM hood, and aftermarket hoods share the same bolt holes.
And thanks for the compliment
Old 04-07-2015, 03:53 PM   #651
yomny
yomny's Avatar
I feel dumb I realized this after posting the question. Looked at some pictures of how mine were installed and they use the same bolt that holds the hood lol. Thanks for the reply.
Old 04-07-2015, 06:54 PM   #652
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Amazing build!! How your GrimSpeed hood struts work with the new bonnet? It should be roughly the same weight as the stock one, right?
Efferalgan is offline   Reply With Quote
Old 04-07-2015, 06:56 PM   #653
protpibe
protpibe's Avatar
They work fine. The seibon actually weighs more than the oem hood
The Following User Says Thank You to protpibe For This Useful Post:
Efferalgan (04-08-2015)
Old 04-09-2015, 08:16 PM   #654
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
That hood looks great!
Sellout is offline   Reply With Quote
Old 04-17-2015, 09:06 AM   #655
yomny
yomny's Avatar
Just installed my AMS hood.. carbon hoods are not my favorite look but it does well at releasing the heat and its the only one that I know of that has rain guards as it does rain a lot here in Miami
Old 04-17-2015, 10:36 AM   #656
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Hood and fender vents installed on @boostedfrs NASA TT FR-s
crazyfrenchbiker is offline   Reply With Quote
The Following User Says Thank You to crazyfrenchbiker For This Useful Post:
continuecrushing (04-17-2015)
Old 04-17-2015, 11:45 AM   #657
boostedfrs
Drives:
Ya ill let you guys know how big of a difference the hood vents make. The fender vents are not for heat. They are for relieving high pressure lift in the wheel wells
boostedfrs is offline   Reply With Quote
Old 04-17-2015, 07:01 PM   #658
sw20kosh
Drives: 2013 Black FR-S
You guys must like spending money...
We have solved our FI heat issues with a large oil cooler core mounted in the center in front of the radiator/condenser. 0 other modifications. 0 body work. 0 ducting. 0 aftermarket fan shrouds. 0 aftermarket fans. 0 crash beam delete. 0 anything else. Stock Radiator. Skid plate in place and un-modified.
https://www.google.com/webhp?sourcei...w%20series%209
Max temps: 210 F coolant, 218 F oil after 25 mins of hot laps at multiple tracks in winter and in summer. 60+ psi oil pressure to redline. 5w30. 2 cars with this setup have been running this for a year with 15+ track days.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
fred_boosted (11-01-2015), mkivsoopra (04-17-2015)
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 04:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
