Old 03-13-2015, 12:21 AM   #295
JB86'd
JB86'd's Avatar
Drives: JAWS
Originally Posted by Phantobe View Post
Damn this tuning stuff is starting to become frustrating lol.
91 Chevron - Tuned with some timing pulled
Everything looks great for like 2 weeks IAM hardly drops below 1.0. Now all the sudden another week later im getting 3 degrees of timing pulled & IAM drops to .49!
@JB86'd since we both are running the same shitty petrol, have you experienced anything like this? I feel like I can't win lol.
That's a huge difference..I would think a bad tank of gas, or an exhaust leak has developed and is throwing things off majorly. I would say gently run this tank of gas to E and try a different station, maybe try Shell like I've switched to. My IAM hasn't dropped below 1 lately.
JB86'd is offline   Reply With Quote
Old 03-13-2015, 12:25 AM   #296
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I was running shell before chevron, chevron seemed good for the first couple weeks O.o
What kind of timing are you pulling do you have a snapshot of your tables? I haven't been pulling that much just in the 2-4k RPM region. I guess I'll just ride this tank out and see if my IAM improves over time.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 03-13-2015, 12:43 AM   #297
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Mate i know you not going to like this ,but i think its all due to the AEM intake and the hardware chip thingo that probably adjusts maf readings. Just been doing some scaling on those intakes and they are a pain , suggest you go back yo stock intake with a drop in filter and sell the aem to someone.
Or buy grimspeed intake they are very close to stock scaling and you wont have these dramas
The sad part is you're correct. I know you are. I've been looking at that. and removing that chip thing is causing problems too. I may be going back to all stock here.
Old 03-13-2015, 01:23 AM   #298
JB86'd
JB86'd's Avatar
Drives: JAWS
stage 2 UEL 91 octane...as far as I know this is safe but no guarantees, I'm no expert.
The Following User Says Thank You to JB86'd For This Useful Post:
2much (03-31-2015)
Old 03-13-2015, 03:39 AM   #299
steve99
Drives: FT86
Mate i can give you the scaling i did but its on straight petrol not 10% ethanol fuel and without chip thingo, not sure how it will go, but if you want it let me know, managed to get trims to about 5% , but those aem intakes seem turbulant or something a real pain to get low trims on and correct afr.
Old 03-13-2015, 04:45 AM   #300
Kodename47
Kodename47's Avatar
Drives: UK GT86
Was that recent pull in a higher gear? There's quite a few more lines of data than the ones in February. I have put the main data into a spreadsheet to compare. Your LTFT are more negative, therefore you're running leaner. Not by much, but it could be enough to push you over a knock threshold. You could also try and make the engine run a little richer between 3000-4500. Here are the charts to compare:
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-13-2015, 09:09 AM   #301
Celadrielas
The AEM intakes are turbulent as all get-up and in addition to that, I have a cut snorkle which isn't helping at all, either. -- I'll take what I can get from you and would be GLAD to look at it, but I'll have to find a way to account for the Ethonol base in the fuel we have here in America.
Honestly, I think the answer is to change the intake I have out completely and go from there
Old 03-13-2015, 10:55 AM   #302
Phantobe
Phantobe's Avatar
I think the first two pulls were 2nd gear and last one was 3rd gear (in march). After you mentioned the thing about running leaner, I did go back & compare my logs. And I noticed I was running slightly leaner... This would have to be why I'm getting knock, afaik running richer is better esp. on 91.
What would you suggest I do? Pull timing in the 3500 to 4800 region, or try to run slightly richer? I assume that has to do with MAF scaling I haven't delved into that yet.
Also how did you compile the logs like that, is that from the knock correction tool? Thanks for all this great info! Sharing is caring :P
Old 03-14-2015, 01:20 AM   #303
Phantobe
Phantobe's Avatar
So I pulled some timing in the region where I was getting knock, and now I'm still seeing more knock!
Is it possible I just got a shitty fill up? I'm tempted to go back to Shell...
http://datazap.me/u/phantobe/91chevr...=0&data=1-4-14
Its weird, I noticed I was just cruising in 5th and stepped on the gas a little bit around 2200RPM & the ECU is pulling 2.50 degrees of timing. I'm just thinkin it has to be the fuel o.o
Old 03-14-2015, 02:46 AM   #304
steve99
Drives: FT86
for things to change that much its likley fuel
its also worth logging intake air temp instead of kc learned as large chages in intake air temps can effect knock
Old 03-14-2015, 05:01 AM   #305
Kodename47
Kodename47's Avatar
Drives: UK GT86
Doing that in 5th gear s likely to provoke "knock" just because of the load generated,
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-16-2015, 04:48 PM   #306
trdric
Drives: fr-s
So im pretty much new to software tuning, i ran e85oft OTS 2.063. I know from reading you guys that I my MAF is off since I use a greddy intake (takeda)
http://www.datazap.me/u/trdric/log-1...og=0&data=1-14
I know from what I read from @steve99 I was suposed to log to adjust it in 91oct :/
trdric is offline   Reply With Quote
Old 03-16-2015, 04:59 PM   #307
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Running the same intake - we've scaled two different cars(both running Takedas) with Steve's guidance and the odd thing was that the scaling was different between the two, the MAF sensors on these cars seem to differ quite a bit between them.
Started with the Takeda scaling posted elsewhere and took it from there, it's now at a point where it's pretty much spot on but it took time and a good couple of runs/logs.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 03-16-2015, 05:07 PM   #308
trdric
Drives: fr-s
ya i tried opening that thing. this is what i got
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
