Old 05-18-2012, 09:36 PM   #1
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Tinting Question
I've got an appointment to have my windows tinted on Tuesday. Usually the tint shops say not to roll the windows down for a bit just in case. However, our windows roll down slightly when we open the door.
Im curious, does that issue pose a problem?
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following 2 Users Say Thank You to civicdrivr For This Useful Post:
benjoke (06-22-2012), RiskyTrousers (05-19-2012)
Old 05-18-2012, 09:53 PM   #2
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Pull the power window fuse
michaelahess is offline   Reply With Quote
Old 05-18-2012, 10:56 PM   #3
Julio86
Julio86's Avatar
Drives: 2013 Scion FR-S 6MT
Great question. Never thought about that.
I don't always drift every corner, but when I do, I drift FRS . Stay drifty my friends
2013 Scion FRS Whiteout 6MT
Julio86 is offline   Reply With Quote
Old 05-18-2012, 11:18 PM   #4
LostTHEbeat
First 86
Drives: 2004 Scion xB
This. Although, we did not do this with our car, which was tinted 3 days ago. Oops!
LostTHEbeat is offline   Reply With Quote
Old 05-19-2012, 12:41 AM   #5
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
So what would happen if you roll the windows down while its drying?
RiskyTrousers is offline   Reply With Quote
Old 05-19-2012, 01:47 AM   #6
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
My bmw 128i does this also since the windows are frameless but it did nothing to the tints so dont worry
FutureFT86 is offline   Reply With Quote
Old 05-19-2012, 03:38 PM   #7
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Thanks guys. Ill also run it past the tint shop before they start to see what they recommend. Worst case scenario, Ill pull the fuse as mentioned above.
Parting out HERE
Old 06-02-2012, 09:33 PM   #8
mixminus
Pulling the fuse will not work. Car has a fail safe even if you pull the fuse. Final resting place of the closed window is above the hard frame of the roof. You would break the window opening the door if it didn't' operate correctly. So even with the fuse pulled it will go down when opening but it wont go back up closing the door.
Keep it simple.
Open door. Push the button above the latch on the door frame that senses the door being closed. Window will go up all the way with the door open. Tape button down and install tint. Remember to remove tape before closing or bad things will happen
mixminus is offline   Reply With Quote
Old 06-02-2012, 10:13 PM   #9
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Or you can just remove the screw that holds the sensor in place. The window will stay rolled up until you reinstall the screw.
kmbkk is offline   Reply With Quote
Old 06-03-2012, 05:00 AM   #10
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I must've updated a different tint thread, but......
I asked the tint shop what would be best. They said dont worry about it. I didn't, and the tint looks perfect.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post:
Dang Lad (07-04-2012)
Old 07-04-2012, 12:31 PM   #11
poudre
Drives: Silver Limited
Any reputable tint shop knows how to handle this.
poudre is offline   Reply With Quote
Old 07-04-2012, 01:03 PM   #12
jarviz
jarviz's Avatar
Drives: Raven FRS MT
I just told the tinter/owner that my car does that. They said "okay, don't worry about it" sure enough the tint came out perfect. Even when it rolled up and down everytime i closed/open the door the rest of that day.
jarviz is offline   Reply With Quote
Old 07-04-2012, 01:46 PM   #13
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Here's how we figured it out when my windows were tinted:
For some reason the door switches on the BRZ are handled differently from usual. But just unplugging the switch doesn't raise the windows. They must be in the raised position when the switch is disconnected for them to stay up. It might be a CAN-BUS thing.
Open the door and press the door switch in, the window should roll up completely.
While holding the switch in, remove the bolt holding the switch to the body. This will cut the ground.
Now you can release the switch and tape it in place so it won't fall out.
When your tint has cured, reverse the process; hold the switch in, replace the bolt, then release the switch.
Old 07-04-2012, 07:22 PM   #14
ragingSPAM
Photojournalist
ragingSPAM's Avatar
Drives: Firestorm FR-S, EG8 civic
If a tint shop is good then they should be able to lay the tint below the window line on the bottom so when it rolls up or down that .7 inch the tint should not be affected by much...in california its illegal to have your front windows tinted anyways :happy0180:, but in case you are going to do it make sure they lay the tint out below the weatherstrip
ragingSPAM is offline   Reply With Quote
Question jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 9 10-23-2020 11:31 AM
BRZ Taillights - What do you think about tinting them ? ShoGun Cosmetic Modification (Interior/Exterior/Lighting) 37 09-26-2014 02:26 PM
Question for BRZ and GT-87 hps? west2k95 Scion FR-S / Toyota 86 GT86 General Forum 276 03-13-2012 10:45 PM
