Old 03-21-2015, 10:41 AM   #1
wparsons
wparsons's Avatar
"Best" (most flexible) oil cooler option?
Looking at oil cooler options, and am looking for input on what is going to be the most flexible kit.
Currently the car is N/A, but it might be FI in the future and I'd rather not have to buy another oil cooler when going FI if I can help it.
I like the Mishimoto kit because it looks like a good value, but it also looks like it won't work without a custom mounting bracket if there's an intercooler up front?
I don't like the JR kit because it's two different kits for N/A or FI (with their SC kit).
I'd prefer something that mounts in the bumper opening, not in front of the front wheels, and I need to keep the washer reservoir.
I was originally looking at the OEM style cooler, but I'm not convinced that it will keep temps down enough with FI with heavy track use.
Thoughts?
flickr
Old 03-21-2015, 11:13 AM   #2
brn12345
brn12345's Avatar
Have the Perin kit and it works great dropped oil temps significantly and was easy to install. Quality of the parts is very high.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
The Following User Says Thank You to brn12345 For This Useful Post:
Bahraini86 (03-23-2015)
Old 03-21-2015, 02:26 PM   #3
jflogerzi
jflogerzi's Avatar
Thoughts?
Most oil coolers will not keep temps in check on an FI car being pushed at the track. I would recommend searching. Your gonna need a ducted style and a pretty beefier core.
Old 03-21-2015, 02:36 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Robispec FTW.
Old 03-21-2015, 03:49 PM   #5
wparsons
wparsons's Avatar
I contacted Robi about getting one, and didn't get anywhere. Hard to buy one if the guy selling won't respond.
Is the mounting point for the Perrin in the way of an intercooler?
flickr
Old 03-21-2015, 04:02 PM   #6
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
If you do go FI, you will just have to mount the cooler further out a bit. I have a Vortech and a Mishimoto oil cooler and I couldn't use the mounting bracket it came with. I just mounted it on the plastic floorboard.
Tye300 is offline   Reply With Quote
Old 03-21-2015, 05:47 PM   #7
steve99
Drives: FT86
Thoughts?
If your going fi you will probably need upgraded radiator, as well as oil cooler, intergrated oil cooler unit like robispec
http://cms.skunk2.com/id/1085/Ultra-...ZFRS-Radiator/
DAEMANO (03-21-2015)
Old 03-21-2015, 09:12 PM   #8
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
JR cooler is just a different bracket and lines, same cooler for NA/FI. Most modular cooler to me, and thats what you asked for.
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following 3 Users Say Thank You to ck-GT86 For This Useful Post:
cactus (03-23-2015), DAEMANO (03-21-2015), wparsons (03-22-2015)
Old 03-21-2015, 09:13 PM   #9
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I have the vortech S/C, Mishimoto radiator, and perrin oil cooler. I installed them all at the same time, no issues. Just mounted the oil cooler to the plastic bottom (with large bolts and large washers underneath) all fits great and looks nice. Look at my build thread for more pics.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following 3 Users Say Thank You to Gopherboy6956 For This Useful Post:
DAEMANO (03-21-2015), Hawk77FT (06-09-2015), wparsons (03-22-2015)
Old 03-21-2015, 09:31 PM   #10
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You can even put together your own cooler. A Mocal T-stat Sandwhich Plate. Choose the exact cooler you want. Add a few -10 fittings and a decent length of oil lines. That way you can choose exactly what parts you want.
I haven't done it, but am just throwing it out there. I would personally do that with a Setrab 19 row core... when the time comes...
The Following 2 Users Say Thank You to boredom.is.me For This Useful Post:
DAEMANO (03-21-2015), Sportsguy83 (06-12-2015)
Old 03-21-2015, 10:30 PM   #11
AlexBinJackson
Drives: 2015 Brz Blue Series Pearl White
As for Robi I would stay away as a word of caution not trying to bad mouth just my 2 cents from past experience
AlexBinJackson is offline   Reply With Quote
Old 03-22-2015, 01:56 AM   #12
ck-GT86
ck-GT86's Avatar
Also, that oem style oil cooler is more of an oil temp regulator. It doesnt drastically keep temps down like the purpose-built coolers. i gathered 90% of the parts to get it together until i read more posts from those who actually benchmarked it. Save the $350 and get one that works
. ck
|| My Build Thread ||
The Following User Says Thank You to ck-GT86 For This Useful Post:
YouShallKnow (03-22-2015)
Old 03-22-2015, 11:40 AM   #13
boredom.is.me
Custom User Title
. ck
Explain?
Old 03-22-2015, 12:07 PM   #14
jvincent
jvincent's Avatar
Originally Posted by boredom.is.me View Post
Explain?
The OEM oil cooler is limited in its cooling effectiveness by the fact that it cools the oil to the temperature of the engine coolant. I have one installed and under normal driving conditions the oil temp is within 1 or 2 *C of the engine coolant.
In cold climates the OEM cooler also acts as an oil heater, since it raises the oil temp to match the engine coolant faster than normal.
I have not tracked with mine yet, but others have reported a modest improvement in on track temps, ~10 degrees reduction, on track and a faster cool down. However, the OEM cooler does not have enough heat exchange capability to keep the oil temp close to the coolant temp on the track so the oil temps will be quite a bit higher than the engine coolant. I am hoping for about 235-240 *F. This is probably fine for me since I am NA.
If you are going FI, then your temps will be considerably higher, so a dedicated air cooler, which is not limited by the engine coolant temp and where heat exchange is limited by radiator size are better options.
The Following User Says Thank You to jvincent For This Useful Post:
ck-GT86 (03-23-2015)
Trying to find the toyota factory "option pack" High rise spoiler. HELP! Hotlava86 Cosmetic Modification (Interior/Exterior/Lighting) 52 05-04-2014 03:02 AM
"back-seat-remove" option. Z_Rocks Scion FR-S / Toyota 86 GT86 General Forum 53 06-25-2013 04:24 AM
No "Edit Signature" option switchlanez Site Announcements / Questions / Issues 4 05-03-2013 06:33 AM
Dealer "Simoniz Glass Coat" option Bfly Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 18 09-16-2012 12:53 AM
