Old 03-10-2015, 04:00 PM   #1
fasteddy
2013 VS 2015 BRZ Suspension changes
I have heard that there were new suspension changes for 2015. I have yet to find any good solid info so far. I keep coming across references to 2015's having Sachs dampers, or just different dampers.
I bought a full stock suspension from another member out of a 2015 Series Blue. These are Showa units, not Sachs. They do have a different part # than the 2013-2014. I pulled these part #'s off of the web:
SHOCK ABSORBER-REAR .
This genuine part fits your 2013 Subaru BRZ .
Stock Code 20365CA011 ; 20365CA010
This genuine part fits your 2015 Subaru BRZ .
Stock Code 20365CA110
STRUT COMPLETE-FRONT LEFT .
Stock Code 20310CA130
Stock Code 20310CA031 ; 20310CA030
The spring part #'s appear to be the same.
Anyways I am just throwing this out there for reference. I am pushing on 40,000 miles and figured a new setup out of a 2015 should be an improvement, although how much is yet to be seen.
I will post up my impressions after I put the 2015 stuff in. That won't be for a month or so though. I may wait until after my first track day of the year so I can have a good comparison.
Anyone actually seen any stock Sachs dampers in a US BRZ?
Pat
edit-this is the only real review between the two I have found yet http://www.ft86club.com/forums/showp...&postcount=432
************************5-14-2015 Edit-update after install!**********************************
I finally got the 2015 suspension installed in my car last week. I have had a chance to put a few hundred miles on it now. All I have to say is. WOW, I cannot believe how nice the car rides now!
The main difference that I noticed is that I do not seem to harshly feel every single bump in the road like I did before. Perhaps they softened up the compression or something? The car feels simply a lot more composed and is not seem to get as upset over bumps.
The car definitely rides a lot nicer than with the 2013 suspension.
I have a track day on Monday so I will see how it really handles then. I do not suspect there will a big difference as far as that is concerned.
Pat
fasteddy is offline   Reply With Quote
The Following 10 Users Say Thank You to fasteddy For This Useful Post:
Bonburner (05-01-2015), Createddeleted (03-11-2015), cslntuee (03-11-2015), Darkparadox911 (07-24-2015), Hyper4mance2k (03-10-2015), kdmBRZ (03-13-2015), N234 (03-10-2015), peachsnow (03-11-2015), Tcoat (03-11-2015), x1UP (03-11-2015)
Old 03-10-2015, 04:01 PM   #2
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
How much did you buy the Series.Blue stock suspension for?
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 03-10-2015, 10:12 PM   #3
N234
N234's Avatar
Drives:
Thanks for the info!
N234 is offline   Reply With Quote
Old 03-11-2015, 05:46 AM   #4
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't think that by changing just the dampers you'll have the best result. The chassis is stiffer in the 2015 models and the dampers were changed because of this. One well known change are the new suspension mounts (new bolts and nuts). You can find the new part numbers here.
The Sachs dampers can be ordered only by Toyota Japan. They are sold as an additional part for Toyota 86. As you said, the new dampers in BRZ are again by Showa.
Old 03-11-2015, 08:35 AM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
Guys, I really doubt that a slightly different bolt head could make a noticable difference in the feel of the car. Especially considering where they are. All of them are mainly in shear, not tension where that different head design MIGHT make the assembly stiffer. Even then I highly doubt the new design would make any difference at all. It's probably just a different supplier or, for some reason, the new bolts are cheapers.
The Following 2 Users Say Thank You to Calum For This Useful Post:
2013GTRNate (01-21-2016), wparsons (03-11-2015)
Old 03-11-2015, 08:56 AM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It is not only the head different and the designers usually do not make anouncements if the change is only the supplier. Anyway, I don't think it is worth to discuss this. The extra cost is just a few dollars and they don't need any extra installation effort. Personally, I wouldn't take the risk not to change them.
The Following User Says Thank You to nikitopo For This Useful Post:
funwheeldrive (12-27-2016)
Old 03-11-2015, 09:43 AM   #7
fasteddy
I got my set for $200 shipped.
I agree with you about the bolts. I am sure they cannot hurt anything, but I would be very surprised if they produced any noticeable difference in handling or ride.
Pat
The Following User Says Thank You to fasteddy For This Useful Post:
Calum (03-11-2015)
Old 05-14-2015, 02:09 PM   #8
fasteddy
Thumbs up
Pat
The Following 3 Users Say Thank You to fasteddy For This Useful Post:
Hyper4mance2k (05-14-2015), jcygts6 (05-15-2015), nikitopo (07-20-2015)
Old 05-14-2015, 04:36 PM   #9
Cope52
Drives: 2014 BRZ
Whenever they say "revised" or "retuned" shocks/suspension its almost always softer. If it were firmer, they'd say so. I drove a '15 BRZ it's definitely softer. I think the earlier cars ride just fine, especially for the level of handling.
Originally Posted by LeeMaster View Post
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my clutch engagement point felt smoother.
Cope52 is offline   Reply With Quote
The Following User Says Thank You to Cope52 For This Useful Post:
Old 05-14-2015, 05:05 PM   #10
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Pat
Confimation of what I have been saying. I don't think it's softer at all, I think they have a batter dampining curve that better matches the spring rates. The old struts had to adapt to a pretty broad rance of spring rates that they were throwing in the 86, FRS, & BRZ.
I can also confirm that the 2015 struts are better valved for Swift Spec R's I run. Rebound control is much better in my 2015 than in my 2014. (though now I have my Bilsteins installed)
edit: I also think it's worth noting that Subaru said in their press release that the 2015 chassis was stiffer to combat the noises from spirited driving. I'm guessing they're talking about the rear deck lid popping noises.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Old 05-16-2015, 02:16 AM   #11
donoman
donoman's Avatar
Drives: '13 FR-S
Pat
Looking forward to hearing your feedback. I finally got used to my 2013 FR-S suspension but my initial feeling (after almost buying a 2015) was that it was REALLY rough.
I have a set from a 2015 BRZ waiting to go into my car but I was contemplating some lowering springs. However, none of the Bilstein/Eibach/RCE's have specific springs for the 2015+ suspension and I am guessing they were designed with the 2013-2014 car in mind. So now I'm wondering if that will be dumb to put lowering springs from a 2013-2014 on shocks from a 2015. Yes, first world problems.
With that being said, I think the FR-S handles wonderfully in the canyons and I am so amazed by the suspension that I really don't want to screw it up.
donoman is offline   Reply With Quote
Old 05-16-2015, 05:00 AM   #12
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There were no changes on springs. Old lowering springs are compatible with newer OEM struts.
Old 07-04-2015, 02:29 AM   #13
donoman
donoman's Avatar
Drives: '13 FR-S
Update:
Just installed suspension from 2015 Series.Blue BRZ into my 2013 FR-S and there is a noticeable difference. The car handles bumps a lot better and the feeling is that the ass is more planted. Whereas before, I could easily get the back end to step out by simply gassing in 2nd gear around a left-hand turn, that is no longer the case.
Ride quality is marginally improved and it's a worthwhile modification over the 2013 FR-S shocks if you're looking for a calmer ride. For the price I got my suspension ($250) used, it was entirely worth it.
Suspension took approximately 2.5 hours to complete from wheels up to wheels down, and this was the first time I've done it on an '86.
The Following 4 Users Say Thank You to donoman For This Useful Post:
Mr.Impreza (01-21-2016), nikitopo (07-20-2015), P@ul (07-07-2015), TofuJoe (03-31-2017)
Old 07-04-2015, 09:24 AM   #14
Teseo
Drives: frs
Acording with op the "new" suspension make the car more soft, i pass
By the way how much cost everything
GrimmSpeed Cold Air Intake BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Engine, Exhaust, Bolt-Ons 22 03-25-2015 01:12 PM
Beatrush Over Pipe Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Engine, Exhaust, Bolt-Ons 17 03-16-2015 11:29 AM
2015 models suspension different ??? Sugi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-25-2014 11:15 PM
Review of 2015 BRZ suspension changes? thismock BRZ First-Gen (2012+) — General Topics 10 09-26-2014 09:38 AM
2015 Model FRS suspension changes SeanRTR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-21-2014 12:21 PM
