Old 03-16-2015, 08:17 PM   #6147
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
car is going to Corner3garage for vacuum leak and belt swap to a Gates K061010 from a normal length one as I have a 70mm pulley. After the installation of the kit I got a bit lazy and just want someone to fix the issues
where are the common areas you guys see vacuum leaks?
mokinbird87 is offline   Reply With Quote
Old 03-19-2015, 02:37 PM   #6148
Dream20b
Y u do dis?
Well, i'm not sure if the answers have already been covered in detail (searching as I post), but what risks do I run by slightly overrevving a twin screw supercharger such as the 210 kit, IE, 70mm vs 72.5mm pulley?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 03-19-2015, 02:40 PM   #6149
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Probably some supercharger oil usage. Just rev it out to 7100 instead of 7400 and it should be ok.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 03-19-2015, 02:46 PM   #6150
Dream20b
Y u do dis?
Thanks!
I'm aware that lowering the rev limit will save some headaches but I want to get 285-300 RWHP with E85 but without going to a built engine or bigger SC unit. the car will (and does) see exclusively E70-E85 year round in Chicago weather. I drag race about 3-5 days a year. I refuse to go turbo due to having shit luck with every turbo car I've ever owned.
Dat Hot Lava Doe
Old 03-19-2015, 04:08 PM   #6151
s2d4
s2d4's Avatar
Lol
Old 03-19-2015, 06:12 PM   #6152
brianhj
Drives: 2017 Camaro 1SS
Does the engine sound different on E85? Or is it because I put the 69mm pulley on? Engine sounds harsher now, not as smooth as before, when I rev it. It sounded better before. Just trying to figure if it's my imagination, the fuel or the pulley making the s/c work harder.
Might run this tank low and put 93 back in and possibly go back to the larger pulley.
brianhj is offline   Reply With Quote
Old 03-19-2015, 06:28 PM   #6153
CK_Bladesmith
Drives: Raven FR-S
I run a 70mm pulley and 93 octane and my car does just fine.
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
Dream20b (03-19-2015)
Old 03-19-2015, 06:51 PM   #6154
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by brianhj View Post
No it's a Bluetooth kit, and the phone app isn't available yet
You can still view Ethanol content by logging the "Custom Map P" parameter in EcuTek. Going from 93 power is gradually added in with ethanol content. If you dump in E85 from an empty tank of 93 it's a much more drastic change. The engine can sound a tiny bit different running on ethanol, but not harsh. Could be your imagination, or you may have something going on mechanically, but the tune itself and Flex Fuel kit are unlikely to be causing any sort of issues in that regard. Can you log the ethanol content and report back?
Sincerely,
Zach
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
brianhj (04-03-2015), vaderbloke (04-01-2015)
Old 03-20-2015, 12:49 AM   #6155
dpgfunk
Drives: 2012 E92 M3, 2013 BRZ
Originally Posted by poorsche View Post
Should have specified: I have it, but have not serviced the blower with it yet. Anybody have ideas on how to get a temp reading of the blower for comparison? I don't know if oil temp or inlet air temp are good indicators. Maybe just take the surface temp before and after?
Interested to see the results of this. Have you had a chance to change the sc oil?
dpgfunk is offline   Reply With Quote
Old 03-20-2015, 01:22 AM   #6156
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
How many owners installed the kit themselves? I am not a mechanic by trade but am good with my hands. I don't like the idea of having to pay for something that seems so bolt on and the satisfaction of doing it myself would be great! How difficult is the install really?
[ame="https://www.youtube.com/watch?v=QaYt-rucF34"]Innovate Supercharger install on a Scion FRS - YouTube[/ame]
Chad86 is offline   Reply With Quote
Old 03-20-2015, 01:35 AM   #6157
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
Some of the instructions aren't perfectly detailed, but I can email you the latest install guide (or you can email SprintexUSA). I did the install myself and spent a few evenings doing it. I could do it again in 3-4 hours with basic hand tools.
I'd be more than happy to talk you through some of the steps if needed. You can do the first portion of removing everything in an hour or two.
R3NIK is offline   Reply With Quote
The Following User Says Thank You to R3NIK For This Useful Post:
Chad86 (03-20-2015)
Old 03-20-2015, 10:56 AM   #6158
xxscaxx
Drives: 2013 SWP BRZ
Its really simple. Everything is bolt on/off. The only part that requires you to do something other than take a bolt out or attach a hose is where you have to shave the alternator down slightly so it doesn't hit the supercharger. Besides that its very simple. I installed this in 4 hours (non intercooled before I went IC) without even rushing.
The "hardest" part would probably be placing the unit down as its a tad heavy and you have to basically hold it out in front of you to place it down. Wasn't a problem for me, but it may be beneficial to have a second person for that part.
Be quick about swapping the coolant hose on the back of the block to minimize your coolant loss, and de pressurize the gas lines by pulling the fuel pump fuse under the hood and letting the car die out. Those are the only few things I can think of that are nuisances.
Even if you aren't mechanically inclined, its simply the best way to learn about a car...just dive in and get to it. Once you do the install you will think how silly it was to even think about paying someone to install it.
Only plus side obviously to having a shop do it is if theres a problem its on them..but if you take your time you won't have any issues.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Chad86 (03-20-2015)
Old 03-20-2015, 11:23 AM   #6159
jwvand02
Drives: 2013 SWP BRZ Limited
Depends a lot on what your conditions are and how familiar you are with the car itself, also if you're buying the kit new or used.
I bought the kit used, did the stage 2, the previous owner felt safer using a relay for the water pump, and to top it all off I did it outside (in 30-40 degree weather) with my tools on a tailgate. Basically, the worst possible conditions with some significant extra complications thrown in. I'd say it took me well over 10 hours of work, if not more. I think I could do it again much quicker.
The instructions are so bad in spots that they border on wrong, and that fact meant that I spent a lot of time trying to figure out hose routing. Once I figured out that there are two breather hoses and two coolant hoses, and the two coolant hoses go to the throttle body and the two breather hoses go back to the intake, it really wasn't that complicated, but I'll be damned if that wasn't very clear to begin with.
I took it slow on purpose though, tested everything as I went, double triple and quadruple checked. You can't be too careful with a FI install. If you have a mechanically inclined buddy to help you drop the supercharger (or even better, a small engine hoist/crane) on top of the engine, you'll save yourself a lot of discomfort. That bastard is heavy.
jwvand02 is offline   Reply With Quote
The Following User Says Thank You to jwvand02 For This Useful Post:
Chad86 (03-20-2015)
Old 03-20-2015, 11:36 AM   #6160
brianhj
Can confirm, instructions are terrible. Did the install myself. Definitely replace the plastic hose fittings with brass ones posted earlier in thread. Have extra hose clamps handy. Have extra hose handy (assorted sizes). The brass replacement barbs require larger ID hose unless you really muscle the hose on there. But then it's a gigantic PITA if you ever need to remove the charger or hoses. I also had to buy anaerobic flange sealant (gasket maker) and plastic hose couplers. I wanted to do it right, with the right size hoses and the right size clamps.
If you have any questions feel free to ask. I've installed it three times now.
The Following User Says Thank You to brianhj For This Useful Post:
Chad86 (03-20-2015)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
