#85 | |
Drives: 12' Evo X , prior 1st 86 FR-S
Rpm - Mph
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few: 12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi, 08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV |
| The Following User Says Thank You to MarkRacerX For This Useful Post: | Dadhawk (05-18-2012) |
#86 |
Drives: '06 AM V8V Coupe
That's interesting, the 70mph fuel economy is really shitty...in fact, I have a hard time wrapping my head around such a huge drop from 55 to 60. Pekingduck said he was getting 39mpg at 70 in the manual transmission!
48-49 sounds about right for 55 considering the gearing, but 60 and 70 are just completely off. Given the expected load increase and considering the increased efficiency due to increased load, 60 shouldn't be that low. Just punching in 48/(12/11)^3 (aka, zero rolling resistance and constant engine efficiency) gives 37. Makes me wonder if there's something wrong with your car! |
| The Following User Says Thank You to serialk11r For This Useful Post: | Dadhawk (05-18-2012) |
#87 |
I'm second guessing the 55 shot, honestly. I'm wondering if I was in a slight incline or something. One thing I did notice is the MPG can vary widely at the same RPM even tough speed isn't changing if you are going up/down a small incline. I'll try that one again if I get a chance. It did hold there for at least 30 seconds though, and the road was relatively flat.
#88 |
First 86
Drives: Scion FRS Argento Automatic
On my Lexus IS 250 which has essentially the same auto, 6th gear usually comes in at 55 mph so I'm not surprised by that mileage.
Life is short...NO BORING CARS |
| The Following User Says Thank You to russv For This Useful Post: | Dadhawk (05-18-2012) |
#89 | |
#90 |
Yea, could've been a slight slope or something like that, but those numbers are still really weird. The only one that seems about right is the 55mph reading, on a completely flat road. I feel like 60-65mph shouldn't be causing that big of a drop overall, maybe like low 40s mpg. If Pekingduck's reports are correct, I'd predict ~42 mpg trip average going about 70, locked in 6th gear of course.
#91 |
Drives: N/A
That's actually not too unrealistic, Cereal, but I'd like to hope that something was off at 60 and 70mph. Possibly timing retard under load?
Dadhawk, what's the earliest it shifts into OD? I have a feeling it'll hit 50+MPG if you could get it into 6th at 35mph or even 45mph.
#92 | |
Anyhow, it seems a bit unlikely that they would intentionally design the engine to start retarding spark timing this early and then intentionally giving it these tall gears which would cause a significant drop in efficiency...if that's the case though, then maybe this is a good reason to start looking into E85 conversion? The Cobb dyno run showed it running rather rich, maybe the high compression ratio combined with suboptimal fuel is limiting the power...perhaps E85 can allow aggressive spark timing and closer to stoichiometric AFR.And Dadhawk, thanks again for providing the community with some info
#93 | |
#94 | |
First 86
I do wish 5th and 6th were taller in the MT. At 70mph I'm doing 3,000 rpm. Still, even if the computer is off a bit I'm averaging 27mpg since pickup yesterday.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch |
#95 | |
Drives: N/A
I wouldn't assume it's retarding timing without actually looking at the ECU readouts, it's just a thought since the MPG doesn't seem to correlate with the increased load. It could be entering enchrichment too, though I doubt it. Then again, I don't program ECUs. I do know that ATs operate at higher loads than MTs.And yes, Cereal. I am still thinking about E85 conversions but I'm trying to keep it low key while I'm just doing research. There is another E85 guy here that I am kind of competing with. I don't want to lose.
#96 |
Its possible although they were all on the same stretch of road within a few minutes of each other, heading due West the entire time.
#97 | |
#98 | |
Drives: N/A
| The Following User Says Thank You to Allch Chcar For This Useful Post: | Dadhawk (05-19-2012) |
| Tags |
| dadhawk, first86 |
