Old 03-02-2015, 11:17 AM   #631
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Anything on combating the heat. I think its pretty clear we could all use an oil cooler.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
CSG Mike (03-02-2015)
Old 03-03-2015, 07:02 AM   #632
AJPG
Drives: 22RE, FA20, 4G63
Originally Posted by yomny View Post
Anything on combating the heat. I think its pretty clear that most of us could use an oil cooler.
Agree. Until last weekend I though it was a must have for everyone, but after seen my uncle driving (BTW it wasn't extremely low speed, more like normal people driving on regular car), and no heating problems...
So maybe most of us will need oil coolers, bigger rads, vents, WMI... It will depend on how you use your car. That been said, there is no one unique solution for everyone.
That I take the overkill route? Well better safe than sorry
AJPG is offline   Reply With Quote
The Following 3 Users Say Thank You to AJPG For This Useful Post:
CSG Mike (03-03-2015), Yobiwan (07-13-2015), yomny (03-03-2015)
Old 03-18-2015, 12:52 AM   #633
Lonewolf
Lonewolf's Avatar
Drives: Moped
Any more people running fender vents of any type/construction?
I know @Lunatic has some, and a handful of others, but I don't see too much said about them.
Old 03-18-2015, 04:26 AM   #634
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
I am, and our shop car is.
I was going to run the Prova vents on my FRS anyways because I prefer the look to the "86" logo on the fender. When I proposed the idea to my boss for the shop car to add real vents while installing the Prova ones, he liked the idea.
I ended up doing a lot of work to the shop car all at once, including wrapping the headers. I went and test drove the car after performing the work, and smoke burning off the wrap was blowing out of the newly cut fender vents quite ferociously. So I can't exactly say how much airflow or heat is getting sent out there, since nothing has been tested, but it at least works to an extent.
Here it is on my personal car:
The Racers Line is offline   Reply With Quote
The Following 5 Users Say Thank You to The Racers Line For This Useful Post:
GT86_PRAGUE (08-03-2015), Lonewolf (03-18-2015), Thatguyjeremy (03-18-2015), Tye300 (03-21-2015), yomny (03-18-2015)
Old 03-18-2015, 06:47 PM   #635
yomny
yomny's Avatar
Damn I'm very very close to cutting holes in my hood.. can't get over the fact that i don't like the carbon hoods and color for this car and the vents on most still have the same risk or potential issue of allowing water to get all over my hot downpipes and turbine housing.
Old 03-18-2015, 06:59 PM   #636
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I'm close too...just need a free weekend
Old 03-18-2015, 07:32 PM   #637
Lonewolf
Lonewolf's Avatar
Drives: Moped
Thank you. Any shots from the inside of the fender or with the hood open?
Old 03-18-2015, 09:46 PM   #638
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
My fender vents. They work really well.
Lunatic is offline   Reply With Quote
The Following 7 Users Say Thank You to Lunatic For This Useful Post:
chaoskaze (10-26-2015), JustBoostin (04-05-2015), Lonewolf (12-23-2021), spitfire481 (03-19-2015), The Racers Line (03-18-2015), Tye300 (03-21-2015), yomny (03-19-2015)
Old 03-19-2015, 01:55 PM   #639
yomny
yomny's Avatar
Any how-to's?
Old 03-19-2015, 04:06 PM   #640
s2d4
s2d4's Avatar
Any how-to's?
Dremel, fender, template, cut
Old 03-19-2015, 05:09 PM   #641
Jetbill
Drives: 2013 FRS, 2014 BMW 335 M-Sport
Here's mine using stock fender 86 fender garnish modified with a vent. Name:  ImageUploadedByTapatalk1426799319.997231.jpg
Size:  280.7 KBName:  ImageUploadedByTapatalk1426799358.019923.jpg
Jetbill is offline   Reply With Quote
The Following 11 Users Say Thank You to Jetbill For This Useful Post:
continuecrushing (03-23-2015), Hyper4mance2k (06-01-2015), Kiske (04-09-2015), Lonewolf (03-20-2015), LucidMomentum (04-07-2015), R2RO (10-04-2015), sroby (12-15-2020), Target70 (03-19-2015), Tye300 (03-21-2015), Xuningshen (04-28-2015), yomny (03-21-2015)
Old 03-19-2015, 05:41 PM   #642
Lunatic
Lunatic's Avatar
That's about it. I used a dermal to cut out the plastic BRZ vent, and a metal cut off wheel to cut out the steel fender. I used double sided tape to attach the painted screen to the fender insert and then double sided tape again to attach that to the fender.
The Following User Says Thank You to Lunatic For This Useful Post:
yomny (03-21-2015)
Old 03-20-2015, 06:49 PM   #643
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
Does the double sided tape seem to be holding up well?
'13 Lightning Red BRZ
Mods: Grimmspeed Cold Air Intake|FT86SpeedFactory Stage 2 Tune|FT86SpeedFactory Catted header|Nameless Catted and Resonated OP/DP|Perrin Resonated Cat-back|
quicksilver30 is offline   Reply With Quote
Old 03-20-2015, 07:08 PM   #644
Lunatic
Lunatic's Avatar
Yes, holding up very well.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
