Old 08-14-2014, 10:34 AM   #15
2thdoc
2thdoc's Avatar
Drives: Scion FR-S
where did you put the cutout?
2thdoc is offline   Reply With Quote
Old 03-15-2015, 08:13 PM   #16
Wyattkb
Drives: 2014 Whiteout FRS
Don't want to throw anyone under the bus, but let me make it clear. It wasn't me who said that.
Anyway here's a couple of pics from underneath the car.
Reviving this thread from the dead because I would like to see where you had this installed.
Anyway you can re-upload the pics?
Wyattkb is offline   Reply With Quote
Old 03-15-2015, 08:44 PM   #17
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
i would like to see as well!
andrew5826 is offline   Reply With Quote
Old 03-19-2015, 04:00 PM   #18
M-17
Ninja Cat Mod
M-17's Avatar
If I find the pictures, I will re-post them. I'm not sure what happened to the previous pics I posted before.
Old 03-19-2015, 04:09 PM   #19
Koa
Originally Posted by mad_sb View Post
Yeah, I have been thinking about having something made using a universal Varex... mainly for the early am and late night cold start... that first 30 seconds while the timing is at -10* and the throttle plate is open is just too loud for my taste, and is about to be even louder with a catless header. Once the idle kicks down it's fine.
Why not just tone down the cold start to -4 across the board and change the maf correction after start table to have rpms at a cool, easy 1400?
Old 03-19-2015, 05:13 PM   #20
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
All that's old becomes new again...
In the 60's they called these "dumpers."
keithr is offline   Reply With Quote
Old 03-19-2015, 08:45 PM   #21
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
not sure how this setup is but I made a modified front pipe using a weld in y pipe with a cutout and turn down. All 2.5 in with he cutout just under the driver seat.**I went with cheap eBay components but I only have 200 in the setup.Name:  ImageUploadedByTapatalk1426812304.907760.jpg
Size:  186.7 KBName:  ImageUploadedByTapatalk1426812326.915034.jpg
bee_are_zee is offline   Reply With Quote
Old 03-20-2015, 09:24 AM   #22
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
i got mine installed. chopped out the resonator in the mid pipe and welded it in
check it: https://instagram.com/p/0c1UyHRDyD/?taken-by=86guo
Old 03-20-2015, 09:27 AM   #23
Wyattkb
That looks very clean. Anyway you can post a larger picture of it? I'd like to show my fabricators an example.
Old 03-20-2015, 09:33 AM   #24
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
ask and you shall receive
Old 07-03-2015, 01:01 AM   #25
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
Thread revival, how did you wire it into the car?
KungFuWaffle is offline   Reply With Quote
Old 07-03-2015, 01:04 AM   #26
bee_are_zee
Drives: GBS BRZ
Through the shifter boot to under the center console.
Old 07-03-2015, 02:24 AM   #27
KungFuWaffle
Drives: Whiteout
Do you have a picture?
Old 07-11-2015, 09:04 AM   #28
bee_are_zee
Drives: GBS BRZ
Sorry. Didn't see this until today. I should be under the car today I will try and grab some pictures. Basically poked a hole in the corner of the rubber shift boot under the leather one and ran the wire along the side of the transmission tunnel using wire sticky pads to hold it in place.
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Crazy exhaust with complete electric cut-out Hawk77FT Australia Classifieds 10 12-23-2012 06:35 AM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
Electric Cars? Godzpeed Other Vehicles & General Automotive Discussions 16 06-25-2012 09:45 AM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
