Old 03-12-2015, 09:01 PM   #1
TRD_Demon527
TRD_Demon527's Avatar
Drives: 2014 scion frs , 1987 toyota supra
N/A build pros and cons...
i have built my car to the point where i like it as is but knowing me ill want more power. i would like to stay naturally aspirated and keep the car practical. any suggestions or ideas would be greatly appreciated.
my current mods are:
intake
cat back exhaust
billet power blocks
stage 1 tune from oft
crank pulley.
what would be the pros and cons of a nice N/A street build
TRD_Demon527 is offline   Reply With Quote
Old 03-12-2015, 09:08 PM   #2
raven1231
cons very little power for investment
Old 03-12-2015, 09:09 PM   #3
Createddeleted
Drives: 2014 BRZ - 2004 GLI
If you have to ask, you shouldn't be "building" an NA setup.
Pros
- slightly more power than stock
- longevity if built right
Cons
- so expensive your mind will explode
- you will ask your self why you spent all that money for such little power
- forced induction guys will put you to shame
- only knowing how to drive in a straight line (bad joke? Lol)
NA build and street usually don't exist in the same realm. If you want more power I suggest you start by getting a proper dyno tune instead of running on a basemap.
Createddeleted is offline   Reply With Quote
Old 03-12-2015, 09:09 PM   #4
TRD_Demon527
Well for a practical daily I'm not looking to build it to be a speed demon. I have my daughter to put in the car. So I need to keep it n/a for a while or until I get a spare block n build a strong engine.
Old 03-12-2015, 09:11 PM   #5
TRD_Demon527
I plan on getting a dyno tune after I get myself an exhaust manifold and change to another exhaust that will look cleaner then the j2 quad tip
The Following User Says Thank You to TRD_Demon527 For This Useful Post:
Createddeleted (03-12-2015)
Old 03-12-2015, 09:12 PM   #6
MikeM7
Drives: 2013 BRZ Limited White
If you want power, you should have gotten header instead of pulley and intake.
MikeM7 is offline   Reply With Quote
Old 03-12-2015, 09:12 PM   #7
Createddeleted
Sounds like you want to be fully bolted and not have an NA "build".
Old 03-12-2015, 09:13 PM   #8
TRD_Demon527
Yea I guess ur right sorry for not being more specific
Old 03-12-2015, 09:24 PM   #9
Createddeleted
- get a full exhaust
- get the new fluidampr pully
- get e85/flexfuel harness kit
- get dyno tune
- get LW flywheel
- get carbon fiber driveshaft
- exchange rear gear
I also suggest going to a track day. It lets you understand and communicate with the car better. Maybe you won't need to be fully bolted.
The Following User Says Thank You to Createddeleted For This Useful Post:
TRD_Demon527 (03-12-2015)
Old 03-12-2015, 09:26 PM   #10
TRD_Demon527
i appreciate the suggestions i will look into all the parts suggested and add them as i go. thank you again
Old 03-12-2015, 10:24 PM   #11
shellslinger
Drives: Whiteout FRS
Pros
Cons
+1. I would buy an OFT though.
shellslinger is offline   Reply With Quote
Old 03-12-2015, 10:26 PM   #12
TRD_Demon527
I have an open flash tablet
Old 03-12-2015, 11:19 PM   #13
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Only know how to drive in a straight line is typically saved foot forced induction cars that have little suspension and braking mods. Our brakes barely handle stock power let alone boost.
All depends on goals.
Imp cooling/brakes/suspension first. But I only have 6 hpde days in so far. I've iced 3 sets of brake pads.
FRSfan111 is offline   Reply With Quote
Old 03-12-2015, 11:22 PM   #14
TRD_Demon527
I upgraded to EBC brakes and rotors changed to the wrx 4piston calipers in the front. I stop on a dime. My suspension is coilovers swaybars strut bars and various components. The list of stuff done so far is posted in my garage with the photos.
Pros and Cons of the Rocket Bunny Kit VroomVroom86 Cosmetic Modification (Interior/Exterior/Lighting) 28 11-07-2014 01:29 AM
Colour options - pros & cons Sanzie99 Scion FR-S / Toyota 86 GT86 General Forum 44 07-03-2014 12:07 AM
Greddy vs avo stage 1 Pros and cons of each SliverBrz Forced Induction 90 04-18-2014 10:45 PM
KW V3's pros & cons Shaolin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 02-25-2014 09:58 AM
