Old 03-17-2015, 08:49 AM   #113
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by Iwannajag View Post
Are you running your Spec86 config? How competitive is it with that setup?
Yup we will be running the Spec86 in TTD, PTD and Spec86 this year. It should be fairly competitive.
-mike
AZP Installs is offline   Reply With Quote
Old 03-27-2015, 05:16 PM   #114
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Am I correct that this link is for the latest classification rules for B-F ?
https://nasa-assets.s3.amazonaws.com...1--1-15-15.pdf
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 03-27-2015, 05:36 PM   #115
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Yup.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T
phastafrican is offline   Reply With Quote
Old 03-27-2015, 06:13 PM   #116
Deep Six
Deep Six's Avatar
Two more questions:
EL catless header, catless front pipe ,catback exhaust: 8pts or 5 ?
Minimum competition weight before points assessed?
[SIGPIC][/SIGPIC]
Old 03-28-2015, 01:25 AM   #117
phastafrican
Originally Posted by Deep Six View Post
Two more questions:
5pts.
2885lbs for the car. Can apply any left over points to weight reduction.
Old 03-28-2015, 07:28 AM   #118
Deep Six
Deep Six's Avatar
Originally Posted by phastafrican View Post
5pts.
Holy Crap! My car weighs 2610 with a full tank of gas.
[SIGPIC][/SIGPIC]
Old 03-28-2015, 09:19 AM   #119
phastafrican
Base weight includes driver at whatever fuel level you come off track. So you'll have to take points for whatever the weight difference ends up being. I'd assume around 7pts for somewhere around 110lb difference. (Just from memory)
Old 03-29-2015, 02:53 PM   #120
phatfil
Drives: 13 FR-S Asphalt
Originally Posted by JustDoItMikey View Post
My current setup / planned setup is as follows.
Current = 13:
Conti Dry / R7 +6 (2 point credit for using 225)
Non-BTM Struts +3
Non-BTM Springs +2
Non-BTM Calipers +2
Planned = 5:
Non-BTM Exhaust +5
Tune +0
Keep in mind I am new to all this and have very little testing time in that setup, but if you are trying to stay in the base class that really is the most logical build. We are limited to 200 hp, I think, so there isnt a whole lot to do to the engine besides exhaust and tune to free up torque. Suspension is a must and you can put together a great package for the 5 points. After that its a question of how many points you want to spend on tires and what to do with those few remaining points.
After just running my first weekend on the current setup I will say it felt great. Still trying to get a feel for everything (first time on R-comp let alone full slicks...) There is still a million adjustments to be made to get everything out of the setup but as a starting point it seems solid. Obviously things vary from track to track so what may work for me could be useless for you.
225 is a 4 point credit
Hoosier R7 is a 10 point tire
Conti sport car challenge EC-Dry is a 8 point tire
phatfil is offline   Reply With Quote
Old 03-29-2015, 04:31 PM   #121
AZP Installs
We are going with R6 or Contis due to the 8-4=+4 net for our setup.
-mike
Old 03-29-2015, 04:53 PM   #122
sstfnv
sstfnv's Avatar
I will be racing in TTE. The car is completely stock with 225/45/17 Direzza Z2 star specs. I only have a forester XT oil cooler and OFT Stage1 tune. Not sure if I will be very competitive but I hope to have some fun without breaking the bank and keep the car streetable.
sstfnv is offline   Reply With Quote
Old 03-29-2015, 05:05 PM   #123
THEmailman
Drives: Raven 6MT
The car is base classed in TTD so not sure how you're getting it downgraded a class. ...
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 03-29-2015, 06:50 PM   #124
sstfnv
sstfnv's Avatar
tires for TTD base class are 245. I'm going with 225 and getting 4 points back so going down a class.
Old 03-29-2015, 07:17 PM   #125
Iwannajag
Drives: 13 FR-S whiteout / blue w2w
Does not work that way. Can't go less than base class. Only up if you have more than 19 points
Iwannajag is offline   Reply With Quote
Old 03-29-2015, 07:28 PM   #126
sstfnv
sstfnv's Avatar
I could be wrong but according to the nasaforums and the TTB-TTF class calculator it does work that way.
Class calculator spreadsheet: https://nasa-assets.s3.amazonaws.com...2015_v1.4.xlsx
Thread in nasaforums: http://nasaforums.com/viewtopic.php?p=489425#p489425
Another one: http://www.nasaforums.com/viewtopic....456887#p456887
Official TT results(see TTE): http://timingscoring.drivenasa.com/N...%20Day%201.pdf
Lets talk lug nuts Ibanezboy21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-23-2014 03:42 PM
Lets talk tires... frs10 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 10-04-2013 05:21 AM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 04:13 PM
Lets talk exclusivity whitejdm BRZ First-Gen (2012+) — General Topics 33 02-15-2012 01:17 PM
Lets talk weight KaliKev Scion FR-S / Toyota 86 GT86 General Forum 63 09-12-2011 12:05 AM
