Old 05-17-2012, 09:04 PM   #29
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Wow, that's pretty impressive. Mine over 289K miles was only about 36. He must have drove nothing but highway and hammer down the whole time.
Even when checked it over highway trips, the second you pulled off for gas, the avg would drop significantly.
used to do sports and i was top 10 national for my age group, so we went to a lot of competitions... nothing but highways, but during the week he still sat in stop and go traffic... 287000 miles in 5 years... never once changed the spark plugs, very reliable van, sold it for 3k..
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 05-17-2012, 09:21 PM   #30
That would explain it. One of the best vehicles Chevy ever made, they should still make it. Between the two I had I literally drove them far enough to have gone to the Moon and back, with almost zero issues. But, when they died, they died hard!
Old 05-17-2012, 09:23 PM   #31
carbonBLUE
Reverse Burnouts
well i guess we need 2k more miles for it to die! 287000 to your 289000 lol...
(wont forget you)
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
Dadhawk (05-17-2012)
Old 05-17-2012, 09:28 PM   #32
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
i really didn't see the MPG disply
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 05-17-2012, 10:12 PM   #33
bslag
Drives: 2009 Mitsubishi Lancer GTS
Originally Posted by serialk11r View Post
Miles to empty is just calculated off the amount of gas you have in the tank right?
Not quite. It also takes into account your current MPG, so it does fluctuate.
In my previous cars, I pretty much just always tried to fill up when I was around 1/4 tank remaining just to always be safe.
bslag is offline   Reply With Quote
Old 05-18-2012, 01:12 AM   #34
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Miles to empty is just calculated off the amount of gas you have in the tank right? I'd just like to see an accurate fuel gauge so I know how much fuel is actually in there! More useful than "miles to empty" which will vary depending on circumstances and driving.
I hope it switches to gallons per hour when you're idling, that is good information to know. Speaking of which, any current owners able to chime in on this? Does it just say 0.0mpg when you're stopped, or does it give you gph?
Would GPH actually be that useful to you? Do you know of a few vehicles with this? I know many commercial trucks now cut the motor after idling over certain times.
How much can you idle; its great for boats but why would you want your car to be idling for hours in the first place?
chulooz is offline   Reply With Quote
Old 05-18-2012, 01:35 AM   #35
serialk11r
Drives: '06 AM V8V Coupe
I suppose it's not actually that useful, but it's better than a display that reads "---" or "0.0", which is just completely useless and stupid. Knowing idle GPH might make some people consider turning their engine off more often, and if you're stuck in say a closed off mountain road where you don't know how long you're going to be there, knowing how much fuel idling costs you would help you make a better choice as far as fuel conservation goes. I believe VW cars have the GPH reading in neutral, but not sure if it's across all models or if it even exists in the US (I noticed it in a VW Jetta taxi in another country).
