Old 03-20-2015, 05:30 PM   #1
PNA
Drives: 2013 BRZ Sport-tech
Dead battery - can't open door with mechanical key!
My battery has died - I installed a Lukas-LK290 (to prevent battery from dropping past 12.4 V) and a dash camera with motion detect feature, and I guess I didn't do it right.
I had left a light on before and the battery couldn't start the car, but this time the battery is so dead that the doors won't open.
What's strange is that the mechanical key doesn't unlock the driver's door!
I can open the trunk, so at least I can get into the car to open the hood and jump it, but I'm wondering if there's any reason why the mechanical key isn't opening the driver's door.
Any ideas would be appreciated.
Also, I'm going to try to get a new (better - automatic version) battery - I have the battery that came with the manual version of the car (small capacity). I heard some success with this, what helps to get it?
PNA is offline   Reply With Quote
Old 03-20-2015, 05:40 PM   #2
bababooey
Drives: BRZ SWP Limited -6MT
from my single time experimenting with the physical key, it was difficult to open likely because you cant quite get enough leverage to rotate the darn thing.
bababooey is offline   Reply With Quote
The Following 2 Users Say Thank You to bababooey For This Useful Post:
Choco (04-27-2015), DarkPira7e (12-23-2018)
Old 03-20-2015, 05:45 PM   #3
PNA
I can rotate it - end to end - or at least it feels like it.
Old 03-20-2015, 05:48 PM   #4
Koa
did you try the passenger door?
Old 03-20-2015, 06:01 PM   #5
AznBRZer
Drives: 16 CBS WRX Limited
Put more elbow grease into it. The first time can be a little stiff and you'll notice a thump/click when it unlocks.
Sport Tech is the same as the Limited: only the driver's door has the lock.
AznBRZer is offline   Reply With Quote
The Following 2 Users Say Thank You to AznBRZer For This Useful Post:
JohnJuan (03-20-2015), Koa (03-20-2015)
Old 03-23-2015, 03:56 PM   #6
PNA
Well, you were right. It really required a lot of force!
Old 03-24-2015, 08:57 AM   #7
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
You need an aftermarket battery. The Subaru batteries are crap.
ntron1 is offline   Reply With Quote
The Following User Says Thank You to ntron1 For This Useful Post:
Choco (04-27-2015)
Old 03-24-2015, 02:36 PM   #8
Poodles
Drives: 2015 Series.Blue
Not this crap again... The stock battery is a Panasonic, it's fine. It's a high compression motor so it needs more power than most, so it's going to show a weak or low charge battery more easily.
The Following 2 Users Say Thank You to Poodles For This Useful Post:
Hyper4mance2k (05-01-2015), ntron1 (03-24-2015)
Old 03-24-2015, 02:38 PM   #9
stugray
Drives: 2013 GBS BRZ Limited
The real issue is that these cars draw a lot of current even when sitting off.
I calculated that if the car is left for ~10 days without starting it, the battery will run down.
Add the camera and thats probably more like 5 days. (Just a WAG)
The Following User Says Thank You to stugray For This Useful Post:
Chad86 (08-01-2016)
Old 03-24-2015, 02:42 PM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I must have a miracle battery. I went 2 months without a start. Then on 20 degree Fahrenheit day it fired right up. The cranking was slow. But it fired and the battery still lives today.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following 2 Users Say Thank You to Takumi788 For This Useful Post:
krayzie (05-01-2015), SirBrass (03-31-2015)
Old 03-24-2015, 02:53 PM   #11
stugray
The BRZ is worse than the FRS because of the keyless entry.
Old 03-24-2015, 05:19 PM   #12
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
It really is a weak ass battery. Like Stu said, mine sat for two weeks last month and it couldn't start. And the best part is I parked it front first into my garage....
jflBRZ is offline   Reply With Quote
The Following User Says Thank You to jflBRZ For This Useful Post:
ntron1 (03-24-2015)
Old 03-24-2015, 05:36 PM   #13
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
It's totaled.
Instagram: stimson
The Following 3 Users Say Thank You to Turbo95eg6 For This Useful Post:
2much (03-31-2015), Fastbrew (05-01-2015), Kevinn (03-25-2015)
Old 03-24-2015, 05:51 PM   #14
ntron1
Sarcastic Bastard
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 05:17 PM
Dead battery Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-07-2015 10:58 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 05:06 PM
BRZ LTD battery drain issue, can't stop open door beep DoomsdayJesus Issues | Warranty | Recalls / TSB 9 02-06-2015 07:05 PM
Is there any know that how to open the truck when the battery is dead?????? wilson0326 Scion FR-S / Toyota 86 GT86 General Forum 31 07-06-2013 10:24 PM
