Sam Strano
Old 03-14-2015, 01:27 PM   #2367
xwd
Sorry in advance for the shameless foresale ad.
I am likely going to sell my 17x7 +42 Velox PG-5S rims since I've moved onto STX at this point. I have five of them, I bought the fifth one when they were down to two wheels left. These are forged and on my scale they weigh 13.8lbs. They are discontinued and haven't been made in several years.
The paint finish on these rims isn't the greatest so they have a bit of flaking at this point, except the 5th one which is brand new. I'll take some better pictures. They actually look very good on a DGM car IMHO. I was going to ask $1100 plus shipping for them. This is for 5 wheels.
Old 03-14-2015, 11:22 PM   #2368
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I'm heading to a local event tomorrow and realized I have only a vague idea of what tire pressures to shoot for on my just purchased 235/40 17 star specs. I'm guessing I'll end up somewhere mid 30's give or take, but if anyone has actual experience on these tires in this size I'll happily take recommendations.
Car is a '13 FRS. Only other current mods are camber bolts, cat back, and et42 wheels.
Briankbot is offline   Reply With Quote
Old 03-15-2015, 04:05 PM   #2369
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Had our first event of the year today. 40's windy, rained the day before so pretty much not the best conditions but it was a lot of fun. The course layout was nice imo and contained sections where you just have to straight up trust the car/setup. I was on the limiter for what felt like eternity on the back slalom and with the added dips and puddles it was certainly a challenge. We had a ton of twins competing, not sure how many are here but I believe I might have finished 3rd in class. I know jonesey battled a very good drive in a rx8 for the lead and I was a little less than a second off their pace.
Set up:
Koni, a hair from full stiff front, 90 degrees from full soft rear
215/45/17 Rs3s V2 37f 35r
Camber bolts
Stock Bar
Track Pipe.
[ame="https://www.youtube.com/watch?v=KMdmstLRb8E"]MSNE 03.15.2015 - YouTube[/ame]
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 03-15-2015, 09:02 PM   #2370
jonesy
jonesy's Avatar
Drives: 2010 Corvette GS
Set up:
Camber bolts
Stock Bar
Track Pipe.
Glad we were done after the second heat, I couldn't feel my toes! Not sure where I ended up, fastest run had a cone. Good to get the rust off, I'll be back at Metlife on 4/4, but probably in the gf's FoST. Video:
[ame="https://www.youtube.com/watch?v=CrcBSIlVgH8"]MSNE Autocross 3/15/15 C Street Subaru BRZ - YouTube[/ame]
Matt
#73 GS Focus ST/#82 STX BRZ
jonesy is offline   Reply With Quote
Old 03-15-2015, 11:54 PM   #2371
cjd
cjd's Avatar
Drives: 2017 BRZ
Hah.camera angle on the side by side changed just enough between the two I was able to view the surroundings in 3d... Brains are weird! I can't wait for things to get started here.
Old 03-16-2015, 07:40 AM   #2372
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Nice to meet you. Based on the video I Def lost time on the back turn around. I took it slower and tighter which clearly wasn't faster. Nice driving.
Old 03-16-2015, 01:54 PM   #2373
bslate3
Drives: 2015 CWP BRZ
This was my best run good for first in CS with the Texas Region SCCA. Driving tips and comments appreciated.
I'm coming from a WRX so I'm starting to get the idea of a RWD momentum car. Gotta get on the gas sooner and don't use the brakes! Lol
SCCA #1 TMS:
bslate3 is offline   Reply With Quote
Old 03-16-2015, 03:00 PM   #2374
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
SCCA #1 TMS:
I'd bet there is at least 2/10ths of a second left between you and the left side cones. In other words, you should be closer to the cones to reduce times. There were a few in there that were good placement, but when you can see 6 inches of pavement between the cone and the car in a slalom, there is time to be had there.
I find the easiest way to recognize issues is to watch the videos between each run. Then you can adjust your next run slightly.
Nice job on 1st place though. It is always exciting to do well.
Cheers,
Chris
bimmer635csi is offline   Reply With Quote
Old 03-16-2015, 03:46 PM   #2375
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
SCCA #1 TMS:
That might have been the smoothest brz run I have seen. You can def get more aggressive with the car IMO. Nice driving.
Old 03-17-2015, 08:25 AM   #2376
bslate3
Thanks for the advice. I'll be more aggressive with the throttle next time. I'm just now learning to throttle steer my way thru the tight 180's.
Old 03-17-2015, 09:14 AM   #2377
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
What pressures did you end up running? What were your impressions of the tires and how'd they perform? I've got pretty much the exact same setup, and have my first event coming up in a few weeks.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 03-18-2015, 03:26 PM   #2378
hukdizzle
Drives: 2013 Subaru BRZ (WRB)
Hello to all! Just picked up a BRZ and plan to prep it for CStreet and was hoping to get some opinions on what tire dimension seem to be preferred. Are we stuffing 245/40's on or going with something thinner like a 235/40 or 225/45?
hukdizzle is offline   Reply With Quote
Old 03-18-2015, 05:00 PM   #2379
qoncept
qoncept's Avatar
Read the last 20 pages of this post to find out.
Short answer: Yes. Stuffing 245/40's on or going with something thinner like a 235/40 or 225/45.
qoncept is offline   Reply With Quote
Old 03-18-2015, 05:09 PM   #2380
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
I personally went with 215 rs3s last year because I got the car mid season and wanted something cheap but competitive. This yea I am thinking of going 235/45 stones or 225/45 rival s. What is everyone's opinion on the taller 235/45?
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
