#15 | |
Those two sockets and ratchet(s) are all you need. Assuming everything is cold, I can do this in under 5 minutes. If it's hot, I'd recommend you wait for things to cool down unless you have well insulated gloves. |
#16 |
You don't see JR kits for sale or I haven't in the user for sale area. I'm not sure what kinda HP numbers they make with the CARB tune someone chime in with that info. Closer to factory is the way I would describe it. They spent an asston of time perfecting the kit and from what I've read it was time well spent.
The KW kit is cheaper and seems to have sold more. KW customer service has been well above expectation in my experience. I don't have the miles others have on their kits but I haven't read of any major issues on professionally installed kits. Correct me if I'm wrong someone. I was able to install my kit in <5hrs. The instructions are fine if you take the time to read over them and understand them completely before jumping in and ripping stuff out. I've written a lot of instruction sheets in my years of automotive manufacturing so it made sense to me, so take that with a grain of salt. Honestly I don't think you can go wrong with either kit. I would highly recommend the oil cooler that both offer if you plan on driving hard though. |
| The Following User Says Thank You to FirestormFRS For This Useful Post: | Dpforlife (03-13-2015) |
#17 | |
That Guy
Drives: 2013 asphalt FRS MT
#18 |
Drives: Raven Scion FR-S
Thanks guys ! Great info ! If going with the JR. what do you also recommend changing or upgrading as a means of precaution for something not breaking? And also im content with hitting 270hp so JR seems to be a good choice
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#19 | |
Drives: FRS, Supra, Colorado D, GLC63
In fact, it is just as simple to detension it as it is stock. I had a customer who had one of his idler pulleys start to throw a little bearing grease. JR sent him a new pulley(free under warranty) and I went to his house with only a 14mm wrench and was able to replace it in his driveway in about 5 mins. |
#20 | ||
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
In before gmsii arrives I don't own either but I'd choose JR over KW. Here's why. -JR is simpler and more reliable, period. Several KW owners have experienced belt failures due to the overly complex dual belt system and cogged sc belt. -JR is going to be easier to change the air filter and it has already been proven that intake air temps with the JR kit are lower than stock so the "cold air intake" in KW's kit is not a perk in my opinion. Both kits use intercoolers. -JR allows and includes an option for a fully plug and play thermostatic engine oil cooler kit with a bigger, more efficient core than KW's offering. KW only offer one proprietary skunk2 adapter that's not thermostatic, which owners in cold climates should be aware of. Traditional Mocal sandwich plates don't fit with the giant KW mounting bracket. If you want a thermostatic oil cooler with KW's kit, you're on your own to figure it out. -JR is CARB legal with a rock solid reliable tune thats track tested in the desert over several thousand miles, KW is still not CARB legal and hasn't been approved in over a year since they announced they were seeking approval. KW has been making excuses for the delays and meanwhile JR has had CARB approval about month after releasing their kit. Quote:
-JR offers a pulley upgrade for the C30 which puts power figures with pump gas over 300whp. If your power goals are north of 350whp and you're considering or have a KW C38 kit, you could have met those goals more efficiently and with more torque by going with one of many turbo kit offerings. Personally I don't see the point in running a C38 on the FA20 as it's simply too big for the engine to use efficiently. A turbo just makes more sense to me at that power level because again you'll have more usable torque and area under the curve. To me the C30 is perfect for these cars and owners looking for ~50% more power reliably and without all the extra heat from a turbo. Track-ability is second to none with Rotrex superchargers since they run cooler and more efficiently than everything else available. Jackson Racing just does it better through a more simple design and more quality control through lots of testing PRIOR to releasing their products. Both of the aforementioned points are directly correlated to their kits reliability which is second to none. It shows trough their post-release track record and lack of issues discussed in the JR owners thread compared to KW's. /FlameSuitOn
| The Following 10 Users Say Thank You to ATL BRZ For This Useful Post: | campy (03-13-2015), Cheeseballs (03-13-2015), ck-GT86 (03-17-2015), dp1 (03-12-2015), flippy (03-12-2015), JEFFSTYLE (04-05-2016), Jesse36m3 (03-12-2015), ohmai18 (11-23-2015), themajesticone (03-12-2015), uRBAN_Metal (03-12-2015) |
#21 | |
No Money, No Problems
Or does that make it non-CARB legal at that point? |
#22 | |
Drives: 2015 scion frs
| The Following User Says Thank You to otterpop For This Useful Post: | Freeman (03-12-2015) |
#23 | |
Lots of good info in this thread. I purchased and will be installing the JRSC this weekend. I based my decision on the amount of good reviews/comments by tuners and owners. I have read very positive comments from Delicious Tuning and Moto Mike on this kit, that means a lot to me. The lack of problems with the JRSC seems self evident if you do enough searches. Just my .02 Pat |
#24 |
#25 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | sw20kosh (03-13-2015) |
#26 |
Drives: 2013 Ultramarine FR-S
Yup the torque rush of a turbo is childish to me. But it makes cruising around not as boring.
#27 | |
| The Following User Says Thank You to LucidMomentum For This Useful Post: | CSG Mike (03-12-2015) |
#28 |
Another happy JRSC / Moto-East customer here. The setup is slick, the drivability is excellent and the experience is really non-intrusive, until you hit about 4500 rpm--then hold on! The JR setup is everything that has been described: solid design, great execution, user-friendly, and all initial feedback has been that it is very reliable. I've had no issues with my package (including the oil cooler). I also had to overcome an aversion to its looks since I wanted something that looked OE--which would be Vortech package IMO. But, since my hood is up only long enough to check fluids or to show off the JR kit and Moto-East's flex fuel, I decided I could live with the JR function-first, looks-second first impressions. No regrets.
My $0.02 is that if you want (or think you'll want) a strong low-rev kick-in-the pants experience as your primary goal, then you really should think about going turbo (or Sprintex). In my case I specifically wanted to build a track-oriented setup. So, in that sense, the JRSC was a no-brainer when compared to other options. Yes, there are many good turbo packages for the track and they usually offer more power (if you really need/want that in a 2700 lbs. car), but you will need to take extra $$$ steps for heat management and managing the power if you go big: fueling, oiling, internals, transmission and axles. The forum is full of threads on those subjects. If you're honestly looking at whp power levels from 250 - 350 (with e85 and fueling mods) then it's hard to beat the relative ease of a SC setup. You just need to decide what sort of grin-factor you want. This car is a handling dream, and I chose to preserve that aspect vs. higher power levels. |
| The Following 4 Users Say Thank You to sprintamx For This Useful Post: |
| Supercharger Comparison: Innovate, Jackson, Kraftwerks, Vortech *Updated March 9 2014 | CSG Mike | Forced Induction | 281 | 02-25-2021 04:14 AM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Kraftwerks C38 Supercharger Kits with EcuTek - In Stock Super Sale!! | rickspecd | Forced Induction | 10 | 01-03-2015 07:11 PM |
| Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? | OICU812 | Forced Induction | 7 | 10-14-2014 12:36 AM |
