Old 03-11-2015, 04:20 AM   #1
donoman
donoman's Avatar
Drives: '13 FR-S
Test drove a '15 BRZ, bought a '13 FR-S ... WAY DIFFERENT
Decided I should get an '86 used, just in case the car turns out not to be my cup of tea. Boy was I surprised at the lack of ride quality in this FR-S after driving it around a little more.
Intended use: Daily driver, mixed city/fwy. Some days 10 minutes, some days 60 minutes each way. Grocery beater, something that I won't mind bringing to the gym as my other cars are just too rare to beat on.
I'm actually pretty APPALLED that the suspension is so dang brutal in the (older) FR-S. When I test drove the '15 BRZ it was firm but not rough. I actually LOVED it and that's saying a lot. The tire grip, the motor, the interior noise level, it's all to my satisfaction but wow that rear suspension reminds me of my lowered Miata on GC track suspension. It's totally different... set up for sharp handling and auto-x but probably not as good of a daily driver. Hats off to you guys (and your butts) that can handle this all day err day. Maybe I'm just getting old.
AM I CRAZY or is this drastic difference real?
Edit: Car has 22k miles and previous owner only drove it for 1.5 years... car was babied.
donoman is offline   Reply With Quote
Old 03-11-2015, 04:52 AM   #2
CoupedUpSubie
Drives: 2013 BRZ Limited
Are you sure it was babied? Private sale or from a dealer?
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 03-11-2015, 05:20 AM   #3
donoman
donoman's Avatar
Drives: '13 FR-S
Barring having the previous owner swear on his mothers grave and take a blood oath yes, it was babied. I used to be a buyer for a car dealership and this car is legit.
Old 03-11-2015, 05:21 AM   #4
donoman
donoman's Avatar
Drives: '13 FR-S
One thing I didn't think about is perhaps the difference in seats. I test drove a '15 BRZ limited and this thing has cloth seats.
Old 03-11-2015, 05:42 AM   #5
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
You did know that the FRS and BRZ suspensions are different spring rates right?
ntron1 is offline   Reply With Quote
Old 03-11-2015, 06:12 AM   #6
Are you sure it is on stock suspension??
The FRS aint no glide on a cloud ride but with stock suspension it shouldn't be as bad as you are describing either.
Old 03-11-2015, 06:13 AM   #7
donoman
donoman's Avatar
Drives: '13 FR-S
I knew but had no idea it would be so drastic. Lots of people talk about how the two cars feel almost the same. They feel very different. I feel like the front is good but the rear needs more rebound damping.
Old 03-11-2015, 06:14 AM   #8
donoman
donoman's Avatar
Drives: '13 FR-S
I need to also make a confession that I'm coming from very German cars so my butt is probably used to the luxury.
Old 03-11-2015, 06:21 AM   #9
AJPG
Drives: 22RE, FA20, 4G63
Mine (FRS2013) could use more damping on the rear, but that's above 80-90mph... At that speed also need brake upgrade to avoid heat soak/overheating.
AJPG is offline   Reply With Quote
Old 03-11-2015, 07:29 AM   #10
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Maybe you should go test drive a 2014/2015 FRS at a dealership and see if you still have the same opinion about the suspension. I dont think there were any changes made to the suspension between model years for the FRS.
For the BRZ I think the 2015 improved ride quality even more, not sure how, its just what I've read a few times around here.
EDIT: I saw your WTB thread lol. Might want to look at this: http://www.ft86club.com/forums/showthread.php?t=84230
Old 03-11-2015, 07:46 AM   #11
ImBatman
My Tumbler is an FRS
Drives: exclusively in the fast lane
They did tweak the suspension a bit on the 2015 FRS... it was really the only "performance-oriented" upgrade they made since the first model year.
Apparently, they made the FRS ride similar to the BRZ. Not quite as tail-happy and a touch softer for daily driving.
That's what they tell us anways... @Tcoat broke down the differences in this thread: http://www.ft86club.com/forums/showthread.php?t=73739
There's some pretty good first-person, real-world experience impressions in there if you're interested.
The only other performance upgrade in the 2015 FRS/BRZ that I know of is the factory turbo... Should've opted for the new one man.
ImBatman is offline   Reply With Quote
Old 03-11-2015, 07:49 AM   #12
PandaSPUR
PandaSPUR's Avatar
So the OP's best bet for a good comparison would be to find another 2013/2014 FRS owner, or find a dealer that still has a 2014 on the lot I guess.
Old 03-11-2015, 07:59 AM   #13
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
And a lot more weight. German cars are bloated and heavy now. That makes for a much more luxurious feel and smoother ride. You have to do a total mind wipe once you get used to and start enjoying that in order to appreciate the light and tight that you get from the FR-S. A lot of the early adopters could not adjust and scurried back to the lap of luxury.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 03-11-2015, 08:14 AM   #14
xmadror
Drives: BRZ Sport Tech 13
Is the fr-s still on stock wheel and tire size ?
Many owner went with 18" and that would make it harsher
And as mentioned already the spring rate are not the same for the frs and brz
Spec from a quick search from 2012 post (not sure if its still accurate but it should):
Front OE Spring Rate:
Subaru BRZ 27 N/mm (153 lbs/in)
Scion FR-S 23 N/mm (131 lbs/in)
Rear OE Spring Rate:
Subaru BRZ 34 N/mm (195 lbs/in)
Scion FR-S 37 N/mm (211 lbs/in)
So there is a difference but I'm not gonna try to elaborate any more on this (already plenty of info on this forum about that)
xmadror is offline   Reply With Quote
Hey guys I recently test drove the 86 straight after test driving the Megane RS. Obsessionz Scion FR-S / Toyota 86 GT86 General Forum 32 09-23-2014 01:20 PM
test drove FRS mush Scion FR-S / Toyota 86 GT86 General Forum 47 06-05-2013 01:36 AM
test drove both 86 and brz same day! leoz1412 AFRICA 33 02-06-2013 07:12 AM
test drove both 86 and brz same day! leoz1412 AFRICA 0 02-03-2013 01:52 PM
test drove both 86 and brz same day! leoz1412 AFRICA 0 02-03-2013 01:51 PM
