Old 03-21-2015, 12:06 PM   #15
FirestormFRS
Save your self lots of money and buy a resonator and have a local shop add it to the CBE. You can get a good vibrant for <$100.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
b rawr z (03-21-2015)
Old 03-21-2015, 12:11 PM   #16
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
Hmm. Ill have to research that then. Thanks.
b rawr z is offline   Reply With Quote
The Following User Says Thank You to b rawr z For This Useful Post:
FirestormFRS (03-21-2015)
Old 03-21-2015, 01:00 PM   #17
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I had a similar quote from a shop near me. If I bought the resonator, they would charge me an hour shop time to install @ $60 dollars an hour.
GotBRZ1691 is offline   Reply With Quote
Old 03-21-2015, 01:08 PM   #18
b rawr z
b rawr z's Avatar
I need to figure out where to get a quality resonator then.
Old 03-21-2015, 02:35 PM   #19
GotBRZ1691
GotBRZ1691's Avatar
http://www.summitracing.com/search/part-type/resonators
There are a lot on summit, do;t know how quality they are, but this is where I was looking.
I ended up just getting a newer, much nicer exhaust
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
Old 03-21-2015, 09:34 PM   #20
b rawr z
b rawr z's Avatar
Thanks. I'll check em out.
Old 03-21-2015, 11:25 PM   #21
Mkyl
Drives: Brz Limited
I wonder if the Inlet diameter have to be the same as the cbe which i think is 2.5" or a little bigger say 3" would work without any issue. The reason why i didn't get add the resonator was because of the inlet diameter; i could be wrong but i didn't want any rattling.
Mkyl is offline   Reply With Quote
Questions about Nameless Front pipe with Helmholtz Resonator Xdragonxb0i Engine, Exhaust, Transmission 67 08-28-2016 12:47 AM
Besides Nameless does anyone make a front pipe with HFC and resonator? btoast Engine, Exhaust, Transmission 20 05-29-2015 11:45 PM
wtb catted front pipe with resonator 86socal Want-To-Buy Requests 5 10-27-2014 02:15 PM
invidia front pipe resonated or no resonator? bdanisi Engine, Exhaust, Transmission 1 08-20-2013 01:24 AM
Anyone running a baffle resonator front pipe? swift996 Engine, Exhaust, Transmission 8 06-19-2013 04:41 PM
