Old 03-08-2015, 01:09 PM   #113
aagun
Drives: 86
Any one can post here if there are any LTFT activity . Mine is 14% at idle
aagun is offline   Reply With Quote
Old 03-08-2015, 01:36 PM   #114
BRZnut
Drives: BRZ DGM Limited
Originally Posted by RedEdTed View Post
Hmm.. mine is making some noises too. Only when the car is warmed up about 20 minutes.
Been going on for over 3 months not getting worse so i took it to Toyota to check it out, (no scion dealers near us).
Report from Toyota:
Cause: ticking noise from high pressure fuel pump
Correction: replaced fuel pump as per tsb 3863
Shortly after driving around warming up the engine i hear the noise again.
Back to the dealer next week probably, this time with the car warmed up and hopefully the noise going. I may bring them some of the information on this forum for them to think about :P
Here is a youtube of the noise:
Sounds like rod knock but not as loud as some others that have posted
Old 03-09-2015, 03:30 PM   #115
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
I don't get that tapping sound, but is the noise of the belt supposed to be that loud? Really noticing it on mine these days. Also my injectors.. jeepers
Wilso is offline   Reply With Quote
Old 03-10-2015, 01:26 AM   #116
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The injectors ARE loud. It really depends on the noise.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Wilso (03-10-2015)
Old 03-10-2015, 03:01 AM   #117
jaime3
jaime3's Avatar
Drives: Scion FR-S
sounds like rod knock to me? does it get louder as you drive?
jaime3 is offline   Reply With Quote
Old 03-10-2015, 02:55 PM   #118
Squishy
Drives: 2013 WRB BRZ
Report from Toyota:
Yours sounds more like a really bad idle tensioner pulley and not rod knock.
Rod knock would indeed be more audible as you revved the motor. If it does, I am surprised the dealer has not figured that out yet.
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 03-14-2015, 03:04 AM   #119
RedEdTed
RedEdTed's Avatar
Drives: Scion FRS, Rocket bunny kit
Hi again!
Originally Posted by aagun View Post
this is rocker arm and lifter issues
Would like to offer some words of encouragement but that does not sound promising!
If you have a Subaru dealer nearby you may be better off taking it there then a Toyota one that does not deal with the FRS all the time. The Toyota techs may never have had to deal with the boxer engine before and have no clue what they are looking for.
Originally Posted by N1rve View Post
Definately sounds like my issue.
My noise only happens when it's warm too and NOT when it's cold.
Thanks for all the replies guys!
Well in that case yes it may not be the rod knock?
N1rve, after reading your post about them replacing "All 8" has that first noise issue gone?
Here is the conditions of the noise i'm getting:
-Noise is a tapping knocking noise coming from behind, in or under the engine (not near the front pulley/ alternator system)
- Started about 35,000k's not getting any worse.
- Car really warmed up (after driving for at least 10-20 minutes)
- Most notable when idle or low revs (cant hear over higher revs/ while driving not sure if it stops or engine noise is louder?)
- When noise is going it is consistently going when it starts and only stops when the car turns off and cools down.
I have been too busy this week to do anything. I will call the closest Subaru and Scion dealers with the information I now have and see if I should take it to them or if the local Toyota can actually fix it?
Will post results as they come.
RedEdTed is offline   Reply With Quote
The Following 2 Users Say Thank You to RedEdTed For This Useful Post:
aagun (03-14-2015), Tcoat (03-14-2015)
Old 03-14-2015, 08:39 AM   #120
BRZnut
Take it to the dealer/ remove any after market add-ons to the engine if you have them before going/ have all your oil change recepts ready to show them.
If this is an engine issue and you did not get all your service at the dealer, get ready for them to try to get out of covering the cost of the repair. That seems to be the trend from those that have posted here.
Old 03-14-2015, 11:49 AM   #121
And we wonder why some dealers question things?
"Honest Mr. Service manager it was completely stock and I really did all my oil changes on time and with the right volume of the right oil" (not saying anybody here does this).
The warranty is very clear that aftermarket parts that may have impacted the failure void the coverage. If you don't think they may have been a problem why take them off? If you do think they may have been a part of it then taking them off is fraud.
My point here is that in a perfect world everybody would be up front and honest with the dealers and they would do warranty work without question but people aren't, so they don't!
(sorry for the sermon)
richardM (04-08-2015), yo joshman (07-20-2015)
Old 03-14-2015, 01:05 PM   #122
Squishy
In that case you could be hearing what I have my car in for. Passenger side exaust cam sprocket failure. Much like the AVO thread for the p0017 (passenger side) or p0016 for driver side exhaust cam sprocket. I hear a clicking that appears relative to that parts weakness.
You may just be hearing the one part loose enough to make the clicking noises but not bad enough to trip the CEL.
or it is something else in the valvetrain. This is the worse scenario to know something is wrong but no CEL to back it up.
Hope you luck solving the problem.
Dale Earnhardt
Old 03-14-2015, 03:40 PM   #123
N1rve
N1rve's Avatar
Take it to your dealership to have them listen to it. Only they can authorize the repairs.
My noise has not returned since all replacements.
N1rve
Old 03-14-2015, 05:37 PM   #124
BRZnut
Because.... even if the add on parts have nothing to do with the issue, once the dealer sees you have modified your car they will use it as an excuse to stick the owner with the cost of the repair. Several members here have found that to be the case.
If the dealers were honest with the customers, it would not be necessary to remove the parts before going in.
Old 03-14-2015, 09:25 PM   #125
It is a two way street as members also blew it with a tune, over boast or just plain screwing it up and stripped everything down to collect on warranty.
There are also many examples here of people that had warranty work done with no issues so it isn't all the dealers that are out to get the customer.
Ultramaroon (03-15-2015)
Old 03-15-2015, 08:12 AM   #126
BRZnut
I agree. If you boost your ride and it blows , you should be man enough to fix it yourself and not try to scam your local dealer.
I just wish we could get a handle at what causes the oil starvation issues on non-modified cars. Are they a little low on oil? over due for an oil change? Always run at 6,000 RPM?
I am all about doing all I can to prevent an issue, but other than changing my oil with a good synthetic every 5000-7500 miles and not constantly driving like I stole it, not sure what else can be done.
The Following 3 Users Say Thank You to BRZnut For This Useful Post:
Tcoat (03-15-2015), Teseo (03-16-2015), Ultramaroon (03-15-2015)
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 09:58 PM
2013 scion frs engine scion123 Engine, Exhaust, Bolt-Ons 16 10-13-2014 09:03 PM
Engine knocking after flash Tenchi Software Tuning 10 09-25-2014 11:50 PM
tapping sound coming from engine forgotten93 Issues | Warranty | Recalls / TSB 11 12-23-2013 09:54 PM
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts ptuning Engine, Exhaust, Bolt-Ons 0 02-04-2013 10:24 AM
