Old 03-13-2015, 12:43 AM   #15
torqdork
torqdork's Avatar
Drives: RV-7
After looking at your garage, the two things that I'd consider first are swapping the tires and wheels for something smaller and lighter. From what info is available, the tires weigh 29 lbs., wheels are also 29 lbs. per corner. That's a lot of unsprung rotating mass to get moving.
If they fit, I'd be going for 16", no bigger than 17", and max width of 225's. Most likely you'd save over 20 lbs. per corner, something you'd notice in every performance aspect of the car. It might not meet your visual needs, but after selling the existing setup the net cost would be less than regearing with better overall results.
torqdork is offline   Reply With Quote
Old 03-13-2015, 12:43 AM   #16
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Originally Posted by TRD_Demon527 View Post
I upgraded to EBC brakes and rotors changed to the wrx 4piston calipers in the front. I stop on a dime. My suspension is coilovers swaybars strut bars and various components. The list of stuff done so far is posted in my garage with the photos.
Sounds like a great start. In that case I highly recommend an oil cooler.
Engines get toasty on the track.
Perrin or mishimoto are good options. I have the mishimoto myself and a koyo radiator. Stock rad is fine for na but I wanted to stay cool when drafting.
FRSfan111 is offline   Reply With Quote
Old 03-13-2015, 12:45 AM   #17
jdmblood
jdmblood's Avatar
Drives: white subaru brz
Pros:
-reliability
Cons:
-no power lmao
-very expensive
jdmblood is offline   Reply With Quote
Old 03-13-2015, 12:46 AM   #18
TRD_Demon527
TRD_Demon527's Avatar
Drives: 2014 scion frs , 1987 toyota supra
I like the wheels n tires n I only use them for track days n autocross. Reason they have been on for the past few days is to break them in. For the weight and width it works for me. I normally use the stock wheels for daily use.
TRD_Demon527 is offline   Reply With Quote
Old 03-13-2015, 12:49 AM   #19
TRD_Demon527
My next batch of upgrades will end up being all about cooling and sir displacement. I'm getting a thermostatic oil cooler sandwich and I have a cooler. Just need to make lines.
I'm making a front splitter. Nothing crazy I want to upgrade the radiator and reduce the temp.
Old 03-13-2015, 02:54 AM   #20
FRSfan111
Koyo radiator works wonders. Priced competivly, direct oem fitment, and about 3 times the size of the original radiator. Took 2 full bottles of Subaru blue coolant and a bottle of water wetter once all the air bubbles were worked out. Only sad thing isn't our radiators aren't visable as the heater core sits in front of them then my oil cooler. Inside the engine bay they sit under the core support lol. So only visable from just the right angle if the hoods up. Sneaky though!
Old 03-13-2015, 03:07 AM   #21
TJ3000
Drives: MT Raven Black FRS
There's a whole lot more mods for N/A than you probably thought
Here's a few more...
-Throttle Body
-Balanced Crank Shaft
-Final Drive Ratio
-Stroker Kit
-High Comp Pistons (But comp is high enough)
-Oil Cooler
-Bigger Radiator
My question though is why do you want power if your going N/A? For a 4 cylinder car with not much torque if it's N/A your building the goal is Mid Range Punch Quick Revs and Balance not power.
TJ3000 is offline   Reply With Quote
Old 03-13-2015, 03:08 AM   #22
TJ3000
I forgot to mention changing your fuel injectors and fuel pump too.
Old 03-13-2015, 01:08 PM   #23
donoman
donoman's Avatar
Drives: '13 FR-S
Dont do it!!! Put that money into your daughters college fund. Or just buy a faster car.
Reason: you'll never get your money back on mods. You can get your money back on faster cars. And the mods you're gonna need to get more power are pretty involved.
donoman is offline   Reply With Quote
Old 03-13-2015, 01:12 PM   #24
TRD_Demon527
My daughter has a age fund already. And I tend to keep the cars I build or restore.
Old 03-13-2015, 01:14 PM   #25
adamg
Drives: brz
Its not all about the money/investment. for some of us its about doing something different and having fun while doing it. Its also about the learning experience.
adamg is offline   Reply With Quote
Old 03-13-2015, 01:22 PM   #26
TRD_Demon527
👍👍👍 nailed it right on the head @adamg
Old 03-13-2015, 01:32 PM   #27
gramicci101
Off Topic
You're pretty much there for NA, other than a header. Get a catless header, flash for stage 2 with BPBs, and you're good to go. Beyond that, you start getting into ethanol, flex-fuel systems, and engine internals.
You can also lighten the rotating mass. Flywheel, driveshaft, wheels and tires. Those will really change the response and feel of the car, because you can put more of the power you do have to the ground.
Old 03-13-2015, 01:34 PM   #28
TRD_Demon527
I am in the market for a header actually. Just don't kno where to go at the moment
Pros and Cons of the Rocket Bunny Kit VroomVroom86 Cosmetic Modification (Interior/Exterior/Lighting) 28 11-07-2014 01:29 AM
Colour options - pros & cons Sanzie99 Scion FR-S / Toyota 86 GT86 General Forum 44 07-03-2014 12:07 AM
Greddy vs avo stage 1 Pros and cons of each SliverBrz Forced Induction 90 04-18-2014 10:45 PM
KW V3's pros & cons Shaolin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 02-25-2014 09:58 AM
