Old 03-21-2015, 01:32 PM   #2423
xwd
I called a local Scion dealer up the street and the springs and swaybars are new options for the 2015, the website doesn't have performance parts as build options. Previously you could get the air filter or intake, but it looks like no one really looked into that one.
According to the guy I talked to, who didn't sound like a complete idiot, they are port installed options and the car is delivered to them with everything installed. Like simpleasbest said, dealer installed options usually have a disclaimer you may get charged more because the dealer WILL charge you to install them unless you negotiate it into the price of the vehicle. You can get them as just normal parts and have the dealer install them as well, it's the same spring and swaybar kit as has existed the last couple years. However, that would not be CS legal, you would have to prove you ordered the car with the parts on it.
Old 03-21-2015, 02:00 PM   #2424
simpleisbest
Senior Citizen
Drives: Scion FR-S
Correction: You only need to prove you CAN order the car with the parts. Perfectly legal to add the actual parts after yourself. Just go look up DS Mini S with JCW suspension or Corvettes with Z51 package. As long as the part was available for your make/model/year car as a Standard Part, you can run it. In our case its not a full trim conversion, just seperate line item optional parts.
simpleisbest is offline   Reply With Quote
Old 03-21-2015, 02:20 PM   #2425
MaxRED13
Novice Autocrosser
MaxRED13's Avatar
Drives: Scion FR-S Red//MT
SCCA Solo C Street Discussion
This all sounds like great info. There is another thread that documents he spring rates that people have gathered and that one showed the TRD springs as 3.5k/5.8k. Are those the Japan only TRD springs versus what we get here as the USDM TRD springs?
http://www.ft86club.com/forums/showthread.php?t=8739
MaxRED13 is offline   Reply With Quote
Old 03-21-2015, 03:56 PM   #2426
xwd
Yeah I kind of met for people with 2013/2014. The springs/swaybars are specifically NOT in the orderable options for those years.
The one sticky point I see is these are not Scion parts in any way, they are TRD parts and TRD manufactures them. I could see a "clarification" disallowing the use of them, but who knows.
Old 03-21-2015, 04:06 PM   #2427
simpleisbest
Senior Citizen
Drives: Scion FR-S
Screen print outs I have from the Scion Accessories Sales Guide say otherwise. Also, regardless of "brand", both kits have Toyota/Scion part numbers. Those part numbers are listed as port options in the Scion Assessories Sales Guide as valid port options (PPO is manufacturer speak for Post Production Options, which are clearly NOT dealer options) for all 3 model years of production to date.
Also, the part numbers are clearly labeled on the parts.
Old 03-21-2015, 04:38 PM   #2428
xwd
There has been some talk lately regarding this stuff since the last Fastrack there is an item to make all "Porsche Exclusive" parts legal for stock. Porsche is very ambiguous about what all is included under that label, it could almost mean anything because as long as someone pays Porsche enough they will do just about anything under that label.
One proposal was to add a rule so no option accessories could be used not allowed to be changed under other street class rules. I would be in favor of that.
Old 03-21-2015, 05:01 PM   #2429
simpleisbest
Senior Citizen
Drives: Scion FR-S
Good luck with that. It's too wide spread with almost all the Miatas in ES with R package conversions and Hard S packages, HS/DS Minis with JCW suspension parts, and Corvettes with Z51 packages.
Old 03-21-2015, 06:26 PM   #2430
xwd
Package conversion isn't really the same thing. I think it will have traction to be honest and after the whole Porsche Exclusive thing in the April Fastrack.
Old 03-21-2015, 07:14 PM   #2431
MPot
Drives: SSC #79
When I go to the Scion site, it gives me the option of building a 2014 or a 2015. The TRD Springs and Bars are available for both years.
The one interesting thing is if I select the Cold Air Intake, a pop-up says that it is a Dealer installed option.
I have a 2013, so I might be SOL anyway.
Mike
MPot is offline   Reply With Quote
Old 03-21-2015, 09:02 PM   #2432
xwd
Mike
I was just looking at a dealer accessory list. I thought I had saved a PDF of it but I couldn't but this is a list of them for all of Scion's cars. The publish date is 3/21/2015.
http://www.scionchulavista.com/scion...sories-pricing
Old 03-21-2015, 09:36 PM   #2433
MaxRED13
Novice Autocrosser
MaxRED13's Avatar
Does any one have any additional methods of proof we can use. It would be great to have something beyond the port order form to show at national level events. There's just so many 86 drivers in the San Diego area.
Old 03-21-2015, 09:41 PM   #2434
MaxRED13
Novice Autocrosser
MaxRED13's Avatar
That makes it look like it's only a 2015 option or am I wrong?
Old 03-21-2015, 09:44 PM   #2435
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
I dunno guys. Do we actually want this? If the springs are legal then aren't the TRD 18 7.5J +35 offset wheels legal, and the upsize rear sway bar legal? That would make a monstrous Hotchkis bar work a lot better too...
And then the FRS seems like a serious overdog in CS... A situation that wouldn't last long just based on the unbalance between it and the BRZ.
That said, I'm going to go buy all that and a short shifter on Monday. I knew buying a brand new car was worth it...
Cueman is offline   Reply With Quote
Old 03-21-2015, 10:39 PM   #2436
bslate3
Drives: 2015 CWP BRZ
If FRS owners get TRD springs then why can't BRZ owners get STI springs?
On another note, can we shave down the bumpstops in CS?
bslate3 is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
